Quarantine shop cleaning/organizing challenge
Old 03-29-20, 05:30 PM
  #76
nlerner
Quoted: 1480 Post(s)
Liked 537 Times in 317 Posts
I did a bit of organizing in the basement shop just now, mostly boxing up a couple of sets of parts for upcoming projects and clearing them off of my main work space. The wheel grotto is kind of a hopeless cause as I inherited lots of various and sundry wheels from a bike friend who just moved:
The main workspace is pretty organized. I essentially have about 800 sq. ft. play with. My table saw is the primary surface, and three of those bikes hanging to the left, I’m storing for my friend:
This pano shot is an attempt to show pretty much the bulk of the main area. Off to the left is another bench with a vise, and a bunch of storage areas are off to the right (including the wheel grotto).
nlerner is online now
Likes For nlerner:
Old 03-29-20, 06:03 PM
  #77
gugie
Dilberteur at large
gugie's Avatar
Bikes: It's complicated.
Quoted: 2701 Post(s)
Liked 627 Times in 356 Posts
That's the cleanest than I've ever seen your man cave!
So, you've got three zero bikes down there for a friend?
gugie is offline
Likes For gugie:
Old 03-29-20, 06:41 PM
  #78
nlerner
Yup, plus there'll all my size!
Likes For nlerner:
Old 03-29-20, 11:52 PM
  #79
droppedandlost
small ring
droppedandlost's Avatar
Bikes: 531st, Tange 2, Gilco, SLX/SPX
Quoted: 195 Post(s)
Liked 120 Times in 71 Posts
droppedandlost is offline
Likes For droppedandlost:
Old 04-04-20, 12:58 PM
  #80
USAZorro
Señor Member
USAZorro's Avatar
Quoted: 875 Post(s)
Liked 162 Times in 116 Posts
First, an orientation. This is the layout of the lower level of the house. The bike areas are in gray to the lower left,
Here is my "before" state - taken about 10 days ago. I have space, but tool organization in particular is a deficit. Shown from the entry door, counter-clockwise.
I have gotten a start by putting up shelves between some of the studs to the left and right (not shown) of the door. Have done a bit of this in the adjoining area as well..
There's a separate "room" behind the shelves. Not going to be part of this event, but there will be paneling separating the spaces. The spaces will eventually get a panel ceiling and possibly another couple light outlets. The room behind will be storage/display, with a 4 x 3 array of angled bicycles along the partition wall, and additional storage for approximately 9 bikes under the stairs. That probably won't get completed until 2022 or 2023.
The space has a mix of general "shop" items, bike parts, bike tools, and bike projects. Bikes/frames (r-l) here are a 40's or 50's Robin Hood (black frame), a 1970 Raleigh Record (blue frame), a 1970-ish Carlton Corsa (green), a 1978-ish c-itoh (the white frame depicted behind the Corsa - that I got for $10.00 mainly for the tires, but which will be going on the trainer), and the 1973 RRA, which is wearing the swallow-ish saddle that I got from rhm. Getting that one on the road is one of my next ambitions).
This gives a better sense of the size of the space. I had already purchased pegboard, which I will be mounting above the work bench that's at the far end. Also seen in the picture are my wife's 1981 Miyata (on the stand for bar wrapping, cabling and adjustments), her 1962 Dunelt 3-speed which is barely visible behind it, a 5-speed 1970-ish Raleigh Sports atop the chest, and the 1949 Clubman which is due some FW adjustments and eventual brake caliper replacement.
There's a whit Mk I Raleigh Professional that's behind the Clubman. I really should move it to the other space, since all it needs is some air in the tires. There's a rolling bench that has a small planer, vise, and grinder on it (as well as other stuff that doesn't really have a home), and finally, my late uncle's old Superbe - which also needs a lot of care.
and the final corner of the shop, which is truly languishing.
I do have one small success to report though. I have no aspiration to ever take this bicycle on the road, because it's too large, certainly would handle like a pig, and weighs a ton, but until I come across a suitable mixte, the c-itoh has a home on the trainer. As an added bonus, I found a use for one set of crusty, steel 27" wheels, and a passable set of tires that had been lying around and adding to the clutter. I promise to be careful to not get that brake cable caught in the front wheel on a blazing descent.
USAZorro is offline
Old 04-06-20, 04:49 PM
  #81
tincup
tincup's Avatar
Liked 4 Times in 3 Posts
quarantine got me diving headfirst into my first vintage bike rebuild
tincup is offline
Likes For tincup:
Old 04-08-20, 10:10 PM
  #82
gaucho777
gaucho777's Avatar
Bikes: '72 Cilo Pacer, '72 Peugeot PX10, '73 Speedwell Ti, '74 Nishiki Competition, '74 Peugeot UE-8, '85 De Rosa Pro, '86 Look Equipe 753, '86 Look KG86, '89 Parkpre Team, '90 Parkpre Team MTB, '90 Merlin
Quoted: 471 Post(s)
Liked 158 Times in 77 Posts
This challenge came at an opportune time. My garage was exceptionally cluttered and in disarray a few days ago. Here are a couple before pics and a couple in progress pics.
Before:
The workbench:
Bike wall:
And so it begins...I sorted my small bits & bolts container. It seemed like each drawer had a little bit of everything.
That's a lot of extra wheels & rims:
gaucho777 is offline
Old 04-09-20, 08:43 AM
  #83
mkeller234
Rustbelt Rider
mkeller234's Avatar
Quoted: 192 Post(s)
Liked 168 Times in 82 Posts
Originally Posted by JaccoW View Post
You Americans and your huge houses. SMH.
That room is bigger than my house. Are you sure you're not just trying to start your own public exhibition or museum?
I haven't travelled extensively outside of the continental US and Canada, so I would say I only know what I know. Last year I went to Cambridge UK for work and was shocked at the tiny bicycle shops that I found. They were roughly the size of a medium sized bedroom and STUFFED to the gills!
After leaving the UK, I did get a bit of an appreciation that Americans are spoiled with our space... but I was also happy to go back to the extra room! I like/hate the TV show house hunters, but the International one is funny. It always has a couple saying "I'm looking for 3 bedrooms, 2 bathrooms, located in the city center of Dusseldorf.... my budget is $1,500". Nothing but sad blank stares coming from their agent.
These are a couple of the ones I went to. I walked into Greg's, saw absolute chaos, and left about 5 minutes later.
mkeller234 is offline
Likes For mkeller234:
Old 04-09-20, 03:33 PM
  #84
gaucho777
gaucho777's Avatar
Quoted: 471 Post(s)
See a couple posts above for the Before photos. This is about as clean as it's going to get for now. Drum roll, please....the After photos:
Likes For gaucho777:
Old 04-09-20, 05:13 PM
  #85
billnuke1
billnuke1's Avatar
Bikes: Not nearly as many as before...
Quoted: 179 Post(s)
Liked 163 Times in 115 Posts
Looks great! That bench calls out for a bench mount stand...you pull
the clamp out when the stand is not being used...
Don’t know why the picture is sideways...
billnuke1 is offline
Old 04-09-20, 05:20 PM
  #86
billnuke1
billnuke1's Avatar
Quoted: 179 Post(s)
You can also find 90* mounts, too...
Old 04-09-20, 05:58 PM
  #87
repechage
Quoted: 1347 Post(s)
Liked 316 Times in 252 Posts
Originally Posted by bark_eater View Post
I salvaged 20 sqft of floor space, and this white elephant swung down from the rafters. Well intentioned exorbitant gift from last year for me and the boy. He's stuck home from first grade and has out grown the trailer, so the time is now...
Next on the list is another 32 sqft under the plywood storage bench.
I could post what my front room looks like but my wife would accuse me of extortion. but that middle image is a similar theme to it.
repechage is offline
Old 04-09-20, 06:06 PM
  #88
bark_eater
Quoted: 295 Post(s)
Liked 91 Times in 61 Posts
Its gotten worse since we started doing a 3 day quarantine of all deliveries. The clean spot has gotten use with a cot as a hide out. I, unlike everyone else in our full house, am not an insomniac.
bark_eater is offline
Old 04-10-20, 11:02 AM
  #89
gugie
Dilberteur at large
gugie's Avatar
Looks great! I've got a project to finish for bwilli88 , as soon as it's done I'm digging into l'Atelier.
gugie is offline
Old 04-21-20, 03:04 PM
  #90
billnuke1
billnuke1's Avatar
Quoted: 179 Post(s)
And we are back...just need a couple’a dry days...the outside 4’x8’ box I built last summer is almost empty...great for excess tools, wheels, etc ...maybe a little less sea breeze, too... anything under a steady 15-20mph with 45mph+ gusts...
Old 04-21-20, 09:13 PM
  #91
Slightspeed
Slightspeed's Avatar
Quoted: 702 Post(s)
Liked 574 Times in 324 Posts
I so need to get out there and get organized. 44 years in the same house, and 2 cars, 8 bikes and laundry still fit in a two car garage ... sort of. To get to anything I need, I need to move at least two or three others. The quarantine would be a great time to take care of this, except the weather is so nice out. Approaching 90+ degrees Friday. Too hot to work in the garage, just right for riding. 😎 Here's my "Before" picture. Don't know when I can post the "After". I've added two more bikes since this picture was taken.
There is a work bench back there, behind three or four bikes.
Slightspeed is offline
Old 06-01-20, 11:17 AM
  #92
billnuke1
billnuke1's Avatar
Quoted: 179 Post(s)
Still moving forward...
Taaaaa...
Daaaa...
Big steps this weekend...utilizing an old medicine cabinet and small book case...
Old 06-01-20, 05:54 PM
  #93
gugie
Dilberteur at large
gugie's Avatar
Well, I patched about 20 tubes, rolled and ready for use. The nice thing about patching that many tubes is one can pump them up, let them sit overnight, and the next day see if the patch really held. My yield was about 85%
I stripped down 40 MAFAC RAID brakes, cleaned them up a bit, and organized the individual parts.
Believe it or not, this is a lot cleaner and organized than a month ago.
The North 40, not so much.
gugie is offline
Old 06-01-20, 06:19 PM
  #94
nlerner
^ But where’s the Gran(d) Sport(s) corner?
Old 06-01-20, 06:58 PM
  #95
cudak888
www.theheadbadge.com
cudak888's Avatar
Quoted: 892 Post(s)
Liked 681 Times in 449 Posts
Been on this for the last three months of weekends now. Cleaned up the workshop, then cleaned up the right half of the shed to get the Bike Share Museum bikes off the ground and hanging as they should.
Still need to clean some more to to make room for the '80 Sports and pair of Raleigh 20's, but I'm not going to attempt to hang them before adding some collar ties to the rafters. The dockless machines are not light like the Paramount or the two Raleigh Professionals. The Rudge DL1 also comes close to scraping the floor - it's big machine!
-Kurt
cudak888 is offline
Old 06-01-20, 08:43 PM
  #96
gugie
Dilberteur at large
gugie's Avatar
I need a bigger corner.
BTW, I count 3 in that picture alone, and 2 more can be seen in the other pictures.
The other 17 are scattered about.
gugie is offline
Old 06-01-20, 09:40 PM
  #97
oddjob2
Still learning
oddjob2's Avatar
Bikes: A garage full
Quoted: 833 Post(s)
Liked 31 Times in 20 Posts
Selling 24 bikes since the beginning of April allowed me to drop a garage sized mini storage rental, clear bikes out of another garage, and working on reclaiming yet another garage by the end of June. The local bike shortage has made a great market for selling. Only 40 more to sell! The last goal is reducing my still large personal fleet. But tell me, why do I have 21 Brooks, VO and Ideale saddles?
oddjob2 is offline
Likes For oddjob2:
Old 06-01-20, 09:46 PM
  #98
scozim
Ellensburg, WA
scozim's Avatar
Bikes: See my signature
Quoted: 207 Post(s)
Liked 69 Times in 31 Posts
Gotta finish the shop first.
1984 Gitane Sprint; 1984 Gitane Tour de France; 1982 Trek 610; 1968 Peugeot PL8; 1982 Nishiki Marina 12; 1972 Peugeot PX-10; 1984 Peugeot PSV; 1993 Trek 950 mtb; 1997 Klein Pulse Comp mtb; 1989 Peugeot Limestone hybrid (for touring); 1975 Gitane Olympic; 1983 Vitus 979; 1989 Spectrum Titanium:
scozim is offline
Likes For scozim:
Old 06-02-20, 11:59 AM
  #99
gugie
Dilberteur at large
gugie's Avatar
Nice!
gugie is offline
