Do you favor one foot forward for descending?
Taking cornering out of the equation, do you have a "stance" when descending long straight descents? When you're going too fast to pedal (for me, around 35 mph).
I noticed I default my right foot forward and put my weight on my left leg. If I hit a rougher patch of road and need to muscle through it, my right foot's always forward.
Left foot forward when not cornering feels pretty foreign.
Is it normal to have a preference? Just noticed I do this today. I switch it up cornering but then go back to right foot forward as a default.
Quoted: 4560 Post(s)
Liked 2,802 Times
Depends. If I'm going for speed and conditions are right (tailwind, sufficiently steep downhill, pavement not too choppy), I'll tuck and set the feet at 3 and 9 o' clock, knees in, etc. There's one particular downhill along one of my usual routes where coasting like that is as fast as, or faster than, my best efforts pedaling with 52/13 maximum gear.
Otherwise I seem to favor having one foot down at 6 'o clock, usually the right (?)... or is it the left? Now I'll need to go ride again to be sure which.
just another gosling
Quoted: 3889 Post(s)
Liked 1,938 Times
My cranks are horizontal, right foot forward. I think my pedals are equally loaded or my cranks wouldn't be horizontal. So level pedals, weight in my feet, knees gripping TT, hands in the crooks, elbows pulled in, chin low, easy to move butt off saddle for bumps.
Results matter
Results matter
Quoted: 40 Post(s)
Liked 9 Times
My cranks are also horizontal; right foot forward.
As for my hand position, I employ Niabli’s pt 1 approach with them in tight near the stem.
Then I add some Pantani with my butt off and behind the saddle with my zyphoid process on the nose of the saddle and chin hovering just above the steerer.
https://www.velonews.com/2018/07/gea...osition_473015
https://www.velonews.com/2017/05/new...-faster_437636
Quoted: 18883 Post(s)
Liked 10,646 Times
Left foot forward, even track standing through a light. Cranks horizontal.
Quoted: 451 Post(s)
Liked 364 Times
I aim for horizontal, but sometimes forget and end up with left at 6 o'clock for extended periods. Usually in the drops when going that fast, which is not that often.
Advocatus Diaboli
Quoted: 4733 Post(s)
Liked 1,532 Times
Horizontal, with left foot forward. Gives me the quickest access to jamming the coaster brake with my right foot (stronger).
Quoted: 1104 Post(s)
Liked 1,825 Times
I had the opportunity to work with Hans Rey on a project once and he gave me some pointers/instruction. His description of the leading foot was "your chocolate foot", meaning which one you like/feels the best for descending or trials work. For me it's my left foot forward, pedals at 3 & 9. I think it's because my right leg is a little stronger and it supports my weight better if I have to hover over the saddle.
Likes For nomadmax:
Horizontal, because I think it's more aero.
Left leg in front I think because I generally fight orthodox (and it carrys over to cycling).
Bikes: SuperSix Evo | Revolt
Quoted: 733 Post(s)
Liked 815 Times
Cranks horizontal, left foot forward, in the drops, elbows in and knees tucked against the top tube, no super tuck I'm big enough that I haul down any descent without getting too crazy. lol
Non omnino gravis
Try to go downhill fast? Cranks level, left foot forward.
Just going down a hill? Twelve and six, with the left foot (usually) at six.
Not that it much matters. On most of the steeper downhill segments locally, my faster times are all on my CX bike... because it has a dropper on it. Lowering or raising one shoe a few inches isn't as productive as moving the entire rider half a foot lower.
Globo Gym lifetime member
Bikes: Fast ones
Quoted: 410 Post(s)
Liked 614 Times
Cranks level, right foot forward while in a tuck. Outside foot in 6 o'clock position through corners.
Non omnino gravis
Likes For DrIsotope:
Not actually Tmonk
Bikes: road, track, mtb
Quoted: 2638 Post(s)
Liked 3,151 Times
I've had some accidents so I tend to get a bit scared over 35 MPH.... I'll be on the brakes.
"Your beauty is an aeroplane;
Likes For noodle soup:
Quoted: 479 Post(s)
Liked 277 Times
Everyone has a favored forward foot. I always thought "chocolate foot" was the same as "goofy foot" - just the less common foot forward. But who the %*#* am I to argue with Hans?!
So try this: make a habit of forcing the reverse - when the descent is easy, ride with your dominant foot back. The more you do this, the less awkward it feels... so when you're caught in that position, e.g. mid-stroke, and have to maneuver (bunny hop, hard brake, swerve, whatever), you're more comfortable.
Airplanes, bikes, beer.
Bikes: Road bikes, mountain bikes, a cx bike, a gravel bike…
Quoted: 398 Post(s)
Liked 788 Times
Road descents- like most everyone else, cranks level, either foot forward. Mtb- if descending in switchbacks or across a face (uphill on one side, drop on the other) I put the downhill side crank arm forward, to avoid rocks/roots/anything away from my uphill foot so that my line isn’t forced toward the “drop” side of the trail. Also, if I have to stop fast I find it easier to quickly stand on the downhill pedal this way and unclip the uphill foot to lean uphill as I stop, rather than trying to put a foot down over the edge of the trail. Either bike- outside foot at 6 o’clock in corners, a few quick pedal strokes, back to level, or the next corner... repeat til the finish line.
Quoted: 550 Post(s)
Liked 325 Times
Right foot forward.
I wonder if it's opposite of board sports, with goofy footers being left foot forward on bikes.
I'm goofy footed and right pedal forward (I guess also goofy biked). I've been trying to go switch this week more on the bike (thus the post). Glad I'm not alone! It feels like adding some symmetry could be a good thing.
Quoted: 4717 Post(s)
Liked 1,882 Times
FTR I can longboard switchfoot, but no chance on a 6'4" thruster.
