Go Back  Bike Forums > Bike Forums > Indoor & Stationary Cycling Forum
Which bike trainer works best with Zwift?
Indoor & Stationary Cycling Forum From spin to Zwift to Peloton, this forum is dedicated to any and all indoor training on stationary bikes
Old 02-02-19, 12:23 AM
Alfster
long time visiter
Alfster's Avatar
Bikes: 2005 Trek 6700 disc 2007 Orbea Onix 2009 Raleigh One Way
Quoted: 33 Post(s)
I'm wanting to replace my old Fluid 2 trainer with a smart trainer that works well with Zwift. Which one do you guys recommend?
I'll be using a 2007 Orbea Onix with a Shimano RD 6600 10 speed cassette.
Alfster is offline
Old 02-02-19, 04:33 AM
srode1
Gravel Rocks
Bikes: Trek Domane and Crockett, BH G7, Niner RLT9, RLT9 RDO
Quoted: 124 Post(s)
Liked 38 Times in 29 Posts
What's your budget? Wheel on trainers are in the $500 range, wheel off trainers are more like $1000 on average. Wheel on trainers are better generally if you don't mind spending the money. My advice would be check out DCRainmaker reviews and comparisons of trainers on the market, he does a great job.
srode1 is offline
Old 02-02-19, 06:45 AM
rubiksoval
Bikes: bikes
Quoted: 2622 Post(s)
Liked 1,429 Times in 711 Posts
I went from a Cycleops Fluid to a generic fluid along with rollers at times to a Tacx Flux to a replacement Tacx Flux. Replacement has worked well over the last few months of hardish riding. Both Flux models I've had consistently report 10% less power across the board, from z2 to max sprints. A massive problem for Zwift, but easily alleviated by using my own power meter. If you don't have a power meter, though, and want to do a lot of group rides/races on Zwift, I would not recommend this trainer.
Everything else on it works well so far. Connects quickly, dropouts are rare.
rubiksoval is offline
Old 02-02-19, 10:17 AM
Alfster
long time visiter
Alfster's Avatar
Quoted: 33 Post(s)
I'm willing to spend a bit to get a decent trainer. I was checking out the Wahoo Fitness Kickr Power Trainer. I think it's their latest 2018 model. It seems to get decent reviews. I'll check out DCRainmaker's reviews. Thanks.
Alfster is offline
Old 02-02-19, 10:42 AM
srode1
Gravel Rocks
Quoted: 124 Post(s)
i haven an Elite Drivo, have had it for over 2 years - very happy with it. I had a Cyclops wheel on smart trainer before the Drivo and returned it - it would get very inaccurate in the middle of hard workouts.
srode1 is offline
Old 02-05-19, 10:23 AM
zacster
Bikes: Kuota Kredo/Chorus, Trek 7000 commuter, Trek 8000 MTB and a few others
Quoted: 22 Post(s)
Liked 461 Times in 363 Posts
I have the Kickr Core and I'm happy with it. My prior trainer was also the Fluid 2. If you don't already have a power meter and can see real power readings, be prepared for a disappointment when you see your real power. I dropped about 40 watts compared to the "virtual" power.
zacster is offline
Old 02-05-19, 02:11 PM
Alfster
long time visiter
Alfster's Avatar
Quoted: 33 Post(s)
Ha, I definitely won't be disappointed to see a drop in my power reading. I have nothing to compare it too. I'm just starting to get back into some kind of shape after 10 years of sloth. I'm considering a smart trainer for two reasons: To avoid the boredom of my old Fluid trainer by taking advantage of Zwift, and to be able to track my fitness progress, where yes, power readings will start to become important. For now I'm just riding the fluid trainer until I decide which one to purchase.
Alfster is offline
Old 02-05-19, 03:08 PM
redlude97
Quoted: 1975 Post(s)
Liked 232 Times in 173 Posts
If you have a PM and plan to use it for powermatch, then any smart trainer will be good. If not, then a direct drive will require less calibration, wheel on trainers should be calibrated each ride after a warmup to maintain accuracy.
redlude97 is offline
Old 02-06-19, 01:21 PM
Genaro
Genaro's Avatar
Bikes: Motobecane Immortal Force
Quoted: 19 Post(s)
Liked 15 Times in 11 Posts
I am still wating for my fluid 2 to give out so I can upgrade to a smart trainer. Using it with my power meter has worked perfectly. I'm afraid of automatic resistance... Hopefully its not much of a shock
Genaro is offline
Old 02-06-19, 06:22 PM
srode1
Gravel Rocks
Quoted: 124 Post(s)
You might never get a smart trainer then.
srode1 is offline
Old 02-08-19, 03:32 PM
kcjc
Quoted: 84 Post(s)
Liked 47 Times in 34 Posts
? As long as the unit support Ant+ FE-C prototol it'll work with Zwift. Check Zwift for trainer BLE compatibility. If you are using Apple to run Zwift, you're stuck with BLE for the most part. Windows, Ant+ FE-C. As far as trainer response, Zwift was developed with Wahoo and Apple in mind initially so older Wahoo Kickr have the advantage when compared to later crops (gen 1 Drivo, Hammer, Neo, etc). If the reviews can be trusted, the gap are non-existing for gen 2 (haven't seen any review of Kurt Kinetic or Hammer 2). It wans't that big of a difference in the first place (i.e. 1 sec vs 2-3 sec response to change of slope, resistance, etc). I have a Drivo (gen 1, >2 years old) and are partial to my inital selection. If I was to do it again, I'll probably take a harder look at Neo (Neo wasn't shipping yet when I bought the Drivo, same with the Hammer). I ranked accuracy and repeatability of power measurement, reliability, and QA/QC (Drivo) over program response (Wahoo, note this aspect wasn't in the initial determination but acknowledgement after extensive use on Zwift). I would not bother with a wheel-on trainer.
kcjc is online now
Old 02-09-19, 11:26 AM
Alfster
long time visiter
Alfster's Avatar
Quoted: 33 Post(s)
Thanks for the reply kcjc. After doing some much needed research on the various smart trainers, I've decided to go with the one I believe will give me the best experience with Zwift ... the Wahoo Fitness Kickr Power Trainer. Although not fully compatible out of the box with my current road bike, I can easily switch out the 11 speed cassette with a 10 speed.
Thanks for all the other replies. Much appreciated. As some of you may have seen in the 'Fifties Plus' forum, I'm busy renovating my exercise room. Once I'm done I'll be purchasing a new trainer.
Alfster is offline
Old 02-10-19, 09:48 PM
obit
Wahoo Kickr Core
Cannot say it is the best, but the wahoo kickr core has been great. Use it with a mac, ant dongle, and garming hr. Good times.
obit is offline
Old 02-11-19, 02:45 PM
jadocs
jadocs's Avatar
Quoted: 942 Post(s)
Liked 526 Times in 349 Posts
Smart rollers, specifically from InsideRide. IMO there is nothing more realistic than that with Zwift.
jadocs is offline
Likes For jadocs:
Old 02-08-20, 12:05 PM
SCTinkering
SCTinkering's Avatar
Bikes: 2020 T-Lab X-3 w/GRX Di2, 2018 Trek FX-5S with GRX/Xt 1x drive train
Quoted: 44 Post(s)
Liked 41 Times in 25 Posts
As of current firmware and zwift software, NOT the Kinetic R1. I got one when they were being offered for $699 w/ free shipping. I spent another $125 or so on things to make it work, Powered USB 3.0 hub with 3m cable to reach from my tablet to near the trainer, ANT+ dongle so I could use my Garmin cadence and HR strap, then when that wasn't working a Bluetooth cadence sensor & hr strap. Even if I stayed with my almost 20 year old Cyclops Fluid+ I would have gotten the tablet holder, so I won't count that $40.
From what I understand Kinetic was both late to the smart trainer game and tried to write their own protocol over BT instead of licensing what's been working for everyone else (Saris, Trax, Wahoo, etc.) It set them a LONG way behind on the "Smart" portion of the trainer.
That all said, it does work VERY well with Trainer Road. Zwift being more social with some training available vs Trainer Road is about training. period.
So if you want a smart trainer to workout of the box with a minimum amount of fuss, Wahoo has their act together, but it will cost. If you want to play less and are willing to be a beta tester, the Kinetic R1 hasn't really been full price since I started looking at them about 4 months ago. Either way do the math and make sure you're budgeting for EVERYTHING you'll need, not just the trainer.
SCTinkering is offline
Old 02-08-20, 12:47 PM
sdmc530
Heft On Wheels
sdmc530's Avatar
Quoted: 887 Post(s)
Liked 560 Times in 346 Posts
I have the kurt kinetic smart trainer and its been awesome. 4 years, no complaints. Its a wheel on trainer I wasn't willing to go wheel off trainer money but I am not disappointed at all. Been a great winter training tool for me. I only use Zwift with it.
Just my opinion of course....
sdmc530 is offline
Old 02-10-20, 01:36 PM
OBoile
Quoted: 1027 Post(s)
Liked 325 Times in 204 Posts
I also have a kickr core. I've never used another direct drive trainer so I can't compare to those, but I'm glad I made the upgrade from a wheel on trainer.
OBoile is offline
UmneyDurak
53
07-07-19 10:58 AM
Caliper
Road Cycling
28
11-20-18 06:21 AM
boshk
Road Cycling
10
06-20-17 09:48 PM
Valsgarde
Road Cycling
6
06-22-15 10:16 AM
lakefr
Training & Nutrition
4
12-14-14 07:47 PM
