Go Back  Bike Forums > Bike Forums > Long Distance Competition/Ultracycling, Randonneuring and Endurance Cycling
Which of these two tires is best for beach at low tide?
Long Distance Competition/Ultracycling, Randonneuring and Endurance Cycling Do you enjoy centuries, double centuries, brevets, randonnees, and 24-hour time trials? Share ride reports, and exchange training, equipment, and nutrition information specific to long distance cycling. This isn't for tours, this is for endurance events cycling
Old 06-23-19, 06:19 PM
AllWeatherJeff
Old Dog, New Tricks
Quoted: 37 Post(s)
Liked 5 Times in 5 Posts
Left: wtb Horozion 650b x 47mm
Right: Clement X'plor mso 650b x 50mm
I will be covering 15-20 miles of beach sand at low tide and riding near the water where the sand will be firm.
Slicks or All Terrain?
Ideal Psi range?
Thanks!
AllWeatherJeff is offline
Old 06-23-19, 07:24 PM
StephenH
Uber Goober
StephenH's Avatar
Quoted: 184 Post(s)
Liked 25 Times in 22 Posts
I'd vote for the knobby. But I doubt it'll actually make much difference.
StephenH is offline
Likes For StephenH:
Old 06-24-19, 08:34 AM
JaccoW
Tinkerer
JaccoW's Avatar
Quoted: 429 Post(s)
Liked 293 Times in 191 Posts
Another option is the Schwalbe G-One. That one was designed for Dutch and Belgian beach races and will work pretty well as a gravel tyre as well.
JaccoW is offline
Old 06-24-19, 08:45 AM
rhm
multimodal commuter
rhm's Avatar
Quoted: 1668 Post(s)
Liked 127 Times in 96 Posts
It really depends on the sand. The sand on Long Island's barrier island (Fire Island) where I've tried this, is simply too soft to ride a bike on. You can go a while, but when you hit a soft spot you sink immediately. No fun.
I hear down south they have better sand.
The knobs won't make any difference, I'd go with the smooth tread, and pressure can be very low. Let some air out when you get to the beach, pump up again when you get back on the road.
rhm is offline
Likes For rhm:
Old 06-24-19, 09:07 AM
AllWeatherJeff
Old Dog, New Tricks
Quoted: 37 Post(s)
I've heard good things about the Shwalbes you recommend. However, I already own the two types of tires in th OP. So those are my only choices for this particular ride.
Odd that I lived near beaches in Cali for decades, and rode all over the place, but I've never ridden on a bike on the beach.
Old 06-24-19, 09:10 AM
DrIsotope
Non omnino gravis
DrIsotope's Avatar
Quoted: 4497 Post(s)
Liked 1,039 Times in 625 Posts
Well, the Koga Beachracer comes fitted with Schwalbe Big Ones, so I don't think tread really matters. The widest slick you can fit seems to be the way to go.
DrIsotope is online now
Old 06-24-19, 09:16 AM
OneIsAllYouNeed
Long-term wear tester
Bikes: Cycles Chinook travel/gravel/family tandem, KHS CX200 road/gravel, Voodoo Agwe fixie commuter, Gunnar Sport travel/road, Motobecane Boris fatbike
Quoted: 221 Post(s)
Liked 14 Times in 13 Posts
Psi: <20. Unless you're on a fat bike, I'd cram the widest possible tire into the frame. Tread in the corners can improve flotation on sand once you've maxed out the tire casing size.
OneIsAllYouNeed is offline
Likes For OneIsAllYouNeed:
Old 06-24-19, 09:40 AM
AllWeatherJeff
Old Dog, New Tricks
Quoted: 37 Post(s)
The sandy stretch will be the final leg of a 300k ride from Philly to Chincoteague, VA. The beach in question is Assateague Island (yes, that's the actual name) along the northern coastline of Virginia. I should be hitting the Assateague just as afternoon low tide is settling in. I've no idea what the sand is like on that beach though.
Old 06-24-19, 10:11 AM
rhm
multimodal commuter
rhm's Avatar
Right, I think I've heard that that beach is good for riding. No first hand experience, but I think you'll be okay.
At any rate, choose the tire that's best for the majority of the ride. I assume that's the smooth one.
If the beach is bad for riding, it will slow you down occasionally, but you'll probably be able to ride most of the way. If you have to get off and walk two or three times, no big deal.
When's this ride? I hope you'll report back, I'd like to hear how it went.
rhm is offline
Ursa Minor
Beach Cruisers
84
12-26-19 06:40 PM
Hondo Gravel
Fatbikes
23
02-28-18 11:22 PM
DaytonaDuke
General Cycling Discussion
4
04-25-15 11:07 PM
MrMJS
Hybrid Bicycles
2
04-10-11 01:07 PM
Mondoman
Mountain Biking
6
10-22-10 10:25 PM
