Barcon Installation Questions...
Hi - I’m soon to be installing a pair of barcons (see pictures) and I have a couple of very basic questions. I’ve found threads dealing with cable routing but nothing to this level of potential dumbness.
- How do I access the bolt that causes the expanders to expand, thereby locking the shifter in the handlebar?
- Which way is up? When installed should tensioning the inner cable be done when pulling the shifter upward or pushing it downward?
Thanks!
Thanks!
Bikes: Raleigh Classic 15, 84; Miyata 912, 85; Miyata Ridge Runner SE, 85; Miyata 610, 86; Miyata 100M, 86; Miyata Valley Runner, 88; Miyata Triple Cross, 89; GT Karakoram, 90; Miyata Elevation 300, 91; Marinoni Touring, 95; Long Haul Trucker, 2013
Quoted: 159 Post(s)
Liked 133 Times
Here's a link to the installation manual:
https://www.ragandbone.ca/PDFs/suntou...ers-manual.pdf
Likes For John Nolan:
ambulatory senior
Quoted: 1955 Post(s)
Liked 3,661 Times
You're gonna love em.
52psi
Quoted: 790 Post(s)
Liked 802 Times
Always cool to see the original documentation. Thanks @John Nolan
Insane Bicycle Mechanic
Quoted: 802 Post(s)
Liked 703 Times
I agree that you will love them.
One piece of advise: the "locknut" on the screw that goes through the center of the shifter can come loose and disappear. Get used to snugging it down periodically.
Finding replacements is not impossible but they're pricey:
https://www.ebay.com/itm/Suntour-Bar...-/173822982487
Jeff Wills
Jeff Wills
Quoted: 1372 Post(s)
Liked 1,751 Times
This is the culprit and this one is original. Could not find a picture of one that I made...
Bikes: 1984 Miyata 310, 1986 Schwinn Sierra, 2011 Jamis Quest, 1980 Peugeot TH8 Tandem, 1992 Performance Parabola, 1987 Ross Mt. Hood, 1988 Schwinn LeTour, 1988 Trek 400T, 1981 Fuji S12-S LTD, 197? FW Evans
Quoted: 531 Post(s)
Liked 1,004 Times
In case you didn't catch the note on the installation sheet, turn the 6 mm wrench counter-clockwise to tighten the expander, and clockwise to loosen. This probably comes up more for people who are trying to remove them from old handlebars.
Quoted: 472 Post(s)
Liked 1,028 Times
I really like my barcons. I have them on my 1974 Crescent. Lovely ride.
Very timely for me. A set of the Suntour barcons arrived in the post today. Those installation instructions will make my life so much easier.
Many thanks
Many thanks
OP, keep in mind that tape then was assumed to be cotton. You'll have a hard time tucking modern padded tape into the end of the bar and still getting the barcons in. Fizik would probably be OK, just. I recall doing one with cork when it first came out BITD and it was a bear. You're better off wrapping upwards in the modern manner if using padded tape.
A good replacement for those locknuts can be made from the head of a pan head screw. Just cut the head off, drill and tap M4. +1 on the Loctite.
ambulatory senior
Liked 3,661 Times
Bikes: 1974 Sekai 2000 Special
Quoted: 11 Post(s)
anyone know the best adaptor to use to convert a suntour barcon set up to a downtube set up or a stem set up for a roadbike? Is it even worth it to keep the shifters or should I just buy new ones?
Just buy a set of Suntour Power shifters with downtube or stem band. They are essentially the same shifters and much less expensive.
Likes For due ruote:
Quoted: 85 Post(s)
Liked 74 Times
The lever body tends to rotate when you are snugging it down tight. I insert a long hex wrench in the hole in the lever body where the shift lever attaches to hold the lever body straight while tightening. Also, the small hex nuts that were used to hold reflectors on old pedals work fine ( but don't look as nice) as a replacement for the lock nut, providing you find the right size.
Quoted: 11 Post(s)
Thanks for all the advice! Think I'll clean up the Barcons and look to sell them.
Quoted: 802 Post(s)
Liked 703 Times
Here's an old thread about them: https://www.bikeforums.net/bicycle-m...g-shifter.html
Jeff Wills
Jeff Wills
