2011 Trek HiFi Deluxe replacement bearing kit
I have a 2011 Trek HiFi Deluxe that's developed a bit of play (slight movement is felt when you pull up on the saddle) in (what I believe is) the top tube pivot bearing.
Below is one online dealer I could find with a replacement kit, but was wondering if anyone out there knows where I might be able to find a high-end replacement kit (assuming one exists)? Thanks ahead of time for any leads or suggestions.
shockcraft.co.nz/bearings-bushings/suspension-bearings/suspension-bearing-kits/trek-bearing-kits
Quoted: 453 Post(s)
Liked 104 Times
Pull the bearing, they will have the spec printed on them, or you can measure them, and order from a LBS/bearing supply place.
Or google it, and you get this for the specs 2011 Trek HiFi Deluxe replacement bearing kit- Mtbr.com
