Brake Help!
Quoted: 12 Post(s)
Brake Help!
I need a new front brake for my fixed gear, have usually just used random stuff that i or friends have laying around.
I want to get something new! I was looking at tektro r540 or shimano 105s anyone have any suggestions.
I barley use the front brake but want for a just in case moment.
Double check how much reach you need - it'll depend on your fork. Both those calipers are short reach, meaning a distance somewhere around 40-50mm from the mounting hole to the pad. That's typical for road forks and track forks drilled for a brake, but if your fork has more tire clearance you might need a medium- or long-reach brake.
aire díthrub
Bikes: Raleigh Competition, Pashley Roadster Sovereign, Mercian Vincitore Speciale
Quoted: 259 Post(s)
Liked 55 Times
There are two things that matter here: Reach and clearence.
What brake are you currently using? What size tires are you using? Either one of those choices would be fine. I would personally go with the shimano over the tektro, but you can’t go wrong with either. There’s likely not a whole lot of difference in performance between the two. So maybe go for whichever one is cheaper cost? Just make sure the brake you choose will fit before spending money. Without knowing which version of 105 brake you’re talking about, I can’t directly compare the two, to say yes or no, on if they will both work or not.
Not actually Tmonk
Bikes: road, track, mtb
Quoted: 2611 Post(s)
Liked 3,128 Times
Shimano brakes are great IME. If you don't mind spending a little more coin, get some used Dura Ace 7800 brakes on ebay. They're the best!
"Your beauty is an aeroplane;
Clark W. Griswold
Quoted: 4332 Post(s)
Liked 3,956 Times
My choice for rim brakes is now going to be pretty much nothing but the eeBrakes from Cane Creek but if I were doing the budget thing 105 isn't so bad, just get some good pads (I like SwissStop) and some good cables and housing (Jagwire Elite Link is now my go to) and that can really upgrade your brakes without a lot of cost.
Quoted: 12 Post(s)
- Soli Deo Gloria -
Quoted: 6844 Post(s)
Liked 736 Times
Keep your eyes open for something at Bike Recyclery.
COMPONENTS - Brakes - Road Caliper Brakes - Bike Recyclery
-Tim-
-Tim-
aire díthrub
Quoted: 259 Post(s)
Liked 55 Times
I am currently using a old brake from one of my friends old state bikes. Right now 700x23 but possibly going to get bigger tires soon. Should I go ahead and measure or is there a brake that is right down the middle cause I don’t plan on going bigger then a 28inch tire.
the second bit is reach. This is where the length of your fork blades and the placement of the brake mounting hole come into play. The longer the reach you need to line the pads up on the rim, the more clearence (height) you will have for larger tires. The shorter the reach, the less room. Another way around this would be to convert to a smaller diameter wheel, which would increase the reach, and with it the size of tire that can fit. (See what I’m talking about here?)
you can directly compare your current brake to whatever brake you’re considering. That could help establish wether or not your tire will fit. If you’re likely to go to 28 at some point, then you should make sure the brake can clear that size.
Having a set of callipers, would come in very handy for this. The reason being, is that the actual width and height of your tire is completely dependent upon the inner width of your rim and the actual true size of the tire you choose. There’s no way to know these until you have it mounted and aired up.
nobody can really give you a definitive on what will or won’t work without measurements, or at least good photos of your current setup, where we could likely eyeball it. If your current brake looks like it has a lot of side and top clearence, and your new brake is similar, you might be good to go. That’s about the best I can do you with what info I’ve got.
