Chain Slap
Quoted: 45 Post(s)
Liked 6 Times
Chain Slap
Any ideas on how to diagnose and fix chain slap?
Googled around and seeing most caused by a dirty derailleur. This is certainly not the case.
Bike is about a month old and meticulously cleaned and recently tuned. Also it doesn’t slap when hitting bumps as many googled articles return.
it’s reproducible while pedaling and suddenly stopping. Annoying yes. Became dangerous yesterday while sprinting. I was full gas so don’t remember the specifics. But I believe I may have paused to stand. The chain slapped and felt like it dropped but it didn’t. Sent the bike into a shimmy, I quickly recovered and hit it again.
I demonstrated to a mech on the ride and he had no idea. I was big ring up front little cog in the rear so no cross chaining.
thanks.
thanks.
I am potato.
Quoted: 1789 Post(s)
Liked 1,629 Times
You don't say what kind of bike. But on some level it doesn't matter. My guess is you have one of those ginormous 11-50 cassettes &/or a reasonably long cage derailleur.
What makes me think this is the sudden stop of drivetrain input after a hard sprint exposes the rotational inertia of the giant cogs & the decreased leverage the long lever (derailleur cage) has on the system.
If this is true, then your derailleur may have a clutch mechanism to help the weak lever component of your problem. Engage it.
The other option is to get a short cage derailleur to fight a high friction drivetrain like would be found on an IGH hub.
Another option is to not sprint, spin up all the heavy giant cogs, then suddenly stop the input.
Car dependency is a tax.
Bikes: SL8 Pro, TCR beater
Quoted: 988 Post(s)
Liked 584 Times
A month old? So you bought it brand new? What did your LBS say?
How stiff is your rear derailleur spring? Might be a manufacturing defect.
Yes to all the above. Also, check your “B” screw adjustment. Insure chain wrap around your small cog is not binding or too loose. Lastly, check your chain length for proper length. Might be a bit long.
Good luck!
Good luck!
Quoted: 4717 Post(s)
Liked 1,882 Times
I've seen massive cassettes cause this issue, especially when combined with new hubs that have slightly draggy freehub body seals.
Quoted: 45 Post(s)
Liked 6 Times
Thanks all for the replies. Answers to the above questions:
Not sure why the bike matters but its a Look 795 Blade RS.
I did get it brand new, but the shop I bought from is 2 hours away. I will be bringing to the local shop but would like an idea of what it is first.
I believe it is a long cage derailleur, the thing is huge, the cassette is 11-32, and its a full r8000 Ultegra groupset.
The wheels are Shimano RS 370. My regular wheels with my preferred cassette are at the manufacturer for a repair.
No workstand at home, but I can easily reproduce by picking the bike up, pedal forward a time or two and suddenly stop pedaling. Just tried this and it was on the middle cog.
To be more exact, i think its the backward motion when suddenly stopping to pedal that causes it.
Quoted: 45 Post(s)
Liked 6 Times
Liked 1,882 Times
When you lift the rear wheel, and slowly pedal backwards, does the wheel spin backwards?
Quoted: 3241 Post(s)
Liked 2,512 Times
OP better get a chainstay protector on there if it doesn't have one.
Quoted: 45 Post(s)
Liked 6 Times
This was part of the cause for the case that I saw. The owner had a very jerky stop to his sprint, and it caused the rear axle to flex slightly(and bind the freehub body). When I tested the bike with a smooth sprint, I didn't have the issue, but when I stopped sprinting the way the owner did, the chain would slap. He tried another wheelset, and the issue was gone.
when this happened on the sprint it was mid sprint. The sudden movement was me looking for more watts and I think standing, not when I first took off for the sprint.
Bikes: Nashbar Road
Quoted: 2934 Post(s)
Liked 341 Times
I don't see how inertia of the cog could have any effect on the chain slap. I would pause, or disregard, that avenue of investigation and look at the other suggestions: the chain, hub behavior, loose cogs and the DR arm action.
Quoted: 3375 Post(s)
Liked 5,513 Times
The one time I ever had this issue it was caused by a draggy freehub that was not disengaging promptly when the rider abruptly stopped pedaling.
Likes For Shimagnolo:
Bikes: Nashbar Road
Liked 341 Times
Rotational inertia is from all of the cogs together, and in my estimation the difference in total inertia from having a larger cog installed won't be enough to cause this by itself. Slapping in the small cog, you could probably take the big cog completely off and it will still slap.
Quoted: 45 Post(s)
Liked 6 Times
Thanks! I really don’t like those wheels. It would have been nice as backups, but my regular wheels were sent to the manufacturer on Monday to be relaced. Hopefully when they return all will be well. And hopefully that return will be in the next few weeks and not next few months.
Likes For Cypress:
Likes For inspclouseau:
Quoted: 10236 Post(s)
Liked 5,183 Times
hot
As others have said, the freehub isn't properly 'freewheeling'. Look at some YooTube vids and overhaul the freehub, it's not hard. If it's chain slapping, it's worth fixing.
Beautiful bike. I'm trying to deduct points for improper presentation, but everything appears to be in order. Valve steams vertically oriented, tire labels oriented to the valve stems, crank at 3:00 with chain in big chainring.....but I suspect your steerer needs to be cut 10 mm. Perhaps handlebars should be rotated up a smidge and the levers moved down that smidge.....and those crazy vertical slats make it harder to judge compared to a backdrop of a white garage door..... but nonetheless, a grand showing of a grand steed.
