Dent in my Big Block, what would be best replacement?
Old 07-24-18, 07:32 PM
TourDeHood
TourDeHood's Avatar
Bikes: Surly Midnight Special, All-City Big Block, Surly Karate Monkey (sold), Kona Jake(gone)
Quoted: 15 Post(s)
Getting mixed messages on if, and when I need to replace this frame. Attempted bike theft left this dent in the top tube. As a Super Clyde (6'3" 310) im a little iffy on the long-term reliability.
So, if I decide to sell/replace this, what would be an on par replacement frameset? Love the Mash Steel (mainly because of the ability to run larger tires). I prefer steel and the ability to run a front brake. ​​​​​​​
TourDeHood is offline
Old 07-24-18, 09:28 PM
TejanoTrackie
Veteran Racer
TejanoTrackie's Avatar
Bikes: 32 frames + 80 wheels
Quoted: 1331 Post(s)
Liked 763 Times in 431 Posts
As long as the frame is not out of alignment I’d not worry about it and keep it. The top tube is not under a lot of stress, which is why it is usually smaller than the downtube that carries most of the load. Steel is very ductile, so there is little chance of the top tube cracking or failing catastrophically. So unless you can’t live with the ugliness of the damage, just keep riding it.
What, Me Worry? - Alfred E. Neuman
Originally Posted by Dcv
I'd like to think i have as much money as brains.
I see the light at the end of the tunnel, but the tunnel keeps getting longer - me
TejanoTrackie is offline
Old 07-24-18, 09:34 PM
Broctoon
Super-duper Genius
Broctoon's Avatar
Quoted: 768 Post(s)
Liked 984 Times in 508 Posts
As to what would be a good replacement, I'm no expert, but I can throw out a few random ideas. If you meant to ask about the MASH Work, they seem to be getting scarce on the new market since production ended. Retrogression recently had a few remaining, but it appears they're now sold out. You might find a used one. There's now a Vigorelli in steel. Or for a lot less money there's the Surly Steamroller, which is probably at least as strong.
As to if/when you need to replace the damaged frame, I'd say it may still be serviceable for a long time. Can't tell for sure, but that dent looks like it has no sharp edges or creases. These are dangerous because they invite cracks. A smooth, rounded dent like you have is mainly troublesome only because it's unsightly. At any rate, you can continue riding and just keep an eye on it. If a crack appears, I'd stop riding. Chances are, it won't suddenly have a catastrophic failure, even with your mass on it.
Broctoon is offline
Old 07-25-18, 06:09 AM
nightfly
Quoted: 89 Post(s)
Liked 15 Times in 10 Posts
If you like this one, what about another Big Block?
Otherewise the Mash Steel (the new one, not the Cinelli Mash Work), looks pretty nice.
https://shop.mashsf.com/mash-steel-f...ver-smoke.html
nightfly is offline
Old 07-25-18, 07:07 PM
veganbikes
Clark W. Griswold
Quoted: 4323 Post(s)
Liked 3,945 Times in 2,638 Posts
I am a fan of the Cinelli Mash Work which they have re-kajiggered after MASH stopped their partnership and are now doing the same stuff but with Columbus which is owned by Cinelli (or the other way around, I cannot remember) It is a fun bike.
I would also consider the Surly Steamroller or CrossCheck (depending on your brake wants or needs) or a Nature Boy (you can get it with discs and 853 tubing as well).
veganbikes is offline
Old 07-25-18, 08:22 PM
belacqua
Quoted: 102 Post(s)
Liked 50 Times in 35 Posts
That dent looks like it might respond well to being rolled out with some frame blocks
belacqua is offline
Old 07-25-18, 09:04 PM
johnnytheboy
johnnytheboy's Avatar
Quoted: 443 Post(s)
Liked 12 Times in 7 Posts
throw it in the garbage and get a new big block frame. how much is your brain worth? or teeth?
johnnytheboy is offline
Old 08-01-18, 01:50 PM
rustystrings61
Quoted: 823 Post(s)
Liked 1,392 Times in 694 Posts
I'm with belacqua, I think you should see what happens when you roll it out with some frame blocks. While I am no Clyde, I have ridden a bunch of miles on a 531C Mercian with what started out as a similar dent. It's still ugly but it hasn't failed and I don't think it's going to. Steel is remarkably resilient material.
rustystrings61 is offline
Old 08-01-18, 01:57 PM
TimothyH
- Soli Deo Gloria -
Quoted: 6844 Post(s)
Liked 736 Times in 469 Posts
Aren't you a welder? Or was that someone else here?
I mean, I presume a welder understands metal better than most of the rest of us. I would value the opinion of such a person, or a frame builder for that matter, and wonder if there is a reason why you recommend tossing this.
Not trying to challenge. Sincerely interested and willing to learn from anyone with expertise.
-Tim-
TimothyH is offline
Old 08-01-18, 02:00 PM
johnnytheboy
Quoted: 443 Post(s)
not a welder. that’s a nasty “dent” bordering on a crease. i personally wouldn’t risk it. i’d rather spend $500 on a new frame than $500 on an ER co-pay.
Old 08-01-18, 02:02 PM
johnnytheboy
Quoted: 443 Post(s)
that tube is straight up deformed.
Old 08-01-18, 09:27 PM
Broctoon
Super-duper Genius
Broctoon's Avatar
Quoted: 768 Post(s)
Maybe you're thinking of @hairnet.
A frame builder who is pretty active here is @JohnDThompson.
Broctoon is offline
Old 08-02-18, 01:01 AM
hairnet
Fresh Garbage
hairnet's Avatar
Bikes: N+1
Quoted: 352 Post(s)
Liked 26 Times in 18 Posts
I'm with you there, that looks like a sharp impact. I can sympathize with OP, as a large Clyde myself, I wouldn't have much confidence in that frame outside of really chill easy pub crawl riding.
Hey, OP! Just cut out that section and have a cup holder welded in it's place
hairnet is offline
Old 08-02-18, 07:57 AM
TimothyH
- Soli Deo Gloria -
That's right. I was thinking of @hairnet.
TimothyH is offline
SteelFrameMane
Singlespeed & Fixed Gear
19
02-02-17 03:29 AM
67tony
Classic & Vintage
7
08-20-16 01:58 PM
az_andrew
8
01-09-13 10:20 AM
goatalope
Bicycle Mechanics
26
09-22-12 01:21 AM
monsterpile
Bicycle Mechanics
19
01-13-12 12:58 PM
