Dumond Tech lube has impressed me
Old 08-07-19, 12:23 PM
TiHabanero
Quoted: 1745 Post(s)
Liked 1,370 Times in 719 Posts
Using Dumond Tech lube on my chain and have one 350 miles without need to relube, although I will be doing so in a few days as part of regular maintenance window. I also mixed a small amount with some Phil Wood grease to lube he jockey wheels. Very impressed with the product.
TiHabanero is offline
Old 08-07-19, 12:31 PM
jimincalif
Bikes: '96 Trek 850, '08 Specialized Roubaix Comp, '18 Niner RLT RDO
Quoted: 569 Post(s)
Liked 123 Times in 83 Posts
Are you using original or lite? I've been using the lite for a few years, it seems to work really well. Outlasts others that I've tried and get good chain life.
jimincalif is offline
Old 08-07-19, 04:16 PM
TiHabanero
Using Lite. Never used a lube that has performed this well. Even waxing the chain is not nearly as good as this. Smoother, quieter, and very long lasting.
Old 08-07-19, 05:05 PM
DrIsotope
Non omnino gravis
DrIsotope's Avatar
Quoted: 4905 Post(s)
Liked 1,731 Times in 958 Posts
My homebrew hot wax blend lasts 500+ miles between dips. And nothing ever need be cleaned.
DrIsotope is offline
Likes For DrIsotope:
Old 08-07-19, 06:42 PM
ct-vt-trekker
Bikes: 2024 Specialized Tarmac SL8Pro, 2022 Specialized Epic Evo, 2021 Framed Alaskan Fatbike,2019 Trek Emonda SL6 Pro, 2018 Trek Stache 9.7, 2013 Specialized Roubaix SL4 Expert, 2009 Ritchey Breakaway Cross, 2016 Lynskey ProCross, 2008 Trek T1000 Tandem,
Quoted: 18 Post(s)
Liked 5 Times in 3 Posts
I've been using Dumond Tech Lite for years, great stuff. I never have to clean my chains as it cleans and lubes at the same time. I put it on every 200-300 miles or so, a small amount on each link then wipe all excess off.
A local bike shop owner once told me "I should stop selling it, it's so good I'm sure I'd sell more parts iif nobody used it."
ct-vt-trekker is offline
Old 08-08-19, 07:38 AM
jadocs
jadocs's Avatar
Quoted: 942 Post(s)
Liked 527 Times in 349 Posts
I use the Lite as well.
jadocs is offline
Old 08-08-19, 10:22 AM
phughes
phughes's Avatar
Quoted: 1034 Post(s)
Liked 1,290 Times in 743 Posts
Oh sweet, a chain lube thread.
phughes is offline
Old 08-08-19, 01:03 PM
San Rensho
Quoted: 383 Post(s)
Liked 133 Times in 91 Posts
Only dessicated Sperm whale oil can be used on bicycle chains! But its dicey, because you have to go on the dark web to source it.
San Rensho is offline
Old 08-08-19, 07:41 PM
phughes
phughes's Avatar
Exactly. This has been determined a long time ago.
phughes is offline
Old 08-09-19, 01:45 PM
TiHabanero
Just did a tune up on the bike last night and cleaned/lubed the drive train. Truly is amazing how well this stuff works, especially when fresh. If you have not tried it, do so and I believe you will agree. Be certain to thoroughly clean the chain and sprockets to get optimum results.
Old 08-09-19, 08:25 PM
randallr
Bikes: 2017 Gunnar CrossHairs Rohloff, 2022 Detroit Bikes Cortello
Quoted: 132 Post(s)
Liked 155 Times in 89 Posts
Yep, I like Dumond Tech, too. I mix the Lite and Regular, 2/3 light to 1/3 regular.
randallr is offline
Old 08-09-19, 09:08 PM
TXBDan
Bikes: Trek Fuel EX, Trek Checkpoint
Quoted: 41 Post(s)
Liked 18 Times in 15 Posts
Any comparisons with Rock n Roll Gold? That's what i use, but only because the LBS said it was good.
TXBDan is offline
Tombaatar
General Cycling Discussion
78
09-27-17 12:30 PM
rangerdavid
Road Cycling
14
03-17-13 07:08 PM
techman
Bicycle Mechanics
3
06-14-11 07:17 PM
lohump
Bicycle Mechanics
12
10-18-10 03:18 PM
jasonball
Bicycle Mechanics
8
10-06-10 04:13 PM
