Miyata 914 I'm not sure what to do with it.
Thanks for that. This would have me sitting more upright and more of my weight where I want it on the seat? Maybe I should just try a stem first and replace the bars also if I'm still not happy.
Quoted: 1088 Post(s)
Liked 1,205 Times
https://www.bikeforums.net/bicycle-m...em-length.html
https://www.bikeforums.net/road-cycl...ngth-also.html
There are links to useful tools and use of the key terminology when talking about stem specifics.
Quoted: 170 Post(s)
Liked 264 Times
https://www.benscycle.com/nitto-ntc-...ng_870/product
Beautiful bike, but looks pretty stretched out as is. If I was in this sort of "position" and looking for comfort, I'd pick up a Nitto 70mm deluxe stem (one of my favorites in finish and function, linked below) along with a Thomson zero setback post and Brooks B17 saddle - plus a compact bar, as recommended by @RiddleOfSteel. And, if your 914 will accept them, 32mm GP5000s. Some or all of these things would transform the fit and feel, no question.
ambulatory senior
Quoted: 1955 Post(s)
Liked 3,661 Times
You wont want to go this far, but just so you know, this started out as an 81 912.
Good looking bike. I agree I don't want to go quite that far.
ambulatory senior
Liked 3,661 Times
Likes For 52telecaster:
Master Parts Rearranger
Quoted: 1556 Post(s)
Liked 2,024 Times
Shorter stem (100mm) and compact-profile bars on one of my bikes. I ain't ridin' no 130, that's for sure. It's wonderful to steer and when climbing out of the saddle, not anything I have to worry about. A super long setup would have me wagging and dipping the bars as I rocked back and forth out of the saddle.
Quoted: 500 Post(s)
Liked 466 Times
My ‘79 912, owned since new, never felt quite right, feeling more “on” than “ in” the bike, until I found this seat-post with lots of setback. I’m quite leggy, comfortable on 62-63cm frames while only 6’0” tall. And FWIW, I’d say that you’d be more likely to find a comfortable fit on a bigger frame, judging by your seatpost extension.
And here’s the overall bike, which is now very comfortable.The front bag and rack are part of an extensive front end modification to enable front loads. That’s a very different conversation, but comfort wasn’t affected.
Quoted: 500 Post(s)
Liked 466 Times
Sorry, duplicate post, edited away.
But it’s worth noting as long as I’m here, that good friend RiddleOfSteel with the lovely black Paramount above, is 6’5” tall, 5” more than me, and yet our saddle heights and frame size preferences are very similar. We occasionally do a ride where we ride each other’s bikes. My time on his Paramount was delightful. His cockpit is a bit longer and bars are lower, but certainly fine for an hour or two when we swap.
So I rode my Scott Sub20 today. Really noticed the difference in comfort compared to the Miyata. . I am stretched out high and wide on the Scott. I like that. I ride with my hands out far on the ergo bar of the Scott I would really like to get the same fit and feel on the Nine 14 as the Scott without making the bike look silly. How about a riser drop bar? Ergo bars or bullhorns on the Nine 14? What would I use as a stem in that case?
Sunshine
Quoted: 10955 Post(s)
Liked 7,484 Times
https://www.benscycle.com/nitto-dyna...c2_870/product
Plus
https://www.somafab.com/archives/product/highway-1-bar
Equals shorter reach and a bit more upright ride.
Wider tires won't make the poor fit feel better.
Plus
Quoted: 1324 Post(s)
Liked 927 Times
Something I like when playing around with quill stem height and handlebar reach is an adjustable stem. That allows me to change height and to certain degree, reach as well of the stem.
I can set the stem to a certain position, ride the bike for a few days, then change either the height or the reach. I do that until I find the combination that works best for me. Then if I want to I'll by a quill stem that matches those measurements and angles. Most times I just leave the adjustable stem on.
Cheers
Cheers
Likes For Miele Man:
Thanks for all the suggestions. I will probably go with the Nitto Dynamic 2 Quill Stem and Soma Highway One bar.Hope I don't feel too compact with this setup.. As far as the bar is concerned is there really any noticeable difference between a 40mm and 42mm or 44mm bar? What size should I get? Any suggestions for a good bar tape?
Have been searching and I'm really liking the look of this setup. Anyone know where I could find a stem similar to that one? Are those dirt drop bars?
Sunshine
Liked 7,484 Times
https://velo-orange.com/collections/...-bar-handlebar
That pic is of the two product above. You need a threadless steerer for that stem.
Liked 1,205 Times
Here is one idea, as a start:
Nitto Dirt Drop with 90mm height, 100mm reach, 26.0 clamp: https://www.benscycle.com/Nitto-Dirt...SABEgIzd_D_BwE
Dajia shallow bars 46cm wide, 26.0 clamp diameter: https://velo-orange.com/collections/...nt=50649893383
I am not sure if this is the ideal set up for you, but it's just one example of how you can mimic the characteristics you might like in a pictured setup.
I appreciate all the suggestions. Almost too many choices. I ordered a taller stem with a shorter reach. I will try that with the current handlebars and see if that helps. If I find that setup more comfortable I will then consider also changing the handle bars.
Never knew there were so many stems and bars to choose from. I'm hesitant to purchase anything higher quality as I don't want to "invest" money into the bike if I don't know if I will be happy with the end result. My understanding is that if I purchase a stem and/or handlebars and I install them the bike I cannot return the items. They would probably have marks or scratches and cannot be returned to the seller. That is understandable. Is that the experience of those on this forum? Once you install the parts you are stuck with them? I guess I could resell the items as used on Ebay if they don't work out.
Liked 1,205 Times
In the end, you're investing in your tactile knowledge of how the bike feels with different components, so it is worthwhile to spend a little time with a measuring tape to see where you may want to trim or add some length/width, and then spend some time researching before you buy. That way, you start from more-than-zero and can spend some time acclimating to a new setup and make a decision. Also, if you buy parts of decent quality, you can always use them on a different bike if you decide this one does not fit.
EDIT: Your approach of trying your current bars with a new stem is a good incremental way to do this. You may find that it transforms the way the bike feels.
Yes, tinkering results in a lot of reselling, but only if you tinker with a lot of different things. Buying and returning isn't really fair to the retailer (unless you genuinely make a mistake and buy something you did not know was incompatible.)
Likes For Rdytoroll:
Quoted: 500 Post(s)
Liked 466 Times
Thanks I will consider doing that. Yes I agree the members of this forum has been very friendly and helpful, I appreciate that very much.
Hoards Thumbshifters
Bikes: '23 Black Mtn MC, '87 Bruce Gordon Chinook, '08 Jamis Aurora, '86 Trek 560, '97 Mongoose Rockadile, & '91 Trek 750
Quoted: 246 Post(s)
Liked 334 Times
Couple things that may help. Don't wrap your bar after swapping components initially until you have things dialed in. I would highly suggest a 80mm stem length with extra long quill like a Nitto technomic. Also would suggest a Nitto Noodle drop bar in a 42-46 cm width range. That added width is a very nice feel on the back. Good luck on the hunting. Again, that road frame should be a nice rider so when you find a bar fit you like it should ride wonderfully. Not sure of the tires you have on there either but someone 25c to 28c width will add to the comfort.
Quoted: 413 Post(s)
Liked 109 Times
I don’t think it’s too small. Looking at seat angles on both bike It seems as if there’s a fit issue, both seats are probably too high.
ive never been a fan of trying to make a bike into something it isn’t. 916 has full racing geometry..... you can do whatever to the bars/stem but at the end of the day it’s still a racing bike.
tip: set your seat heat
1. Level seat. Place a straight on seat and level it
2. Take your shoes off
3. Hop on bike and hold yourself up
4. Place bare heel on center of pedal and pedal backwards
raise/lower seat until you heel just barely makes contact with pedal.
5. Do NOT rock your hips.
6. With shoes on and ball of foot over center of pedal you’ll proper knee bend. Or it’ll be very very close.
