Recessed brake mount filler?
Bianchi Goddess
Quoted: 2930 Post(s)
Liked 2,925 Times
Hello. Doesn’t someone make a nylon filler to go in here?
Sugar "Kane" Kowalczyk
Bike Butcher of Portland
Bikes: It's complicated.
Quoted: 4682 Post(s)
Liked 5,800 Times
Why?
Mr. Anachronism
Quoted: 526 Post(s)
Liked 256 Times
If you have an Ace Hardware store near you, they should have a decent selection of black plastic and chrome push-plugs. I've also had good luck on Amazon, with some careful measuring of the desired head size.
Bianchi Goddess
Liked 2,925 Times
Because someone needs one.
I FOUND IT.
I FOUND IT.
Liked 5,800 Times
I'm curious. Was there a need to fill the brake binder hole (and thus not have a brake), or a spacer so that a non-recessed brake could be used? If the later, please share what you found, a lot of people would have a use for this. I don't recall ever needing one, but it would make sense.
Likes For gugie:
Quoted: 3810 Post(s)
Liked 6,699 Times
Yeah, I’ve bought them from Rivendell in the past, but I’m sure a good hardware store has a suitable nylon bushing.
Liked 6,699 Times
aka: Dr. Cannondale
Quoted: 2155 Post(s)
Liked 3,404 Times
Dia Compe also makes them. I have a pair somewhere left over from the 4 pack I bought a couple years ago when I built the Bianchi (with nutted NR brakeset) for the Eroica auction in 2018:
Likes For rccardr:
Likes For RobbieTunes:
Friendship is Magic
Bikes: old ones
Quoted: 26419 Post(s)
Liked 10,380 Times
Likes For 3alarmer:
framebuilder
This was a special rear brake bridge that was sold in the late 70's or early 80's (I can't exactly remember) with a special brass insert that just fit into that 1st recess. I remember them being a Cinelli brand item but of course they were probably sold under other brand names as well. I'm not where I can take a picture of what they looked like. I brazed them into a number of frames I or my frame building class students made back then. I remember being worried because when overhauling or repainting a bike they could be lost and there wasn't a supply of spares. If lost the whole bridge had to be bought again just to get that little part. Probably because that insert could be easily lost and costly to make, they weren't sold for too long of a time. However because brake bridges tend to be bought in volume they could have been used in manufacturing frames long afterward.
Of course there are other ways (some already mentioned) to turn an 8mm hole into a 6mm one. For example I have a lathe and know how to use it. However the original brass insert was pretty sweet.
Bikes: 1984 Miyata 310, 1986 Schwinn Sierra, 2011 Jamis Quest, 1980 Peugeot TH8 Tandem, 1992 Performance Parabola, 1987 Ross Mt. Hood, 1988 Schwinn LeTour, 1988 Trek 400T, 1981 Fuji S12-S LTD, 197? FW Evans
Quoted: 531 Post(s)
Liked 1,005 Times
I have one bike with nutted front brake that has what appears to be a Presta to Schreader valve stem adapter pressed into the rear hole in the fork crown.
Old fart
Quoted: 3588 Post(s)
Liked 3,400 Times
Ride, Wrench, Swap, Race
Quoted: 1565 Post(s)
Liked 1,296 Times
I would only use metal for any part that in any way sustains bolt tension or supports the caliper or stud.
You can't tighten against plastic and have it not compress over time, requiring repeated tightening.
Or am I misunderstanding the intent here?
I took a couple of cuts off a 6mmIDx8mmOD aluminum spacer to adapt nutted Superbe calipers onto my CAAD3, I think it was as simple as that.
Metal washers can be found in an infinite range of dimensions to fill the little counterbore.
Quoted: 1639 Post(s)
Liked 829 Times
Rivendell is mentioned quite often here for sourcing bike hardware.
Last year, I finally got to visit their place in Walnut Creek (A bit hard to find) and was surprised how sparse the place looked and there was not that much to see in terms of hardware and components. Just a couple of bikes kinda haphazardly parked in their entry space for display and a couple of small showcases with mostly literature and decals at that time. There were a lot of cyclists hanging around the front door, but it seems like most of them were just staging up for their morning group rides and were not really going into the store. Was also very surprised that they did not have the axle spacers I was looking for that day. I was quite perplexed and did not know what to make of Rivendell coming away from that visit. It sure fell off my list of bike places to visit/shop in after that. Maybe I just don't get what Rivendell is really all about?
