Origin of Crack in Downtube-BB Shell Joint
Quoted: 3361 Post(s)
Liked 3,638 Times
I've had this 1985 Schwinn Tempo for most of a year now.
When I got it, it had some pretty rough paint, so I had it stripped and powdercoated.
Before I installed all the components, I sprayed Corrosion-X inside of all frame tubes to help mitigate any current corrosion and prevent any from forming in the future. The great thing about this stuff is that it wicks everywhere and sticks tenaciously to the walls of the tubes.
I recently noticed some of this stuff weeping out of the downtube-BB shell joint, and decided to investigate further. I cleaned everything up, filed away the powdercoat around the suspected area, and noticed a crack right on the braze joint, maybe 1/6 the way around the downtube. I then took the bike out for a little spin around the block, really mashing hard and trying to make the frame flex a lot. I put it back on the stand, and this is what I found:
The black stuff you see is the Corrosion-X weeping out of the crack.
In your opinion, would this be more likely caused by a crack in the brazing, or a crack in the tubing itself?
I'm trying to weigh my repair options here. There is a framebuilder reasonably local to me that I would be willing to take this to if it's just a matter of re-flowing some brazing into the joint, but frankly this frame isn't worth having a tube replaced.
Thanks so much.
Thanks so much.
Old fart
Quoted: 3588 Post(s)
Liked 3,400 Times
Looks like a void area, where the brass didn't fully fill the space between the tube and the BB shell. Hard to say if it's more than a cosmetic issue. Can you see brass penetrated to the end of the tube inside the BB shell? If so, likely just cosmetic, but keep an eye on it. If/when you repaint the frame you can have the void filled with new brass.
Liked 3,638 Times
Thanks for the reply!
Old fart
Liked 3,400 Times
If the Framesaver was applied to the inside but has migrated through the void to the outside, that's a more serious issue. It means there is an extensive void that could compromise the joint. Failure of a joint at the bottom bracket is unlikely to be catastrophic, but it would be a major joint failure.
Randomhead
Liked 3,698 Times
a void that looks like that on the shoreline is probably bad news, nothing inside. Must have been quitting time.
Looks to me that the joint is already in failure. the ends of the "void" show cracks formed along the edge of the lug.
Some info to add for thought. The first frame I built had only half the socket on both chain stay/bb joints filled. Could not fill in as the filler just rolled off the tube because the gap was dirty and I was unable to sufficiently clean it out. I road it as my main bike and commuter bike year round in the snow and salt, rain, etc. for 10 years like that and it held together fine. After hitting it with a car I pulled the rear end off the main tubes and found the sockets had some surface rust where the filler was not present, but the tubes were fully intact and actually reused to fix a busted chain stay on a production bike, which as far as I know, is still being ridden. This took place 7 years ago.
Liked 3,638 Times
The downtube does not show any signs of cracking, so that seems to confirm that there is a void in the brazing.
Who knows, maybe a little bit of A, and a little bit of B. I'm certainly not putting out gobs of power, but I'm a decent sized guy and sometimes like to get out of the saddle to mash up a hill in the big ring.
I'm thinking that for now, it will hang on my wall and might make a trip to a framebuilder for an in-person evaluation. Maybe I'll get lucky, maybe I'll get a stool?
Thanks for the help, everyone.
