Chain rubbing against FD
Old 07-01-19, 08:06 PM
amazinmets73
Quoted: 169 Post(s)
Liked 25 Times in 19 Posts
I had a local bike shop wrench build a bike up from scratch. Upon taking it out on its maiden voyage I discovered the chain was rubbing against the FD. I returned to the shop explained the issue and some adjustments were made. Next ride started off with no rub until I took the bike off tarmac and onto a rough fire road.
What can I do to stop the issue?
amazinmets73 is offline
Old 07-01-19, 08:30 PM
Last ride 76
1/2 as far in 2x the time
Last ride 76's Avatar
Bikes: Yes, Please.
Quoted: 499 Post(s)
Liked 285 Times in 222 Posts
Depends on what's causing it. Seriously. Cross chaining? Not feathering it properly? Cable stretch? In what front/rear gear combinations does it rub? More information needed.
Last ride 76 is offline
Likes For Last ride 76:
Old 07-01-19, 09:25 PM
amazinmets73
Quoted: 169 Post(s)
OK I'll call the shop tomorrow and ask
Old 07-01-19, 09:41 PM
fietsbob
Bikes: 8
Quoted: 7607 Post(s)
If you had a friction shift lever you just move the lever to stop the scraping by fine tuning the cage position.
fietsbob is offline
Likes For fietsbob:
Old 07-02-19, 08:35 AM
Wilfred Laurier
Señor Member
Wilfred Laurier's Avatar
Quoted: 649 Post(s)
Liked 292 Times in 215 Posts
And if a frog had longer legs he wouldn't bump his ass a' hoppin'.
As much as I appreciate you have many years of experience with bicycles, lots of your comments are the curmudgeonly 'back in my day' type, and are not particularly helpful.
Wilfred Laurier is offline
Likes For Wilfred Laurier:
Old 07-02-19, 09:25 AM
fietsbob
Bikes: 8
Shimano's left bar end shifters remains friction.. 8 & 9 speed indexed right side ( 10 & 11 i stopped worrying about)
fietsbob is offline
Old 07-02-19, 09:33 AM
ridelikeaturtle
ridelikeaturtle's Avatar
Bikes: Bianchi Ti Megatube; Colnago Competition; Planet-X EC-130E; Klein Pulse; Amp Research B4; Litespeed Catalyst; Trek Y11
Quoted: 605 Post(s)
Liked 480 Times in 260 Posts
I'm not sure how the shop is supposed to know the answers to those questions - you're riding the bike, after all!
Often you can just 1/2 or 1/4 shift the front derailleur and eliminate any rubbing depending on what gear combination you're in. Basically, just slightly moving the front derailleur so it doesn't rub the chain.
ridelikeaturtle is offline
Old 07-02-19, 09:42 AM
robertorolfo
robertorolfo's Avatar
Bikes: 82 Lotus Unique, 86 Lotus Legend, 88 Basso Loto, 88 Basso PR, 89 Basso PR, 96 Bianchi CDI, 2013 Deda Aegis, 2019 Basso Diamante SV
Quoted: 943 Post(s)
Liked 172 Times in 113 Posts
As others said, you have to indicate when it happens, and what equipment you are running.
This doesn't help at all, while on the off chance that the OP is running friction, Fiets post will be perfectly helpful.
robertorolfo is offline
Old 07-02-19, 09:53 AM
CyclingFool95
Bikes: 1987 Pinarello Montello, 1996 Litespeed Classic, 1996 Colnago Master Light, 1997 Litespeed Ultimate, 2006 Opera Leonardo FP, 2006 Pinarello Paris FP, 1984 Pinarello Record, 89-ish Cornelo Profilo
Quoted: 148 Post(s)
Liked 119 Times in 73 Posts
For that matter, what groupo are you running? I find Campy 11 is incredibly finicky to set up right but Campy 8, which has about 8 click stops, is cake.
Are you running the right derailleur and chain for the number of speeds? Ie, are you trying to run a triple front with a double derailleur, or a ten speed derailleur with 8 speed chain? Is the chainring jump appropriate for the derailleur - if you're trying to run 16 tooth with an old derailleur meant for 11-13, you might get some issues.
CyclingFool95 is offline
Old 07-02-19, 09:58 AM
Phil_gretz
Zip tie Karen
Phil_gretz's Avatar
Quoted: 1465 Post(s)
Liked 1,542 Times in 806 Posts
Maybe a little more information on what the bike is, and what its gearing is? If the left side is friction, then Bob has it right. If indexed and a triple, then there may be a more complicated adjustment issue. Also depending on whether there are trim settings on the shifter or not.
Phil_gretz is offline
Old 07-02-19, 09:59 AM
Phil_gretz
Zip tie Karen
Phil_gretz's Avatar
... a local bike shop wrench build a bike up from scratch...
Please - more specifics about the bike, chainset, gearing and shifters?
Old 07-02-19, 01:41 PM
Last ride 76
Bikes: Yes, Please.
Quoted: 499 Post(s)
Facepalm here...
I just figured out where the problem is... The shop BUILT the bike. He went in and TOLD them the issue with rubbing FD... If I'm the wrench who built the bike up, I would have the OP show me what he's doing when the rubbing occurs, and then go through all guesses in this thread as needed... including feathering! We're all trying to do it long distance, without even having pictures. May I suggest that you go back to the shop once more, and explain that the problem still exists to some degree, and maybe he can show you how to manage the FD positioning, or cross chaining or... or... etc. Probably take a grand total of 5 minutes (maybe 10) - unless there is a real mechanical problem, in which case, he ought to be fixing it anyway.
Old 07-02-19, 03:09 PM
amazinmets73
Quoted: 169 Post(s)
11 speed Campy potenza. 10 speed centaur crank with 11-speed 28 tooth Ultegra cassette
Sy Reene
Bicycle Mechanics
2
05-06-17 05:30 AM
rms13
Bicycle Mechanics
3
08-11-14 04:58 PM
TromboneAl
General Cycling Discussion
9
02-21-10 07:05 AM
thegunner
Bicycle Mechanics
6
02-02-10 03:33 PM
ahson
Bicycle Mechanics
6
12-14-09 01:45 AM
