Threadless headset keeps getting loose?
Old 10-11-10, 11:14 AM
AndyK
Bikes: '03 De Rosa Planet, '77 Cinelli Supercorsa, '79 Paris Sport (Moulton)
Liked 3 Times in 2 Posts
I have a Campy Record threadless hiddenset on my road bike. I have had to tighten the headset after several rides, and even though I am tightening the stem, after a few rides, when I hold the front brake lever and rock the bike forward, I get that clunk, clunk sound that tells me the headset is too loose, again.
If I am tightening the stem after adjusting the headset, what could I be doing wrong to cause the adjustment to loosen?
AndyK is offline
Old 10-11-10, 11:18 AM
FBinNY
Quoted: 4355 Post(s)
Liked 11 Times in 11 Posts
A few possibilities come to mind.
First and most common is that your stem/spacer stack isn't high enough and you aren't getting a proper adjustment in the first place. Remove the top cap and verify that the steerer is below the rim of the outer stack by a few millimeters. Add a spacer if needed.
If it's a newly installed headset
, it's likely that you haven't seated the cups or crown race fully into position. You adjust the headset then while riding the road shocks drive parts a bit farther down loosening the headset.
Look for a gap between the crown race and fork, or frame cups and head tube. If you see any that's your problem, and there are two fixes. Either remove the fork and seat the races all the way home, or continue as you are, taking up the slack as nature takes it's course and seats them for you. When they're bottomed out, you'll make your last adjustment. BTW- be aware that as parts seat your steerer will rise, so you may need another spacer.
If you have a carbon fork and steerer tube, it's possible that the stem clamp isn't holding well enough. The expander (or starnut) isn't enough to resist the forces loosening things. Check that the stem clamp is effective, possibly tightening it a bit more if that's possible without damage. Also check that the two clamp bolt ears don't touch which would make tightening impossible. If you're at the clamp bolt torque limit and need more hold, consider using carbon assembly paste or coarse lapping compound (available in auto stores) to provide mechanical adgagement through the grit's biting into both mating parts. This is an effective way to increase holding strenght without increasing clamping pressure.
That covers the three common and likely causes, if you've eliminated all three, then you need to look at the fit of the headset parts into the frame or fork. For example it isn't rare for Ti frames' headtubes to become bellmouthed at the bottom, causing play between the cup and tube, which acts like a loose headset, but is much more complicated to fix.
FB
Chain-L site
“Never argue with an idiot. He will only bring you down to his level and beat you with experience.”, George Carlin
FBinNY is offline
Old 10-11-10, 12:02 PM
fietsbob
coprolite
fietsbob's Avatar
Bikes: 8
Quoted: 6980 Post(s)
Liked 345 Times in 269 Posts
I added a QBP 'locking spacer', directly above my top headset race
on my integrated headset, it's another pinch bolt to loosen
while you adjust the headset pre load,
But its another bit of clamping force around the steerer tube once you snug it down
I added mine to keep it from letting the fork fall out, when I take the stem off.
and pick up the front of the bike.
like for packing the bike in a box for a trip.
they're thinner than a seat post band clamp, and have no shoulder.
like the clamp that sits on top of the seat-tube would.
fietsbob is offline
Old 10-11-10, 12:29 PM
AndyK
Interesting points!
I did space it out so that the stem is a few MM's above the top of the steering tube, to give me ample room for adjustment. Check.
I did recently swap out the stem, and change the internal locking nut to the Deda unit (carbon fork and steerer). So it could be that the cups are still seating themselves, and need a few more tweaks to find their seating. This is most likely my problem!
Also, the stem isn't fully closed around the steerer, and it has been torqued properly.
So, I'll give it a while to allow the cups to fully seat, and see what happens. If I need it, it's good to know the extra clamp solution is out there.
Thanks!
AndyK is offline
antonyfhilliard
Bicycle Mechanics
15
02-27-15 11:14 AM
jzsoup
Bicycle Mechanics
9
06-03-13 05:46 AM
aidanpringle
Bicycle Mechanics
14
01-01-13 01:42 PM
reshp1
Bicycle Mechanics
9
08-08-11 02:31 PM
joejack951
Bicycle Mechanics
41
03-02-10 11:36 AM
