Hydraulic Brake Question (basic)
Bikes: Canyon Endurace
Quoted: 1041 Post(s)
Liked 922 Times
Is there any kind of failsafe or backup if you lose fluid for one reason or another?
Just wonderin'
Just wonderin'
Quoted: 1572 Post(s)
Liked 643 Times
The front and rear brakes are completely separate systems so you're unlikely to lose both at the same time.
There's no fail safe if you brake a cable either.
Quoted: 5764 Post(s)
Liked 2,537 Times
Yes, same as with cable brakes, or car/truck brakes or even critical systems in aircraft, safety is based on redundancy. Two independent systems, so in the event of total failure of one you still have the other.
FB
Chain-L site
FB
Chain-L site
In older Citroen cars the hydraulics powered the gearchange, suspension, steering and brakes. In the event of loss of the pump there was a small reservoir called the accumulator. With pump failure the dashboard warning lights would light up like a christmas tree and, in order, the car would give up on gearchange, suspension, steering assist and very last of all - brakes.
After that you could only slow down by running over some cyclists.
Quoted: 14 Post(s)
Liked 13 Times
This is just one of the many reasons Citroen has come to dominate the world automotive market.
for the young readers,from the 'Duck and Cover' student generation:
Fail Safe, a 1964 film. [from Imdb]
American planes are sent to deliver a nuclear attack on Moscow,
but it's a mistake due to an electrical malfunction. Can all-out war be averted?
A series of human and computer errors sends a squadron of American 'Vindicator' bombers to nuke Moscow.
The President, in order to convince the Soviets that this is a mistake,
orders the Strategic Air Command to help the Soviets stop them.
Liked 2,537 Times
You wouldn't want a fail-on brake on a bike because if the line were cut the front brake would lock up and you'd do an endo.
FB
Chain-L site
FB
Chain-L site
Quoted: 2026 Post(s)
Liked 1,095 Times
Bikes: 2015 Giant Roam 2 Hybrid
Quoted: 91 Post(s)
Liked 6 Times
Like others have said, it's just as fail proof as a cable brake.
I have hydro discs on my Giant Roam 2 and love them. While I realize that they are completely unnecessary and overkill for the type of biking I do I do sure like them! They are very smooth, the brake lever is smaller, takes less pressure and seems to have finer control than my old bikes V brakes. They are well worth the extra $$$ I spent, at least I realize I have spent more for other things that I have enjoyed far less than these bakes.
bike whisperer
Quoted: 1523 Post(s)
Liked 716 Times
Also I think such brakes are quite difficult to modulate.
Sheldon Brown's bike info ~~~ Park Tools repair help
Half-step triple, using double gear ~~~ 6400 STI rebuild walkthrough ~~~ Want 8/9/10s @126mm OLD? OCR. ~~~ Shimano cassette body overhaul ~~~ Ergopower Escape wear repair ~~~ PSA: drivetrain wear
List of US/Canada bike co-ops ~~~ Global list
Being on top of your maintenance is the key . if you see hose damage, you replace it. before it breaks open ..
