Goggles
Bikes: Devinci Millenium, Gary Fisher Joshua
Quoted: 73 Post(s)
Liked 29 Times
Goggles
Hi,
I always bike with goggles for obvious reasons from safety to comfort.
I find a lot of googles don't last long because they are soft plastic and at some point the lens is too blurry. Plastic polish helps a bit but......
Has anyone found goggles that will take rearview mirrors and are durable and have a great field of view?
BTW I use a Take-A-Look mirror.
Quoted: 4559 Post(s)
Liked 2,802 Times
Have you tried ski goggles? Good ones aren't cheap but may work better. I haven't found any utility goggles in hardware stores that worked well for bicycling.
Look for lenses that meet safety standards agreed upon by ANSI, ISO, ISEA. Usually those will be tough enough to resist scratching and scuffing longer. Or look for safety glass rather than polycarbonate.
There are also some retro style cycling and aviator goggles, the type with separate lenses for each eye for that classic bug-eye look. Might be easier to fit a mirror. Good ones will be pricey.
I mount my Take-A-Look mirrors on my helmets, since I switch glasses often. There's a little trick to using the Take-A-Look on a helmet:
This will leave enough wiggle room to adjust the mirror stalk to suit my riding positions on my upright hybrid and road bikes, with or without a bandanna on my head (usually with). However I can't wear a cycling cap under my helmet -- no matter how I adjust it the bill either blocks my mirror, or forces the helmet so far back on my skull that I can't see the mirror. I don't care for cycling caps anyway.
There are other mirrors better suited to helmets, with articulating support arms. But I like the smaller Take-A-Look and this mounting method works well for my helmets. Most other helmet mirrors are too large and would block too much of my view.
- Cut out a stiff plastic card to substitute for the eyeglass earpieces. Those junk membership cards from grocery stores work well.
- Cut it to fit a space inside the helmet, usually between the EPS foam and MIPS support or liner.
- Zip tie the mirror to the trimmed card.
- Zip tie the entire rig to the helmet itself, through the vents.
Quoted: 73 Post(s)
Liked 29 Times
Wow canklecat,
excellent suggestions! I just lost my mirror so when I get my new one I will try that. I could not figure out a sensible way to mount the mirror to the helmet but you have. I tried clipping it to the sun visor but no luck.
The issue I have with ski goggles is that they don't have great peripheral vision.
I like your suggestion about looking for approvals ANSI etc. and safety glasses rather than goggles. I don't mind spending the money if they will last because when they get foggy, I just get too lazy to throw them away and so put up with it till I have a scary situation happen.
The other thing I considered is getting the plastic flat pieces that wrap around the front like chopper pilots have. I haven't seen a sensible setup yet tho. I worked with chopper pilots who had the fighter pilot style helmets that the lens slipped up into the helmet when not in use. That would be the penultimate. Hang glder helmets can be like that.
Quoted: 18397 Post(s)
Liked 15,494 Times
Goggle=comfort? Does not compute. Does not compute.
Quoted: 73 Post(s)
Liked 29 Times
Comfort means no wind blasting everything from dry, sandy air full of bees, wasps, pebbles flicked up by cars and bikes, not to mention even branches from bushes on the side of the road, especially at dusk, you name it into my face.
Years ago I bought one of the early full face motorcycle helmets. One day I was driving when a big honkin bee hit my face shield. I made a big bang that kind of shocked me. I thanked God for that full coverage helmet face shield. Goggles are as important to me as a helmet.
Quoted: 5223 Post(s)
Liked 3,579 Times
what goggles are you using now?
Quoted: 551 Post(s)
Liked 277 Times
Wiley-X SG1
Liked 3,579 Times
I tried sky diver goggles but they fogged. I drilled vent holes but they still fogged. for blizzards I wear ski goggles with the vent foam removed. for fair weather, I use shop glasses. last summer I got a helmet with w flip up face shield. that was fun but now I need more ventilation so I'm back to shop glasses. I think on sunny days tho I should wear sunglasses
Liked 2,802 Times
Here's how my helmet mirror is mounted. Easy setup, works well.
For eye protection, I use Radians bifocal safety glasses, dark and clear lenses. They work well enough. The brow frame can obscure my view slightly when I'm in the drops. I have another pair of plain frameless sunglasses, no reading lens.
Take-A-Look mirror on Bell Formula MIPS.
I'll add this but I'm not proud. I got a great pair of wrap sunglasses at Walmart for 12 bucks. Foster Grants. Fits my face pattern/eye sockets really well and the wrap around lens really seals my eyes off to "debris." Excellent peripheral vision. Good lens too although I'm certain it's plastic. Clean vision with the right tint. I like them so much, here they are.... wink.
Likes For BirdsBikeBinocs:
So far this year I've been missing winter riding because this past February and March I was riding with ski goggles and a ski mask for some of the very same reasons that the OP cited, save one: I can't take the heat and sweat like a stuck pig. Sweat literally rolls down my brow and into my eyes. This was a non issue in the winter because A: I don't sweat as much in the winter, and B: the padding around the goggles kept any trickle from going into my eyes.
Sure, I got a lot of laughs from joggers on the local MUP but I found winter riding much more enjoyable this year than I did even during the heat of summer.
Quoted: 1109 Post(s)
Liked 1,200 Times
Do a web search for cross country ski goggles. They're not as natty, nor as cheap as shop goggles, but they are made for athletic activities and have high quality lenses.
Doesn't surprise me that you have problems with shop goggles getting cloudy/scratched up. They're usually made with cheap plastic because they're cheap and intended to be more or less disposable.
Likes For Camilo:
Likes For fietsbob:
No, but BBB was merely pointing out that maybe OP is getting goggles based on an invalid assumption ( that they are needed to keep dust/wind out of eyes.) Wraparound sunglasses would do the same job but probably last longer. It's why most of us use them instead of... goggles.
Likes For BlazingPedals:
Disco Infiltrator
Quoted: 3126 Post(s)
Liked 2,102 Times
I had some goggles for motorcycling. Seldom used them because I live in a helmet-law state. They had one lens for each eye and a single layer of foam behind them rather than double-pane ski goggles. Mine had a headband but you can get similar with frames like glasses that would take the mirror. Like this https://www.revzilla.com/product/bob...les-sunglasses
Genesis 49:16-17
Genesis 49:16-17
Quoted: 800 Post(s)
Liked 218 Times
Hi,
I use prescription sunglasses, but any wind hitting my eyes causes them to tear up so I still need a windshield.
I perennially post about my winter eyewear for my 14 mile year-round commute, from about 35° down to as low as 0°. I must wear my prescription eyeglasses, and fogging is one of the worst dangers of winter riding. I am entirely satisfied with my system:
…for eye protection is a pair of simple, wide, plastic industrial goggles that I suspend from my cycling cap using Velcro around the nosepiece. The goggles sit very comfortably on my face securely in place even though my ears are covered. The earpieces then provide a secure mount for my eyeglass-mounted Take-a-Look mirror.
The goggles allow sufficient room for my prescription eyeglasses, and are widely ventilated to carry away the exhaled moisture preventing fogging.
Comfort means no wind blasting everything from dry, sandy air full of bees, wasps, pebbles flicked up by cars and bikes, not to mention even branches from bushes on the side of the road, especially at dusk, you name it into my face…
Damn the abrasion, full speed ahead.
Today is day three after onset of my corneal abrasion, and I was scheduled for a 59 mile ride for my 10 week century training program. By day number two I felt fine with occasional relapses of slight irritation, and I really needed the long ride.
So I donned my winter cycling safety glasses for further eye protection beyond my usual perscription eyeglasses, and left Kenmore Square... [but on a later ride]
… I think my brand new eyeglasses made the gash (about 1 inch long requiring 18 stitches to close).
Ironically, since I had a corneal abrasion a few weeks ago I have been wearing goggles over my eyeglasses and I have to wonder if the goggles pushed the eyeglasses into my face.
The frames were pretty damaged and unwearable though I had a spare pair in the car…
Likes For Jim from Boston:
Quoted: 5 Post(s)
Hi,
Likes For Paul Ko:
DTownDave22
General Cycling Discussion
21
10-19-20 06:07 PM
Cyclist0108
Advocacy & Safety
8
03-05-17 09:15 PM
Bumer
Road Cycling
65
09-28-12 01:31 PM
