Ti - NOW I understand what all the fuss is about!
Bikes: 2007 Quiring Ti + 2014 Focus Izalco + 2009 Dynamic Synergy + 80's Bottecchia w/105 Crank Set + 2010 Jamis Commuter-4 + 1999 GT Slipstream Hybrid
Quoted: 40 Post(s)
Liked 15 Times
I finally found a Ti bike to round out my N+1. It joins my CF Focus, my steel Bottecchia and my aluminum Dynamic Synergy. And... WOW, the ride is considerably smoother than any of them. I took it out for its first 20-miler, yesterday, and ruts and bumps I used to cringe over passed underneath mostly unnoticed. Some I actually had to look for to be sure I passed over them. I am now a believer!
The frame is a "Quiring," created by Michigan frame builder Scott Quiring. The controls and associated parts are Ultegra and, most interesting, the rear stays are Carbon Fiber. I contacted Scott to be sure the mating of the titanium to CF was not a cause for concern and he assured me it was all good.
Likes For Cypress:
SuperGimp
That's basically a CF bike, how can you draw conclusions as to the ride properties of Ti with that thing?
Likes For TrojanHorse:
Likes For Gconan:
Quoted: 40 Post(s)
Liked 15 Times
In answer to your question, some of the manufacturers that combine CF into their Titanium bikes are:
Colnago (CT2)
K. Bedford Customs
Dean Bikes (Exogrid)
Seven Cycles (Ti / Carbon Hardtail)
Litespeed (Unicoi)
and, of course, Quiring Cycles
Quoted: 980 Post(s)
Liked 776 Times
That "thing?" Thanks for the support.
Colnago (CT2)
K. Bedford Customs
Litespeed (Unicoi)
Colnago (CT2)
K. Bedford Customs
Litespeed (Unicoi)
Likes For downhillmaster:
Quoted: 18412 Post(s)
Liked 15,532 Times
Likes For eduskator:
Likes For jadocs:
Should Be More Popular
Quoted: 22596 Post(s)
Liked 8,925 Times
Ti is fly.
But the truth is, how a bike "feels" and "handles" matters very little on the frame material. Frame geometry/fit/tires and especially tire INFLATION all matter more IMO.
That's not to say that identical setups with Ti/Al/CF/Steel/Bamboo/etc. will feel identical. There are certainly nuances to each material. But it's modest and certainly over-rated.
Bikes: Shmikes
Quoted: 10165 Post(s)
Liked 5,856 Times
Ti is fly.
The up-tilted bars suggest to me that the frame doesn't fit, the stem is too long (been there), and/or or the OP doesn't really like standard road geometry.
Liked 15,532 Times
Quoted: 40 Post(s)
Liked 15 Times
Yeah, I have a Ti bike, which I like very much, but I haven't reached any particularly exalted plane of understanding. It rides like a CX bike with 36mm tires, right now.
Regardless all that, my first ride on the Quiring was measurably smoother than my other bikes (aluminum, steel & CF), with the same tire pressure. I have to believe the Ti made the difference.
C'mon, I'm old!
Likes For DrDyno:
Bikes: Shmikes
Liked 5,856 Times
Whoa, you folks are plenty observant in the "bike fit" department! I'm an old guy, just passed my 74th birthday, and started road cycling about 13 months ago. So, you're right, I set up more for comfort than speed. The pictures, above, were taken after a hasty set up for my first ride. My other bikes are equipped with 40° stems which brings the bars higher and closer to me. Being anxious for my first ride, I flipped the Ritchey stem it came with to gain a few degrees of elevation and moved the seat forward to mimic the distance from the seat stay to hoods of my other bikes. Following is a picture of my Bottecchia with its 40° stem.
C'mon, I'm old!
C'mon, I'm old!
Bikes: 1987 Pinarello Montello, 1996 Litespeed Classic, 1996 Colnago Master Light, 1997 Litespeed Ultimate, 2006 Opera Leonardo FP, 2006 Pinarello Paris FP, 1984 Pinarello Record, 89-ish Cornelo Profilo
Quoted: 148 Post(s)
Liked 119 Times
Ti is light no question. I went from an 87 Pinarello (Columbus SLX) to a Litespeed Classic (w/Kestrel EMS fork). Shaved off around 6 lbs (Chorus 11 carbon vs 8-speed Chorus aluminum doesnt hurt, nor does the Syncros Ti seatpost, or other special bits on the Litespeed), but I'm not sure it rides any smoother, and it definitely doesnt handle as nicely. At this point, it doesnt help that it went from a classic 32-spoked wheelset to Zondas, which are pretty stiff themselves. The Pinarello has Mavic Open SUP CDs on 32 spokes. Point being, it comes down to a good bit more than the frame alone. Doesnt matter though...
Adjust the fit so you're comfortable, and just get out and enjoy the ride.
Likes For CyclingFool95:
Liked 15,532 Times
I'm thinking of getting a custom ti frame.
Likes For indyfabz:
Quoted: 389 Post(s)
Liked 255 Times
Ti is fly.
Bikes: Shmikes
Liked 5,856 Times
Likes For MoAlpha:
Quoted: 4806 Post(s)
Liked 3,928 Times
I have two custom ti frames and 3 steel frames, one custom. All with steel forks. What I love about ti frames is that I can run good tires at old-school pressures and the ride is sublime. I don't have to drop the pressure to the level where all frames and wheels feel the same. 92/96 front/rear psi is excellent with Vittoria G+ tires. 104/100 for 25c. 106/110 for 23c (though I no longer run 23c; I may go back to them if I go sewups). (I weigh 150 pounds.)
Yes, at those pressures there is road feel. I like it. I run the same pressures on my steel bikes except a touch less on my winter./rain/city fix gear with its not so light tubing. My Mooney has a little more road feel, my Raleigh Competition less than the ti bikes. (None of my bikes have any damping save tires, seat padding (not much) and two layers of bar tape. All posts and stems are aluminum or ti and all bars are aluminum.)
Ben
Ben
Liked 15,532 Times
Likes For indyfabz:
Liked 8,925 Times
