Aluminium 700c fork
Aluminium 700c fork
Hello everyone,
I have been searching online for an aluminium 700c fork with 1 1/8" threadless steel steerer tube, straight blades and <£100 for literally days now. It is to replace my Jamis Ventura fork which is now bent having hit the bonnet of an uber driver emerging from a side road. With no luck I've now created a BF account to ask for help.
The only one I found was on santafixie website but 1) santafixie has a horrendous rating on trustpilot, 2) no side view is shown for me to check the small angle change at the fork crown/steerer tube and 3) they don't pick up their phone or respond to emails.
Any assistance will be greatly appreciated.
Cheers
Cheers
Señor Member
Quoted: 649 Post(s)
Liked 292 Times
Do you understand that straight blades are purely an aesthetic choice? If you want the fork to look the same then that's one thing, but if you just need the fork to work the same then you only need to match axle-to-crown length and fork rake. Rake on a straight-leg fork is handled by the legs coming out of the crown at an angle, while most curved-leg forks accomplish the same thing by curving toward the desired rake position further down. But if you mounted two forks with identical axle-to-crown and rake, but one straight and the other one curved, there would be no difference in function.
Ok - one small difference - if all other things are equal, a curved leg fork might give a slightly softer ride due to the slightly longer legs over which force is distributed. But this difference would be minor and there would probably be other differences between any two forks to make direct comparisons impossible.
Likes For Wilfred Laurier:
Señor Member
Quoted: 649 Post(s)
Liked 292 Times
The Jamis website has geometry charts for the current Vantura bikes. They list fork rake (which differs by frame size) but not fork length. Luckily fork 'axle to crown' length is much easier to measure than fork rake.
