Figuring out whats wrong with my saddle fit
Hi all,
I got a new bike, a Trek Checkpoint ALR5, and it comes with a Bontrager Montrose Comp saddle, 138mm wide. I've never given much thought to saddles as none really bothered me, but this one is bugging me. I'm 6'4 and I measured my sit bones and i get around 112-115mm center to center. I did this by sitting on aluminum foil on carpet.
Two things are wrong, one is just general achyness up in my pelvis. The second is that it often feels like i'm shifted to one side or the other and like i need to shift to the other side. My hypothesis is that the seat is too narrow and it can't span to reach both sit bones at once. However, i think my other bike saddles are in this width range (i'll check) and i have no issues there.
Any ideas on how to troubleshoot this so i can try and pick out a better option? Thanks
Ha, i should add that i no longer have any other road bikes (or their saddles) and my only other bike is a mountain bike. It has a comfy saddle, but its also a more padded mountain bike type saddle and i don't sit on it for as long as when on my road bike.
Quoted: 7348 Post(s)
Liked 2,465 Times
Get a saddle like the one you had on your previous road bike.
I knew there'd be more to it
Just guessing, but if I were you, I'd go to a bike shop to get your sit bones measured. I'm 6'4" and weigh 198 and my sit bones are 130 from Specialized Assometer.
Quoted: 663 Post(s)
Liked 496 Times
In general a saddle that is too narrow is more likely to cause discomfort than one that is too wide. The area that will cause problems is the area just ahead of the sit bone location where the saddle narrows down. That area needs to match the width between the legs right at the crotch. If the saddle is too wide there it will be uncomfortable.
Quoted: 1034 Post(s)
Liked 1,290 Times
Hi all,
And this one explains what I just stated regarding compensating by dropping to one side. https://www.stevehoggbikefitting.com...d-can-it-be-2/
Likes For phughes:
I sounds like a classic case of one sit bone sliding off the edge. I think you've mismeasured your arse. 138mm is very narrow for someone your size. 155mm is probably what you require.
Quoted: 359 Post(s)
Liked 85 Times
Honestly this @rse measuring BS is another Specialized marketing w@nk (probably something they came up with to try and make up for their sh1t fitting system). I am 6'3" and 185lb. My SMP Composit saddles are 130mm wide at their widest point. I have had hip pain in the past until I dropped my saddle 6cm from where the Specialized "expert" set it. Hip Pain gone.
multimodal commuter
Quoted: 1908 Post(s)
Liked 574 Times
I agree with the suggestion that your saddle is (was) too high.
Saddle width --and especially "sit bone" width-- is not completely irrelevant, but I don't think it's nearly the important measurement that some people think. Look at a classroom skeleton sometime (not a Halloween skeleton). The "sit bones" are shaped kinda like the rails of a rocking chair, but backwards. Their "width" depends on the rider's position. If you sit upright, your weight goes into the sit bones at their widest point; as you pivot your pelvis forward your weight moves to a place where the sit bones are closer together.
Once you have saddle height, stem length, handlebar height, brake lever position &c nailed down, and you're pretty confident of your favored riding position on the bike, you can figure out your sit bone width. Until then, though, forget about it. It's not important enough.
Likes For rhm:
str8jakett
Road Cycling
17
12-15-18 02:56 PM
Wheever
Fitting Your Bike
37
02-12-18 12:16 PM
