Bent hanger or derailleur?
I just put together this bike today from Bikes Direct and haven't even been able to ride it one foot yet, because the derailleur is actually clipping against the spokes and the bike won't even move forward.
Please tell me there is a fix I can do at home for this, I don't drive so I don't have a way to get to a shop. I *might* be able to use my girlfriend's car. And no I don't have a spanner tool thingie. Thanks you guys, I'm dying to get on the road, I've been bikeless for the last month after they stole my sweetheart
Brad
Derailleur's hanger is bent . It a5 mins fix at your LBS .
Quoted: 5779 Post(s)
Liked 2,576 Times
How could you ask hanger OR derailleur? The hanger is very obviously bent, so the real question is whether the RD is also. I doubt it, but that's just on general principles, there's no way to tell until you straighten the hanger, and then see how things work (or not).
If there's a bike co-op, or shop that does reasonable priced repairs within riding distance, you have 2 options.
1- ride it the way is, but be careful to set the low gear limit so it can't get anywhere near the wheel. You won't have the use of your lower one or two gears, and it may run noisy and shift poorly, but it will probably be rideable.
2- remove the RD from the hanger, and fit an adjustable whench over the hanger, spanning the RD mounting hole (critically important that you do so), and gently bending it straight. Aluminum isn't tolerant of repeated bending, so don't try to get it perfect, of go beyond and back. Just get it better, then mount the RD, adjust the limits on the safe (tight) side, and ride to the co-op to have it dialed in.
FB
Chain-L site
FB
Chain-L site
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
Liked 2,576 Times
They're single so they can't ask the wife or inlaws, and obviously don't have kids to do it yet.
FB
Chain-L site
FB
Chain-L site
Quoted: 4201 Post(s)
Liked 3,857 Times
I rarely use the hanger alignment gage/lever tool at work It's much quicker to use a 5mm Allen in the mounting bolt and a screwdriver placed behind the hanger, bearing on the hanger and the end of the cassette/freewheel. Since most of the bent hangers are in the vertical plane very little twisting is needed. I see rear ders with cages that are not square with the parallelogram or mounting bolt. So using a hanger gage is not a perfect compromise every time. i align the hanger with an eye to the cage aligning to the cogs. I'll select a few different cog/ring combos to get a feel for the real pulley alignment needs.
I've owned a campy "N" tool, various Parks and extensively used the Shimano alignment tools and still feel that my freehand method is more then good enough, unless the customer is watching. Then I'll reach for the fancy tool, take more time and still do a fine tuning freehand after. Andy.
Liked 2,576 Times
I didn't suggest this method to the OP, because his RD has a lsender arm or plate between the upper body and hanger, and I didn't trust it (or the OP).
FB
Chain-L site
FB
Chain-L site
Bikes: Look 585
Quoted: 25 Post(s)
Take it to a shop or get the right tool: https://www.masherz.com/products/park...FYxcMgodsREAhg
You can probably find it cheaper, and its a one-in-a-lifetime investment.
Quoted: 2026 Post(s)
Liked 1,096 Times
The OP said it a new bike from Bikes Direct. They should provide a new derailleur hanger if it's replaceable or a new frame if it isn't.
Retro Grouch
Bikes: Yes
Yes, but the the OP needs his bike working right now. I would remove the wheel and rear derailleur, take a 12" adjustable wrench or bigger, tighten the jaws around the derailleur hanger and bend the hanger straight. Even if you overbend it a little, it will at least keep the derailleur out of the spokes..
Bikes: 1992 Dave Yates Diabolo MTB, Steel winter roadie upgraded to full 11 speed 105 and Hunt wheels. 2016 Giant Defy Advanced two with Hunt wheels.
Quoted: 1572 Post(s)
Liked 643 Times
Liked 1,096 Times
I understand the urgency but if the OP does a jury rig correction, Bikes Direct may refuse to honor the warranty.
If you're going to attempt to straighten it by eye then I'd do it with the wheel out (as others have said). That way you can get the spanner jaws all the way up over the thread hole so that the bending happens higher up on the hanger. You could check the result by holding a straight edge on the dropout and seeing that the hanger is at least in line with the dropout.
Much better to find someone with a hanger alignment tool though.
Retro Grouch
Bikes: Yes
Good point by all. If the OP is confused by "spanning the hole", jolly-ross is explaining it here. The weakest points of the derailleur hanger are on either side of the threaded derailleur hanger hole. Make sure the jaws of the wrench are large enough to cover the hole and the metal on either side and some metal on top of the hole, so it will not bend at the middle of the hole..
and that takes the dropout being a parallel plane in all axis
to the wheel and center-line .. up/down., fore /aft.
you may get it close enough to have one gear to ride it into the bike shop, careful not to shift into the spokes ..
and then pay a few$ for them to make it right.
Being Bikes Direct , you can Return, that one, and have them ship another one
and hope the handling is better in transit next time .
might be able to make a damage in shipping claim against the shipper, to recover those costs,
... but that would take more documentation to argue your case.
Liked 3,857 Times
I would never suggest a replaceable Al. hanger be straightened without the axle in place. To try without something in the drop out can very easily allow the hanger to bend/break at it's weak point which is likely where it's mounting bolt is located. often the hanger is only half as thick in the section surrounding the axle slot and above to the top. In this thinner portion sits the hanger mounting bolt. So without bolting (usually thought as having the wheel in place) the two (the hanger and the drop out) together the straightening action might just transfer the bending point to a portion of the hanger you really don't want to stress.
The simple solution is to reverse the wheel so the non drive side of the wheel (without the cassette) is on the frame's RH side. This both secures the hanger and drop out as well as allows enough access to the hanger with a wrench to fully cover the der mounting hole. Or another option is to take any bolt (or old axle) and use it to tie together the hanger and drop out via the axle slot. Andy.
mstateglfr
Bicycle Mechanics
9
12-09-15 06:07 PM
MightyLegnano
Bicycle Mechanics
3
05-18-12 07:06 AM
