Changing gearing for flatland commute
I am currently on a 11spd 34/50 FSA Gossamer crank w/ 11-34 Ultegra cassette. I commute pretty much only flatland (cornfields of Illinois) and never really go past the 15 or 17T when I am on the 50, and I don't really use the 34 that much. If I am starting from a stop, I'll usually start off on the 25 or 27. I originally planned on replacing my crank with an Ultegra 6800 with a BBR60 bottom bracket since my FSA gossamer crank keeps coming undone, and it's annoying me. With that change, I was going to move to a 36/46 or 34/46. However, I completely forgot about changes on the rear cassette with gearing. I did some reading, and it seems like 12/25 is a pretty popular option, would be around $50-60. On the other hand, replacing the crank and BB would be around $150.
I'm not entirely sure whether it's better to just replace the cassette and deal with the loosening crank or if I should just upgrade the crankset + BB. I've spent a ton of time staring at gear charts which makes the change seem to be pretty small. Reading the comments on gearing here seems to suggest that the differences are quite noticeable. Would comboing the 12-25 with a 36/46 (if I ever do that upgrade later) be a bad idea? I am commuting in a town so I'm never really speeding down open roads.
Thanks for the advice.
ambulatory senior
Quoted: 1955 Post(s)
Liked 3,661 Times
My main concern would be why is you crank loosening up. Is there an issue with the bottom bracket threads?
I really have no clue. I made another post here about it, and there weren't really any solutions other than keep checking it every now and then. I had mentioned that it had fallen off completely before which I read can damage the threads resulting in always loosening. I also saw FSA has been recommending loctite, but it seems like you have to open up the BB to do that?
Quoted: 1221 Post(s)
Liked 629 Times
Living just to the west of you I run a 50/39 and 13-23 eight speed, which is almost perfect.
When I go eleven speed I think I'll go for an 11-25, and a 46/36 crank. The eleven cog instead of just a 12 will allow me to use the 36-12 combo, which allows me to stay in the small ring for optimal cadence tackling climbs, and the wind!
Edited to say you might just think about swapping the 34t ring for a 39t and keep the current cassette, that'd be cheap.
I did think about changing the 34 to a 39, but I guess the other reason why I am leaning towards changing the cassette is that I pretty much never use the 34,31 even if it's windy. I also imagine I wouldn't use the 39T that much since I'd be forced to use the 11 or 13T to get higher speeds which would be a pretty severe cross chain, no?
Quoted: 2952 Post(s)
Liked 3,106 Times
The flatter the terrain, the tighter the ratios you can go. I'd get a 12-23 if it were available in 11 speed. I remember having one in 10spd, but I'm not sure they still make it for 11.
20+mph Commuter
Bikes: Surly LHT, Surly Lowside, a folding bike, and a beater.
Quoted: 1434 Post(s)
Liked 331 Times
Both of my commuters have triple chain rings and both have basically road racing cassettes. My commute is flat as a pancake like yours. My beater has 7sp rear and my touring bike has a 9sp cassette. I switched from the stock touring gearing to the tightest ratio I could find. My 9sp is basically a straight block. One tooth difference each cog. I like 11T as my smallest but 12T would likely work fine.
I do not care about gear inches. So i can't say what I have. It works. It's really not that complicated to gear a commuter.
As for your crank looseness, I have no advice. Seek out a good LBS somewhere.
Awesome, thanks. I will switch to a 12-25 or 11-28 cassette! I definitely didn't pay any attention to the gear inches, only looked at the speed + rpms!
Disco Infiltrator
Quoted: 3126 Post(s)
Liked 2,105 Times
Personally I’d leave the gearing alone. You have enough range for anything and you want to replace it with enough range for one thing.
My sarcastic answer would be that since 50/15 is about the same as 34/11, all you really need to do is undo the pinch bolt on the FD.
I think I'll get the 12-25t cassette first, and then I will revisit the crankset since the only complaint I could see myself having in the future would be not being able to reach a high enough top speed at which I can get a Shimano 5800 39/53.
Thanks so much for all the help everyone!
Quoted: 539 Post(s)
Liked 44 Times
If I lived in an area I would absolutely agree, but the flatness here is insane! I thought Florida was flat until I moved to Illinois, and I'll be here for another 4 years before I can think about moving elsewhere. Realistically, yes I can definitely get away with my current gearing. I just find myself crosschaining quite a bit. I've seen some people say modern bikes are okay crosschaining and other people saying it's not. Not sure who to believe. I'm just getting ready to replace the chain so I figure I'd take this opportunity to considering replacing the cassette.
3x you put the front chainring in the middle gear and forget about it for anything except huge uphills or huge downhills.
2x it's always awkward...you're never quite in the right gear.
1x seems great because it eliminates the issue entirely. But it's newish and thus not the cheapest.
I am intrigued by that... but if I'm being honest, I struggle to use my 11, 13, and sometimes 15t when I'm on my 50 already. Granted, it's a lot of stop and go (college campus) so I imagine I'd be on the 46 a lot more than the 53. Now that I think about it, I don't think I've ever used my 11t with the 50.
This is why I thought the move from 3x setups to 2x setups was not great.
I ordered the 12-25. I'm hoping I will be able to ride the bike a bit more before snow + ice sets in, should come in this week or early next week. I started looking into bottom bracket replacements and what a whole new world of confusion debating between Chris Kings and replacing BBR60s and swapping bearings. Sometimes I wish the system was more uniform, but I simultaneously love to see all the innovation and competition. I just wish it was little bit cheaper to try out things
Quoted: 539 Post(s)
Liked 44 Times
1x12 is a mere $380 for a new groupset...
https://www.bicycling.com/bikes-gear...etrain-review/
[QUOTE=SlvrDragon50;20649699]I ordered the 12-25. I'm hoping I will be able to ride the bike a bit more before snow + ice sets in, should come in this week or early next week. I started looking into bottom bracket replacements and what a whole new world of confusion debating between Chris Kings and replacing BBR60s and swapping bearings. Sometimes I wish the system was more uniform, but I simultaneously love to see all the innovation and competition.
But I mean...if you're going to replace the whole bottom bracket, and you have the money to go for Chris King stuff...
Ha, yeah, that's for sure. "I want to try 1x12" "Cool, spend $400" "Wait...I mean...I just want to try it...not sure I want to commit to it..."
That's for sure, I was trying to stay with a triple if possible and skip the double as 1x wasn't expensive as heck.
Come one, if you go to 1x you'll only go from 2 shifters to 1 shifter, so it only counts half as much, right? :-D :-D
If I go for a CK it'll have to a be used one unfortunately! I just haven't quite figured out if it's worth it for a commuter bike, esp with a short commute vs say 10+miles a day. I've seen reports of some BBs going dead in 6 months, but I don't know how hard those are ridden. The other reason why I want a CK is so I can stick with a 44mm external cup tool and not have to buy a 41 and 44mm I'm so cheap that I'd rather splurge on the BB hah.
Disco Infiltrator
Liked 2,105 Times
It's really not hard to make a 1x10 or 1x11 drivetrain for not much (probably less than $150) out of any given modern bike. 1x12, yeah, they are maxing it expensive for now.
Genesis 49:16-17
Genesis 49:16-17
Very Slow Rider
Bikes: Jones Plus LWB, 1983 Centurion Japanese CrMo bike
Quoted: 500 Post(s)
Liked 132 Times
I have a pretty flat commute with few stops/8 miles. I am on a single speed (free, not fixed) track bike - about 65 gear inches. Not the fastest thing in the world and I do get passed when it's triathlon training season but it sure is fun and reliable (no chain drops - chain is 1/8" and bullet proof) - no drama. Plus my bike is lightweight which makes it nice when they're doing elevator maintenance in my building!
"IF IT WERE ME" which it's clearly not so take this with a grain of salt - You could buy a used bike like mine for less than the cost to convert your bike to the ideal setup (1x, IMHO) and use it to soak up the bulk of your commuting miles and keep your existing bike and use it for longer rides/centruries, etc. That's my goal only in reverse (ie, I need the geared bike).
If you're loving your geared bike, I think a good stretch goal for commuting would be to make it a 1x10 with a 40-42T front ring.
Virgo
I commute 25 miles/day on vintage 12 speeds in flat Indiana and I most often use only about 4 gear combos (40/21, 40/18, 52/21, 52/18). I'm puzzled that people desire/require more gears, especially for shorter commutes. I've thought about going single speed but my work route is directly in line with prevailing wind and it's most often quite windy, I'd worry about my knees. If my commute were urban and shorter, I'd go SS in a heartbeat.
Very Slow Rider
Quoted: 500 Post(s)
Liked 132 Times
Jedi Master
I had a 12-25 11 speed with a compact crank and hated it because there was almost no overlap between the chainrings so I was always cross-chained unless I was hammering in the big ring. I swapped the 50T for a 46T, and it's much better now.
How long is your commute? I live in the Chicago suburbs where it is also flat and have been commuting for the past 25 years on a single speed.
Bikes: Yes
Quoted: 3230 Post(s)
Liked 3,868 Times
The cheap way to switch to 1x11 is just pick the chainring size you want and never shift out of it. Just because your crank has two rings doesn't mean you have to use them both. An 11-34 cassette makes no sense at all for your terrain. I'd want something like 12-25 or 12-27 with a 42T ring. You can find cheap 110 BCD 42T rings. Ask around on this forum and you might even be able to find someone to swap with. If you don't plan to use the small ring you don't need a fancy chainring with pins and ramps. Keep the front rerailleur as a chain guide.
The crank coming loose is something FSA is notorious for. I've got one that does that. It's a bad design. For those who don't know, the left crank arm is held on to the spindle but a 10mm bolt. It's not a press fit like square taper cranks. If you loosen the bolt the crank arm slides right off. The bolt comes loose pretty regularly. Proper torque ought to prevent this, but it's a lot more torque than most people expect. A bit of blue LocTite on the bolt would probably also take care of it.
My Bikes
My Bikes
