Road flat with tubeless
Bikes: 2019 CAAD12, 2015 Specialized Sirrus Comp
Quoted: 562 Post(s)
Liked 64 Times
Got my first road flat with a tubeless tire this morning and got stranded. I couldn't pull one side of the tire off the rim so I could insert my spare tube. I'm running GP5000TL on Easton R90SL rims.
Is there a technique to insert a tube so I don't get stuck again?
Bikes: 2021 S-Works Turbo Creo SL, 2020 Specialized Roubaix Expert
Quoted: 762 Post(s)
Liked 4,035 Times
Tire levers?
Non omnino gravis
Quoted: 562 Post(s)
Liked 64 Times
I'm curious of a few things: how big was the puncture (to big for sealant, but small enough to plug?,) and what was the method attempted to get the tire loose? In my experience, even the tightest-fitting tire can still be popped loose and filled with a tube when necessary.
Non omnino gravis
Likes For DrIsotope:
Expired Member
Quoted: 3674 Post(s)
Liked 5,431 Times
Likes For jadocs:
Quoted: 8280 Post(s)
Liked 9,038 Times
It has to come off somehow. Break the bead all the way around and push it to the center to allow you to peel it off.
Likes For big john:
Optically Corrected
Quoted: 562 Post(s)
Liked 64 Times
How well do plugs work on road tires, particularly when the hole is small?
Yes, plugs. Saved me from getting stranded (or having to put in a tube, which I do carry along with boots) last week. I’ve since done another 140 or so miles on the tire since plugging it. I use DynaPlug, there are a few varieties. I’m intrigued by the newly announced plans from Stans that supposedly react with latex sealant to form a more permanent bond with the tire. Are these available yet? My local LBS guy said they were not when I spoke with him a couple weeks ago.
Expired Member
Liked 5,431 Times
Quoted: 562 Post(s)
Liked 64 Times
I was ridding in the rain so it was difficult to tell, but there was some sealant near the valve. When I dropped the wheel off at my LBS later today, we could not easily locate the location.
Quoted: 20810 Post(s)
Liked 9,456 Times
What sealant were you using?
Only once have I experienced a puncture that was too big to be permanently sealed by the sealant alone and yet small enough that it didn't total the tire - it was about a 1/4" (5mm) slit. I tried some bacon strips, but they kept getting pushed out at 80psi. Maybe one of those strips with the metal barb would have held. Anyway, I eventually patched it internally. (And, in fairness, this cut happened somewhere on an 80-mile ride and it held well enough that I didn't notice it until just before the next ride, a couple days later.)
Non omnino gravis
I haven't tried this with road tires, but I have unseated tight MTB tubeless tires with the heel of my shoe. Place your heel on the tire as close as you can against the rim then pull up on the wheel. I have only done this with standard walking shoes.
Quoted: 18883 Post(s)
Liked 10,646 Times
The plug itself is metal, right? Is that ok on carbon rims?
Quoted: 173 Post(s)
Liked 57 Times
It's metal. I have a dynaplug kit, but I have yet to use it. I guess you should take the tire off when you get home and trim away the plug. A bit of a headache/annoyance, but that's the price you pay for going tubeless
Quoted: 942 Post(s)
Liked 527 Times
The DynaPlug end that goes in the tire has a brass end to prevent the plug from being pushed out by the pressure and centrifugal force of the tire as mentioned above (bacon strips).
Quoted: 18376 Post(s)
Liked 4,511 Times
My biggest problem with a tubeless flat was getting the replacement tube installed. Boy was it tight. At the time, I had 1 tubeless, and 1 tube tire, and ended up swapping tires to an easier to mount rim.
