SNAFU milestones.
SNAFU milestones.
Old 07-25-19, 06:22 AM
RobbieTunes
Half drunk? Finish!
RobbieTunes's Avatar
Quoted: 374 Post(s)
Liked 782 Times in 504 Posts
SNAFU milestones.
1. Snapping that Campy seat post binder bolt.
2. Stripping the crankset threads.
3. Slipping onto the chain ring with flesh.
E tu, et al?
Robbie ♪♫♪...☻
I have unfinished business.
RobbieTunes is offline
Likes For RobbieTunes:
Old 07-25-19, 06:25 AM
qcpmsame
Semper Fi
qcpmsame's Avatar
Quoted: 1093 Post(s)
Liked 119 Times in 99 Posts
You having a bad month Bunkie?
Bill
Semper Fi, USMC, 1975-1977
qcpmsame is offline
Likes For qcpmsame:
Old 07-25-19, 06:58 AM
seedsbelize
smelling the roses
seedsbelize's Avatar
Quoted: 5399 Post(s)
Liked 172 Times in 133 Posts
E tu, et al?
I recall you mentioning trimming the cable housing with the cable still in it. As a result of that post, I have yet to do it. Thanks!
seedsbelize is offline
Old 07-25-19, 07:01 AM
seedsbelize
smelling the roses
I did once cut a nice, long, superficial gash in my left wrist (which produced an impressive scar), from incorrectly attempting to remove a freewheel, while under the influence of cold medicine.
Old 07-25-19, 07:29 AM
thinktubes
weapons-grade bolognium
thinktubes's Avatar
Quoted: 537 Post(s)
Liked 281 Times in 167 Posts
Cutting a chain and it's 2 links short...
thinktubes is online now
Old 07-25-19, 07:44 AM
chainwhip
Quoted: 169 Post(s)
Liked 67 Times in 49 Posts
Getting the install sequence FUBAR'ed...
...using a quill stem: brake levers. bar end shifters, cables , bar tape.
Gotta have a plan.
Plan your work, work your plan.
X0p
chainwhip is offline
Old 07-25-19, 07:58 AM
ldmataya
ldmataya's Avatar
Quoted: 65 Post(s)
Liked 11 Times in 9 Posts
Getting 6 miles into a ride (hilly) and realizing you are still stretching the rear tubular - never glued.
ldmataya is offline
Old 07-25-19, 08:22 AM
non-fixie
Shifting is fun!
non-fixie's Avatar
Bikes: Yes, please.
Quoted: 1290 Post(s)
Liked 395 Times in 254 Posts
"I'll tighten that later":
Stem bolt
bar clamp
Seatpost bolt
The postman with my new frame: I'll be here when he comes!
non-fixie is offline
Old 07-25-19, 08:43 AM
Reynolds 531
Bikes: 4 Old school BMX, 6 Klunkers, 5 29er race bikes, 4 restored Sting Rays, Now 3 vintage steel bike being built up
Quoted: 189 Post(s)
Liked 39 Times in 30 Posts
Putting a TA crank Puller in a Campy crank, or vice versa, I forget.
Reynolds 531 is offline
Old 07-25-19, 09:01 AM
delbiker1
Mother Nature's Son
delbiker1's Avatar
Quoted: 360 Post(s)
Liked 230 Times in 148 Posts
Too many to list. Going to leave them cut off at the past. Any Firesign Theater fans in here.
delbiker1 is offline
Old 07-25-19, 09:10 AM
noglider
noglider's Avatar
Quoted: 6167 Post(s)
Liked 654 Times in 449 Posts
Letting the crank fixing bolt wrench slip and bashing my knuckles into the chainring teeth. I used to do this a lot. For a while, I had a scar on every single knuckle of my hands! That was years ago, and most of them have faded. I was a full-time shop mechanic when I was young.
noglider is offline
Old 07-25-19, 10:01 AM
squirtdad
squirtdad's Avatar
Quoted: 1005 Post(s)
Liked 230 Times in 173 Posts
never ever have i done that
squirtdad is offline
Old 07-25-19, 10:07 AM
seypat
Quoted: 1374 Post(s)
Liked 322 Times in 228 Posts
For all of the fly by the seat of the pants wrenching I do, I've never done anything that caused permanent damage. I will say that I use the Allen headed crank bolts.........just in case I have to tighten them up on a ride. I also carry a multi tool with an Allen wrench that will fit those bolts...........just in case I have to tighten them up on a ride.
By far the thing that has caused the worst amount of trouble is not getting my cell phone full charged before an event. I got lost on a century in Mid August one year. The phone died about halfway through. I never could get back on the correct path. At one point after about 45 minutes of riding, I ended up back at the place I was looking at the GPS when the phone died. I ended up doing 155 miles before I got back. I wasn't the only one who got lost. When I got back, they were still looking for 3 other riders.
Now if you are are talking about auto wrenching, let me give you some advice. Don't attempt to change a front CV axle without the CV axle puller tool. Don't do it. That's all I'm going to say about that. That pretty much goes for any type of job that requires a special tool.
seypat is offline
Old 07-25-19, 10:16 AM
squirtdad
squirtdad's Avatar
riding a bike (just a short ride) knowing Big/Big chain combo does not work. I of course will be aware of it and not shift into that combo until i get chain length fixed.
Yeah sure,
hit the combo, and bike stopped. I was going slow and did not crash, per se, but did a cartoon like slow tilt over.
goes back to cutting chain 2 lengths short
and now I use the small/small sizeing method
Old 07-25-19, 10:18 AM
seypat
Nobody(besides me) uses a quick link, chain breaker and the "1 or 2 links at a time" method for sizing chains?
seypat is offline
Old 07-25-19, 10:29 AM
stardognine
stardognine's Avatar
Quoted: 591 Post(s)
Liked 164 Times in 129 Posts
Don't crush that dwarf, hand me the pliers! 😁
stardognine is offline
Old 07-25-19, 10:38 AM
Darth Lefty
Disco Infiltrator
Darth Lefty's Avatar
Quoted: 1838 Post(s)
Liked 390 Times in 266 Posts
I stripped the crank extractor threads... by torqueing the crank bolt so hard that the extractor threads couldn't pull it. This was on the drive side with a cartridge BB so no hope. I dropped it off at the LBS and he said, "give me fifteen minutes... do you need to save the BB?" No sir, just do what you must
Genesis 49:16-17
Darth Lefty is offline
Old 07-25-19, 10:42 AM
delbiker1
Mother Nature's Son
delbiker1's Avatar
Quoted: 360 Post(s)
Oh Nick, you're such a tool!
Old 07-25-19, 10:46 AM
stardognine
Quoted: 591 Post(s)
Don't stop me now, I'm about to leap into a hole that goes to the center of the Earth.
Old 07-25-19, 10:56 AM
-holiday76
No one cares
-holiday76's Avatar
Quoted: 217 Post(s)
Liked 39 Times in 28 Posts
I rode the Sea Otter Gran Fondo in 2012 in Monterey with no bearings in the lower part of my headset by accident.
I prefer emails to private messages - holiday76@gmail.com
Jack Taylor Super Tourer Tandem (FOR SALE), Jack Taylor Tour of Britain, Px-10, Carlton Flyer, Fuji The Finest, Salsa Fargo, Santa Cruz Tallboy, Carver All-Road .
-holiday76 is offline
Old 07-25-19, 11:04 AM
madpogue
Quoted: 1199 Post(s)
Liked 361 Times in 277 Posts
Bought a car from Ralph SpoilSport Motors......
madpogue is offline
Likes For madpogue:
Old 07-25-19, 11:10 AM
BFisher
BFisher's Avatar
Bikes: '61 Schwinn Klunker, '68 Hercules Klapprad, '71 Peugeot UO8, '73 Raleigh Super Course, '78 Motobecane Grand Jubile, '79 Motobecane Grand Sprint, '87 Ironman Expert, '89 Puch Mistral Leader, '92 Trek 930
Quoted: 264 Post(s)
Liked 322 Times in 200 Posts
Let's see...
1. Installed French threaded bottom bracket backwards
2. Stripped crank extractor threads after forgetting to remove crank bolt
3. Split left thumb open badly with a hammer while removing really stubborn cartridge bearing. Super glue = stitches (Kids, don't try this at home!)
4. Punctured tube after tube with a tire lever while wrestling with oversized rims
5. Dropped bike frame on toe while wrenching in sandals. Yep, broke it.
I'm sure there are more.
BFisher is offline
Old 07-25-19, 11:22 AM
delbiker1
Mother Nature's Son
delbiker1's Avatar
Quoted: 360 Post(s)
I wrapped my coat around Nancy to keep her warm, I wrapped her legs around me to keep me warm.
Old 07-25-19, 11:47 AM
rccardr
aka: Dr. Cannondale
rccardr's Avatar
Bikes: Lots. Just...lots.
Quoted: 1193 Post(s)
Liked 173 Times in 114 Posts
I spell my name...Danger!
rccardr is offline
Old 07-25-19, 11:52 AM
Drillium Dude
NNNN
Drillium Dude's Avatar
Quoted: 1429 Post(s)
Liked 532 Times in 303 Posts
DD
Drillium Dude is offline
Likes For Drillium Dude:
