Threads repair
Quoted: 336 Post(s)
Liked 309 Times
Which threads? Although most of us cannot point you to a shop, knowing what threads are buggered might help. A water bottle boss thread is much different than a pedal or threaded headset.
Quoted: 4197 Post(s)
Liked 3,849 Times
Some shops can do crank arm pedal thread repairs with an insert. Some don't, likely most don't. I think your answer will be to call around and ask each shop. I would suggest the older shops first. Andy
AndrewRStewart
AndrewRStewart
Liked 3,849 Times
The issue with a machine shop is that they likely don't deal with 9/16" x 20tpi left handed threads often enough to have the inserts on hand. This is a thread spec pretty much bike industry only.
I sense a reluctance to call shops and find out yourself. Am I correct? Andy
AndrewRStewart
AndrewRStewart
Liked 3,849 Times
Sorry, it was my assumption that it was the LH arm. We see far more LH pedal thread issues then RH ones. Good luck. Andy
AndrewRStewart
AndrewRStewart
Quoted: 283 Post(s)
Liked 262 Times
I looked up your crank, holy cow! I thought an old DeoreXT crank was hot stuff. It looks like your crank is graphite with a threaded alloy block for the pedal. Just a thought, maybe SRAM does or has recommended vendors for repairs to that crank. Good luck with that.
Quoted: 2026 Post(s)
Liked 1,096 Times
Hows bad is the damage? If it's just the lead thread you may be able to "chase" it by threading the pedal in from the back side of the crank arm.
Thanks. good idea to contact SRAM to see what they say. and find out the cost for just arm replacement.
Quoted: 303 Post(s)
Liked 136 Times
Wow, 'someone' must have Schwarzeneggered a pedal install to do that. Most people stop after turning the pedal 1-3 threads
when cross threading, to go all the way is to ignore the 3-4x increased torque needed to cross thread a large thread.
Ability to repair with insert will depend on how big the alloy portion is, as the insert requires 2-3mm larger diameter hole which
is then threaded by the insert, so alloy block must be at least 4-5 mm larger than the 9/16 hole for the pedal.
Used to be Conspiratemus
Quoted: 297 Post(s)
Liked 245 Times
Mel Kornbluh at Tandems East in New Jersey advertises in his catalogue that he will repair stripped cranks, using Helicoil inserts. You could phone him and see if he can repair yours.
Quoted: 6188 Post(s)
Liked 4,806 Times
Is this a carbon crank? If so, the threaded part for the pedals might not like being drilled and re-threaded for an insert to be put in it. May just be an insert itself embedded in the carbon.
If your threads are badly damaged, then trying to run a same size tap through it is going to leave too little material to be a decent fix for long.
If it's only damaged at the starting thread or two, then maybe there is hope for just running a tap through it. Or if your pedals have a long enough threaded part to reach all the way through, run them in from the other side and hope they push the damaged part into a better position. Maybe use an old pair.
Old fart
Quoted: 3587 Post(s)
Liked 3,398 Times
Are the treads shot or is it the threaded insert itself that's spinning? Happened to me on my TT bike - had to epoxy the insert back in to the crank arm.
Likes For Atlas Shrugged:
Friendship is Magic
Bikes: old ones
Quoted: 26400 Post(s)
Liked 10,373 Times
...if it helps you, when you call around, this is the threading on a lot of older spark plugs. So places that machine and repair ICE cylinder heads often run into this issue, and might have some 9/16" 20 tpi helicoils on hand, and be willing to install one for you. They do make bicycle specific kits for this, but they run in the$100-120 range, so a lot of places don't bother to buy them. Bicycle co-ops sometimes have them...ours does.
The bicycle repair business suppliers make pedal thread repair kits ...
2 kinds a sleeve threaded on both sides the stripped hole is reamed , then tapped, then the insert goes in
And Helicoil .. a coiled diamond shape steel wire,, similar process..
Your local shop unwilling to do that, don't own or wont buy the tools to do that.
take the crank off ,
mail it to a shop that is willing to do that, owns the tools , etc..
VAR , France, makes this one..
helicoil type
helicoil type
Friendship is Magic
Bikes: old ones
Liked 10,373 Times
...these guys offer it as an online repair service for $25 9which is pretty cheap), but the mailing costs might kill it for you.
- Pedal thread helicoiling service, to repair damaged pedal threads on your crank arm.
- Available for all models of aluminium crank (and most carbon ones such as SRAM) arm providing it doesn't use a steel insert as standard (such as some Truvativ cranks).
- Only available for 9/16" x 20tpi pedal threads (not steel cranks or 1/2" threads).
- Please note that due to the nature of this service, it may not be possible to repair and replace the thread perfectly square with the crank arm. We do drill out the existing thread as a guide though, so it is usually within one degree and almost imperceptible.
How messed up is it? I would certainly try to tap out the threads first. Other than that, doing a helicoil repair really isn't particularly hard though many shops don't have the kits, but I don't know if the metal insert in those cranks is substantial enough to install a helicoil. There is a zero percent chance SRAM will officially recommend repair, but that doesn't have much relationship to whether it'll work or not.
