Cannondale ST500 Chainstay Issue
Old 01-08-20, 07:50 PM
jrg1244
Bikes: 2010 Cannondale CAAD 5 Potenza 66cm, 1984 Basso Gap Nuovo Record 65cm, 1989 Cannondale ST Racing Triple 27", 1974 Schwinn Paramount Nuovo Record 26", 198? Scapin MKII 66cm Victory, 1994 Havnoonian Chorus 8sp 27"
Quoted: 45 Post(s)
Liked 100 Times in 43 Posts
Ugh... I finally found and recently bought a 27" 1986 Cannondale ST500 frame on fleabay and received it just today. When I unwrapped the frame, which was packed quite well, I noticed what looks like tire rub on the inside of the DS chainstay. The issue is that it looks like some serious aluminum is missing, I don't even understand how a rubber tire could have caused this. I tried to take a picture at an angle where the missing metal could be seen. The rest of the frame is in decent condition and I was planning to media blast/powdercoat it anyways. I guess my question is this... Is this frame toast? Would you guys ride it like this? The damage wasn't disclosed in the auction, so I may have some recourse with the seller or paypal, we'll see.
jrg1244 is offline
Old 01-08-20, 08:31 PM
speedevil
I never finish anyth
speedevil's Avatar
Bikes: 2008 Merckx LXM, 2003 Giant XTC mtb, 2001 Lemond Alpe d'Huez, 1997 Lemond Zurich, 1989 Cannondale ST, 1988 Masi Nuovo Strada, 1983 Pinarello Turismo
Quoted: 294 Post(s)
Liked 137 Times in 86 Posts
The early ST frames did not have dimpled chainstays are as a result cannot handle as large a tire as the later models.
It's not so much the rubber wearing away the alloy, it's the grit on the tires from riding on the road that does the damage. If it were me, I'd probably ride it. But since you do have recourse and are concerned about it, the best long term solution is to return it and find an undamaged frame.
Dale, NL4T
speedevil is offline
Old 01-08-20, 08:47 PM
scarlson
scarlson's Avatar
Quoted: 964 Post(s)
Liked 1,451 Times in 723 Posts
I don't know if I'd even ride it.
What is that darker spot in the middle of the rub-mark? Possibly a place where it's worn so paper thin that it is bending and near-through?
This just happened on my friend's Cannondale, which he now calls the Crack 'n Fail (rhymes with Cannondale)
See how the darker spots in the center of the wear are paper-thin aluminum, just about to wear completely through? And note the crack starting at the holes and spreading. It was nearly halfway around when he stopped riding it.
He rode it with a broken axle and a few broken spokes for some time. Now he has a Litespeed (and a new wheel).
You can't weld these, says my welder friend. He has the impression that they were welded in the beginning, and then the whole frame was heat-treated. Welding on them removes the heat treatment from one spot, which seems like a bad thing to do.
scarlson is offline
Old 01-09-20, 06:40 AM
old's'cool
curmudgineer
old's'cool's Avatar
Bikes: 2 many 2 fit here
Quoted: 263 Post(s)
Liked 112 Times in 70 Posts
Whether paper thin or not, the thin spot is a stress concentration and guaranteed site for crack initiation.
old's'cool is offline
Old 01-09-20, 06:56 AM
sdn40
Bikes: 88 Cannondale Criterium
Quoted: 291 Post(s)
Liked 146 Times in 91 Posts
Don't make compromises based upon the rarity of finding a 27" frame and the pia factor of sending it back. Life's too short to be worried about every creak and bump ..... and you probably will.
sdn40 is offline
Old 01-09-20, 07:05 AM
pastorbobnlnh
Freewheel Medic
pastorbobnlnh's Avatar
Quoted: 1451 Post(s)
Liked 2,183 Times in 960 Posts
Not far away from you in Bellows Falls, VT is frame builder and an extraordinary craftsman, Frank the Welder. My recommendation is to contact him and send your pictures and ask if this could be repaired. Finding a 27" Cannondale frame (I'm assuming you don't mean wheel or tire size) is not and easy task. Maybe the ebay seller would refund part of your purchase in order to offset the cost of repair.
Bob
pastorbobnlnh is offline
Old 01-09-20, 07:13 AM
shelbyfv
Expired Member
shelbyfv's Avatar
Quoted: 3646 Post(s)
Liked 5,377 Times in 2,729 Posts
That's a significant amount of material missing. I'd send it right back.
shelbyfv is offline
Old 01-09-20, 08:28 AM
jrg1244
Quoted: 45 Post(s)
Yup. Upon much closer inspection, it appears that the darker spot in the middle is literally paper thin and looking closer at a more head on angle, a tiny hole that goes clear through the tube can be seen. I think I have an answer. This frame isn't worth building up. Back to searching for my 27" ST!
Thanks for the thoughts and guidance in this.
jrg1244 is offline
Old 01-09-20, 11:41 AM
shoota
shoota's Avatar
Quoted: 1872 Post(s)
Liked 692 Times in 468 Posts
Not to poo poo on your friend but he didn't make that nickname up
2019 Salsa Warbird
shoota is offline
Likes For shoota:
Old 01-09-20, 02:57 PM
Chr0m0ly
Chr0m0ly's Avatar
Bikes: '84 Miyata 610 ‘91 Cannondale ST600,'83 Trek 720 ‘84 Trek 520, 620, ‘91 Miyata 1000LT, '79 Trek 514, '78 Trek 706, '73 Raleigh Int. frame.
Quoted: 684 Post(s)
Liked 370 Times in 219 Posts
This looks like a 27 https://www.ebay.com/itm/Vintage-Cannondale-Sport-Touring-Bicycle-Barn-Find/283734554116?hash=item420fe5b604:g:hMcAAOSwMAxd3JNv
Chr0m0ly is offline
Old 01-09-20, 03:11 PM
jrg1244
Quoted: 45 Post(s)
By George, I think you're right! Thanks for the head's up. My search didn't turn that one up. Wish me luck!
jrg1244 is offline
Old 01-09-20, 06:38 PM
RiddleOfSteel
Master Parts Rearranger
RiddleOfSteel's Avatar
Quoted: 1556 Post(s)
Liked 2,023 Times in 989 Posts
If it is indeed a 1983, and the RD and other components say as much, they didn't offer a 27" (68cm) frame yet. That would come a few years later. A 1983 frame is pretty special, IMO, but it appears to be a 25" (which is my size, haha)
@hazetguy posits a solid option. Cannondale aluminum is pretty thick, but that is a lot of wear to have happened. Really sorry to hear/see it as 27" frames [not 27" tires, for the rest of you reading] are really hard to come by. Great bikes--I want another after selling my '90 ST.
RiddleOfSteel is offline
Old 01-09-20, 07:36 PM
TiHabanero
Quoted: 1739 Post(s)
Liked 1,369 Times in 718 Posts
Cdales are heat treated after welding. Weld that hole with a reinforcing sleeve, maybe. Good question for Frank the Welder.
TiHabanero is offline
Old 01-10-20, 07:51 AM
sixer
Bikes: 1982 Mercian Vincitore, 2014 Fitwell DeGroot, 1999 Raleigh M80, 1968 Schwinn Stingray, 2002 Ibex Classic 3300, 1978 Kabuki Track
Quoted: 32 Post(s)
Liked 21 Times in 12 Posts
I wouldn't feel bad about passing on it. 27" ST Cannondale frames are rare, but not impossible to find - I bought two last summer within a few weeks of each other, but ended up selling both late last year. Winter may not be the best time to be searching for them. I know @ronno6 has several that he may be willing to part with if you're serious.
sixer is offline
Old 01-10-20, 10:00 AM
trailmix
trailmix's Avatar
Bikes: 50+/-
Quoted: 63 Post(s)
Liked 81 Times in 48 Posts
Originally Posted by Chuckk
Those REALLY BIG Cannondale frames make the proportions of the large frame tubes and tires seem like a normal sized sports bike!
My 23" 1990 Cannondale T700 - the tubes look really big
In 1990, they increased the size of the downtube significantly.
trailmix is offline
