Anyone else using Wahoo Kickr in cold season? Having an issue
Was curious if anyone else was having an issue with their Wahoo Kickr. The issue seems to be with the cassette. First the cassette on the Kickr is extremely noisy/grinding basically all the time. Secondly it refuses to shift to the smallest cog 90% of the time which prevents me from gaining a lot of speed on downhill runs in zwift. Second, I can shift to the small ring anytime, but going back to the big ring? That requires me to be in the middle 3 cogs of the cassette on my Shimano 105 drivetrain. Otherwise? No chance to go back to the big ring. This is extremely annoying and makes for really awkward changes when you have to constantly adjust your cassette just to move the chainring.
I'm guessing it has to do with he cassette being a "universal" type cassette? Maybe I should swap it for a 105 cassette? It's absurdly annoying.
Any ideas?
Any ideas?
Super Modest
Quoted: 10891 Post(s)
Liked 4,559 Times
The cassette that came with my Kickr has never meshed properly with any of my bikes no matter how much adjusting I do. I haven't started using it yet this winter but I'm going to install a cassette from a set of wheels that I know meshes ok and see if that helps.
Keep the chain tight!
Quoted: 3905 Post(s)
Liked 7,181 Times
How would the cassette prevent you from shifting from the small chain ring to the big chain ring? I think your issues lie elsewhere.
Quoted: 942 Post(s)
Liked 526 Times
I don’t own one, but something to look at is if the right spacers were used, or to ensure a spacer wasn’t used if your not supposed to have one. I assume everything on the bike is indexed correctly.
Quoted: 741 Post(s)
Liked 412 Times
Mine would have some hesitation in the 13-11 cogs, I think. I swapped the one that came with the unit for a wider range cassette sometime last winter. The hesitation is gone. Always assumed it was something wasn’t adjusted right on the bike.
Super Modest
Liked 4,559 Times
In my case, I know that to be true. The only difference would be wear on my chain so I tried a new chain and still had some slight grinding in a few cogs even after minor adjusting. This year, I'm just going pull the Wahoo cassette and use my own. I'll bet that fixes everything.
I thought the same thing but swapped my wheel back on and went around the block and had absolutely no issues with the chain ring or cassette. Back on the kicker? exact same thing as before. I've now tested it a full 3 times. I believe it has something to do with the spacing on that rear cassette.
Super Modest
Liked 4,559 Times
I changed cassettes today and all is well in Kickr land.
hobkirk
Bicycle Mechanics
8
05-19-15 08:00 PM
shamblesuk
Bicycle Mechanics
36
12-05-13 06:51 PM
