Flip Flop Hub vs. Standard Non-Drive
Bikes: Nashbar Race SIS, Spalding Road Step Through Single Speed, Kent Road Single Speed, 630 Cruiser, Fuji Odessa mountain bike
Quoted: 109 Post(s)
Anything in depth and technical on this? Wonder about potential balance benefits from a flip flop hub. But, with good equipment I think I can be happy with a standard non-drive side. Also, I think flip flop hubs may generally be longer, which may have drawbacks. I can make a wrong decision on this but would prefer not have that decision be a flip flop hub.
Super-duper Genius
Quoted: 768 Post(s)
Liked 984 Times
More than I even have time to address here.
Tremendous balance advantage, even better than what you get from a 2-bolt stem faceplate vs. 4-bolt.
Many of us have learned to settle for one, so long as it's good equipment.
Well, obviously.
Also goes without saying. Please update us when you've made your choice!
Now, in all seriousness, here's what you should do:
Make sure your bike frame has 120mm rear axle spacing (the Over-Locknut Dimension). Then, choose a track hub that you like and can afford. Simple as that! If you want to use a freewheel--with or without a fixed cog on the other side--get one with fixed/free threading, or with fixed/fixed (a freewheel will fit either). In fact, you can even get a single side fixed thread and put a freewheel on it. You won't need to buy a lock ring, but will need brakes. If you only want a fixed cog, you can get a single sided fixed, a fixed/free, or a fixed/fixed. Now, here's where it gets tricky. If you want two different fixed cogs, you need a fixed/fixed two-sided hub. If you get a two-sided, aka "flip-flop" and you only have one cog, that's okay--you don't have to put anything on the other side. That's all there is to it! You should fret more over the color of the hub than what's on the side you're not using... seriously.
Quoted: 4806 Post(s)
Liked 3,928 Times
I am not sure what you are asking with your question on "balance". Are you asking about dish or how the bike handles as you ride? I have many miles on both single fix gear wheels and fix-fix wheels. I cannot tell, either riding or maintenance-wise, the difference. Both have flanges much further apart and more symmetrical than any cassette geared bike so they build up strong, stiff laterally, reliable wheels, even with very light spokes. (The dish in a one-sided track hub is completely trivial.)
Ben
Ben
Liked 3,928 Times
Maybe but there is a rich history with the double sided. It allowed racers to ride their only only bike to the veldrome (or in England 80 years ago, the grass flat track), flip the wheel and race, then ride home. (You might be looking waaaaay better but you'd be lugging that 48-14 up the 2 mile hill to get home to your shower.)
Ben
Ben
- Soli Deo Gloria -
Quoted: 6844 Post(s)
Liked 736 Times
Flip flop will be better for Long Island.
You can run a high gear for flat rides from Manorville to Greenport and a lower gear for hilly rides from Shoreham to Port Jefferson to Huntington.
The rest of the issues mentioned are non-issues. Don't worry about it. There are no balance issues.
-Tim-
-Tim-
ThatsMyPurse
Singlespeed & Fixed Gear
5
08-20-11 07:19 PM
thecezar
19
07-23-11 04:53 PM
