Titanium fixie fork, what are the pros and cons
Titanium fork on fixed gear, what are the pros and cons
I'mHey im trying to build my very first titanium bike and i am just curious if it is okay if i try using titanium fork
Quoted: 4802 Post(s)
Liked 3,922 Times
Titanium forks are not common. One thing I would be very careful about is that you know these forks were welded up by someone really good at welding titanium. A fork is a place where you really don't want to have a failure. (Trust me - I know first hand.)
The characteristics of titanium, if done right, should make a sweet fork. I haven't ridden one but have thought about it for years. The framebuilder who has done a lot of work for me has made a few. He and others have made ti forks as triangular trusses with tubes coming from the hub to the front of the stem. You lose stem adjustibilty, but what a light fork! You want a fork that is larger diameter than a steel fork if you stay conventional to get enough stiffness since the titanium is half as stiff as a material.
Ben
Ben
Anything but building it out of straight Ti tubing , IE tapered blade, will get Really Expensive ... You done well in the Stock Market?
