Drops and dummy hoods
Bikes: Raleigh Technium(SS), Jamis Diablo
So I was riding a conversion fixed with chopped drops, the LBS did an excellent job at selling me a Steamroller. Well the stock is drop bars, so I have been digging the drops lately, but I miss the upright of the bulls. The brake is a flat bar brake, I have the urban assault ordered and on the way (bar end brake also). So this is my question, I am going to keep the drops to change it up every now and then, does anyone run a dummy hood on the left to match the right brake hood? Or is there some other trick I am missing? I would really dig the drops if I could get both hoods on, without it looking stupid.
lots of people run dummy hoods, some with levers, some with just the hood. Doesn't look stupid IMO, though some on this forum will surely hate. Does it get the job done? Yes, and that's all that really matters. I will probably be doing the same thing soon enough, as having multiple hand positions is really great.
don't try this at home.
Quoted: 973 Post(s)
Liked 511 Times
I drilled out the brake lever pivot for the right side brake, and took off the lever, and painted the aluminum bits black. I would try to pull the non-existent brake at times when the lever was still there.
out of shape
you can run just the hood, or get a stoker hood with a cut-off fang lever (no sharp pivot bits exposed), or keep the whole lever and connect it to a bell.
Live without dead time
I run a rear brake just for the simplicity of having something attached to the drop. I have yet to use it, but it keeps everything simple.
What I've seen that is really cool is that you can attach both levers to the same brake if you want. That's another option to consider if you wanted to keep the lever in the hood. Either way I strongly reccomend you keep the hoods as it provides alot of versatility
Bikes: Serotta Colorado III Track (Renyolds Ouzo Pro Aero Fork, Dura-Ace to Mavic CXP-14 wheels, Sugino crank, Thomson and 3T the rest), Steelman Cyclocross (Campy Record 10, Deda Newton & Thomson stuff)
I think the dummy hood thing looks fine:
https://velospace.org/node/16406
On the Tektro levers pictured you can just push out the pin that holds the lever on with a hammer and screw driver or something similar. I prefer drops and hoods to the bullhorn or just drops I've run in the past.
Bikes: '07 Pista, '09 Fantom Cross Uno, '8? Miyata, '67 Stingray, '0? Zoo mod trials, Tallbike, Chopper, '73 Schwinn Collegiate, '67 Triumph Chopper, '69 CB350, '58 BSA Spitfire, '73 CB450
Cool I was thinking the dummy would work. I like the bell idea attached to it...
Fixed-gear roadie
Bikes: 2008 Masi Speciale Fixed
I'm running a dummy lever on the right, or at least until I install a rear brake, which I'll probably do soon. I hate the way single hoods look, and I ride on the hoods all the time in pedestrian traffic around campus, so I wouldn't ever want to give that hand position up.
beatz down lo|seatz up hi
Bikes: A 2007 Trek 4300. 22.5", 1981 Trek 610 24" (61cm)
I saw someone rig up the extra lever to a bell once. I'd do that if I knew how.
Slow mechanic
Slow mechanic
Bikes: Specialized Allez (2007)
Put the hood on, the extra hand positions are well worth it. I did that on mine, it's just for winter training though so I don't really care how it looks. It would look decidedly cool with a bell attached though, I like that!
Ryker, thanks for the bike comments! The hoods were originally black, but I just got some gum ones for fun and to get a bit of a retro element to match the cranks, calling back to when that was the only choice. The idea was also to match them to some nice tires at some point, but gatorskins work better for fall/winter/spring riding. But, if I had the lever in place my bike would weight 15g more! Just kidding, I just kind of took it off because I could, I didn't want it just sitting there clicking around, and didn't have the parts to secure it (you can keep it still by setting it up with a short length of housing and cable, but then at the end of the housing attach a stopper to the cable so it can't be pulled at all, the lever will be solid).
My dad has a tandem from around the 80s (Rodriguez custom!) and the stoker bars have these little nub things that I haven't been able to find anywhere. It's not shaped like a brake lever, it's almost like a little bar end you attach where you would normally put the brake, and it's encased in rubber. Feels more like the end of a bullhorn bar than a big old brake lever while riding.
out of shape
i wish you could buy the CC/tektro levers with the gum hoods straight away. everywhere i've seen your options are black/black lever and black/silver lever.
Slow mechanic
To my eye, the "normal" mode of having two levers doesn't interrupt my brain whereas a single lever or a stoker lever or a hacked lever take a second to decode. My brain kind of just accepts dual levers and moves on to gawk at the important bits.
