Removing paint...chrome frame?
Bikes: 1982 Miele roadie, 1990s Avp-Pro hybrid
I was wondering how well paint stripper works for removing paint because I want to take the paint of my steel bianchi and clearcoat it to have a bare/chrome frame. Is this realistic? I also want to remove rust without scratching the metal, would polish or CLR work best for this?
Bikes: Eddy Merckx Corsa Extra, Basso Loto, Pinarello Stelvio, Redline Cyclocross
Quoted: 336 Post(s)
Usually the chrome is only polished where it would show. But gel paint stripper will take the paint off quite effectively.
Originally Posted by Granny
Bare and chrome are two very different things.
This cant be stated strongly enough!
If you think you are going to strip paint and find chrome, you are waaaayyyyyyy wrong!
The amount of time you would have to spend polishing the metal just to make it shine would kill you. Sending it to a chromer might work. Lots of them available on the internet.
Former Hoarder
WOW!! Almost seems like those pics should have been posted on April 1st!!
Is it common for a manufacturer to spend the money to chrome a frame, then paint of top of it?
after further review, I cant even tell what color it is in the BEFORE picture? Looks like the top might be painted, but the bottom chrome?
Former Hoarder
The Pinarello was fully chromed, then covered with a clear black paint - most likely a powdercoat. The goal was to get the sheen of the chrome to shine through. Painting over chrome was fairly common for some Italian framebuilders back in the 80's and maybe longer.
Here's a closeup of before - look around the edges of the lug where the paint was peeling.
Location: Perth, Australia and sometimes Penang Malaysia
Bikes: Litespeed L1r, Litespeed Ghisallo 07, TCR Advanced Team SL 0 ISP, Giant TCR Advanced SL, Giant TCR Advanced Team - T-Mobile, Giant Propel Advanced SL
Bottom line is that the frame was completely chrome and this is why it looks good with the paint off.
Bare steel on the other hand might look horrible, it would depend on how carefully the welds were done etc..
Nice work, 55/Rad! I am considering doing this to a similar frame.
Interesting. Does anyone know what's under the paint of a Kilo TT Pro?
Is it chrome? Or would stripping the frame leave chrome tips and raw steel where the paint used to be?
Bikes: 1987 Pinarello Montello, 1996 Litespeed Classic, 1996 Colnago Master Light, 1997 Litespeed Ultimate, 2006 Opera Leonardo FP, 2006 Pinarello Paris FP, 1984 Pinarello Record, 89-ish Cornelo Profilo
Quoted: 148 Post(s)
Liked 119 Times
This thread shows my test on an early 80s Pinarello Record and the gel material I used: https://www.bikeforums.net/classic-v...r-project.html
And, case in point for Pinarello labels on a later 80s Montello:
For removing rust from chrome, I use a ball of tin-foil and WD_40. Just wipe gently and be amazed.
