Cable Grease
Cable Grease
Old 11-19-19, 04:57 PM
Robert A
Bikes: 2019 CAAD12, 2015 Specialized Sirrus Comp
Quoted: 402 Post(s)
Liked 21 Times in 17 Posts
Cable Grease
I'm looking for a recommendation to grease my rim brake and derailleur cables. My LBS is recommending Shimano Cable Grease, but it may be overkill (in terms of quantity) for my one bike. Are there good, lower-cost alternatives?
Thank you,
Robert
Robert A is offline
Old 11-19-19, 05:07 PM
HTupolev
Quoted: 1375 Post(s)
Liked 184 Times in 111 Posts
Depends on what you're using. For example, all Jagwire housings above their bottom-end come with pre-lubricated liners and there's not necessarily any reason to add anything.
HTupolev is online now
Old 11-19-19, 05:10 PM
Robert A
Quoted: 402 Post(s)
I have whatever housings came standard with my 2019 Cannondale CAAD12/Ultegra.
Robert A is offline
Old 11-19-19, 05:26 PM
redlude97
Quoted: 1916 Post(s)
Liked 169 Times in 122 Posts
i also use prelubed cable housing but if there are just a bit draggy I've also just used a small amount of grease or triflo
redlude97 is offline
Old 11-19-19, 07:24 PM
zacster
Quoted: 22 Post(s)
Liked 99 Times in 79 Posts
For a 2019 bike you shouldn't need lube on a Shimano cable unless you leave the thing out in the rain 24/7 and I doubt you do with a CAAD12/Ultegra.
zacster is offline
Old 11-19-19, 07:35 PM
DrIsotope
Non omnino gravis
DrIsotope's Avatar
Bikes: Nekobasu, Pandicorn
Quoted: 4231 Post(s)
Liked 747 Times in 452 Posts
DrIsotope is offline
Likes For DrIsotope:
Old 11-19-19, 07:41 PM
zacster
Quoted: 22 Post(s)
I should mention too that when I started a thread about a month ago asking what lube to use for cables the answer I got was to not bother and just get new cables. In my case though the bike WAS left out in the rain and snow 24/7 for 4 years. As it turned out I only replaced the rear derailleur cable as that was the one giving me problems and it worked. The bike is also a 1990 model, not 2019.
No, you don't need to lube your cables. If one is sticky it probably has a broken wire and needs replacing.
zacster is offline
Old 11-20-19, 08:48 AM
La Brea Bike
Bikes: 2002 Litespeed Ultimate, Felt F1, 1984 Raleigh Grand Prix 1984 Raleigh Super Course 1985 Raleigh Prestige 1928 Hercules 1938 Raleigh Sports
Quoted: 110 Post(s)
Liked 18 Times in 14 Posts
So, we perform 20-30 Tune-ups a month. There are definitely situations in which even newer bikes have benefitted from cable lube. Slow return of brake levers, and slow drop of the Rear Mech are commonly improved. As far as what they use, it has varied by Mechanic. The guys I have had the highest faith in (20 + year experience) have preferred Tri-Flow wet. Whatever you do, never use a dry chain lube. We had one guy using this on occasion, and we had some comebacks. I can see how paraffins might sound like a great idea, but it gums up the works. On the other hand, if it's my bike, cable and housing are cheap and provide ultimate results.
La Brea Bike is offline
Old 11-20-19, 12:46 PM
Clipped_in
Rubber side down
Clipped_in's Avatar
Bikes: are fun! :-)
Quoted: 5 Post(s)
Liked 62 Times in 46 Posts
Dialectric (silicone) grease is what you want. It won't degrade the various synthetic components in the cable housing like petroleum-based grease will. I've also heard this works well but I'm guessing it is a silcone grease:
Clipped_in is offline
Old 11-21-19, 02:49 PM
Robert A
Quoted: 402 Post(s)
Any thoughts on this product from Park Tool:
Just spoke to Calvin, and he recommended it over grease for its ability to work it's way into the cable housing.
File Type: pdf
Robert A is offline
Old 11-21-19, 08:37 PM
MagicHour
MagicHour's Avatar
Quoted: 83 Post(s)
Liked 7 Times in 6 Posts
I've used the shimano SP-41 grease, which is also a silicone product. Haven't had any issues over the lifespan of my cables, shifting is always nice and crisp.
MagicHour is offline
Old 11-22-19, 04:02 AM
Fiery
Fiery's Avatar
Quoted: 220 Post(s)
Yep, also came in to say this.
Fiery is offline
Old 11-22-19, 08:33 AM
Robert A
Quoted: 402 Post(s)
How do you get the grease far enough inside the cable housing without pulling out the cable?
Robert A is offline
Old 11-22-19, 12:37 PM
Reynolds
Passista
Reynolds's Avatar
Quoted: 528 Post(s)
Liked 90 Times in 65 Posts
Grease is too heavy and sticky IMO. I prefer some light oil, currently using ATF.
Reynolds is offline
Old 11-22-19, 02:43 PM
Jack Tone
Quoted: 56 Post(s)
Liked 19 Times in 15 Posts
I've never had a problem using WD40 or Triflow with one of these:
Jack Tone is offline
Old 11-23-19, 02:25 AM
Racing Dan
Racing Dan's Avatar
Quoted: 826 Post(s)
Liked 31 Times in 26 Posts
Good question.
If you have a bike with only a short gear loop at the end, it easy to clean and lube that.
Park the bike with the chain on the big rear cog. without pedalling shift all the way down, to release some cable and the cable goes slack. - Now you can unseat the housingends and clean the cable, ect.
Racing Dan is online now
Old 11-23-19, 01:14 PM
Clipped_in
Rubber side down
Clipped_in's Avatar
Bikes: are fun! :-)
Quoted: 5 Post(s)
You do it as a cable prep during the installation--not after. Put some grease on your fingers and working it along the exposed cable working it into the filaments. Then, run the cable inside the housing moving it back and forth a few times. Take the cable out of the housing and gently wipe it down with a soft cloth. Then, install cable and housing.
Likes For Clipped_in:
