Protecting new paint
I wondered if anyone had experience with applying helicopter film to either newly repainted frames or new steel to protect and preserve the finish. I am considering something like this for my Colnago. The one i have in mind is a polyurethane film but it is a permanent film and so I am not sure I want something on there that I won't be able take off without ripping the paint off with it. Are there other options ? Does this stuff really work? I also am not sure how good that adhesive on these films is for the paint anyway. Any thoughts would be appreciated.
Quoted: 454 Post(s)
Liked 104 Times
Did it a few years back to a new steel frame, if doing it now, and the bike was expensive, would be looking at somewhere which used the same stuff (PPF) as they wrap high end/exotic cars with, as 'helicopter tape' is pretty generic now, there are lots of brands, of different value/spec.
You mention the film is permanent, would really be looking for a removable film, as if it's ever damaged/you badly apply it, your in trouble if it needs replacement.
XPEL springs to mind as a brand to look at; would also look to see if anyone near you does it professionally, as this may end up being a cheaper/similar cost option to doing it yourself/for the quality of finish.
Quoted: 241 Post(s)
Liked 232 Times
The stuff works well. Effetto Mariposa Shelter Road is a pre-made kit for a road bike. I've put them on a couple of customer's bikes, you can barely tell they are there. Can't say how well it comes off but they claim it is removable.
Shimano Certified
Speaking from experience with the afore mentioned films in my aircraft dealership job, I can tell you they are very clear and sometimes imperceptible when installed WELL. Research techniques for proper installation. The downside is when you get enough sun it can begin to yellow slightly. That would be starting to show on some of our customer's 3-4 yr old aircraft that have been in the South Carolina-florida range. When it comes to repairs, you would have to remove it completely to repair a damaged paint area which can be a royal handful.
Most importantly, make double sure it is cured long enough. At least 90 days is a requirement unless certain conditions are met. Without that much time involved it will cause outgassing to be trapped and work as a paint stripper between layers as well as preventing long term curing and hardness which can take a couple months depending on the paint system used.
I will be using that on my recently redone trail bike on the downtube ding area and toptube but having been painted in Nov I will be waiting until at least Mar/Apr to be sure.
On yer bike
I've used the 3M auto stuff on a few bikes in high wear areas, and it can be removed without damaging the paint. When applied correctly it is more or less invisible and it is really tough stuff. I had a rock kick up and hit and there was a gouge in the film but it didn't tear through it. If that had hit bare paint it would have chipped it for sure.
Related to what the poster above mentioned, another side effect is that some films protect the underlying paint from UV and general exposure so well that if you pull the film off after a while there can be a sharp line between the exposed and protected paints.
Quoted: 1438 Post(s)
Liked 1,092 Times
Do what my surfer buddy did with all of his new surfboards: knock it against the corner of the house to get the first ding over with so you don't need to worry about it anymore.
Quoted: 839 Post(s)
Liked 1,064 Times
If going with some brand of Urethane Tape make sure you get the "Outdoor, UV resistant" type, otherwise it will turn yellow and become brittle.
Quoted: 454 Post(s)
Liked 104 Times
There is a (promo) video here from a UK wrapping company, skip to about 30 secs o where you see what their doing, The process should be the similar regardless of where you are in the world.
Quoted: 4212 Post(s)
Liked 3,881 Times
My experience with various sporting (and machine tooling) goods that have been covered with various clear "protective" tapes is that after a while you wish you had done something different. Things happen, the covering gets scuffed, gritted, grimed, lube discolors it. Shoes scuff stays, crotches touch top tubes, cables/casings rub tubing, knees brush tube sides, and more. If you transport your bike via a car expect more contact points to show.
If you were looking for a short term protection that you could remove to then resell the bike (after initial use) then maybe this would be worth it. Still the removal will be a real hassle. Andy
AndrewRStewart
AndrewRStewart
Quoted: 569 Post(s)
Liked 589 Times
Heft On Wheels
Quoted: 887 Post(s)
Liked 560 Times
I sort of have the same approach. I ride it very VERY soft until I get the inevitable scratch or ding then I ride it like it was meant to be ridden. Once the first one comes the honeymoon is over. Only I don't do the scratch on purpose, that is hard core!
