Need a silver 1x 11sp crank
Old 09-25-20, 06:46 PM
iab
iab's Avatar
Quoted: 3015 Post(s)
Liked 3,802 Times in 1,408 Posts
What's out there? What else?
Velo Orange
Rene Herse
SunXCD
Chater Lea
iab is offline
Likes For iab:
Old 09-25-20, 07:09 PM
Sir_Name
Sir_Name's Avatar
Bikes: are fun!
Quoted: 466 Post(s)
Liked 864 Times in 273 Posts
Slight variation on an option above: you could run a SunXCD ring on a 49d or other 50.4 set of crankarms to mix old and new. A TA Pro 5 Vis ring might be a better choice as the SunXCD outers are ramped and pinned. Neither of those get you a narrow-wide ring if that’s what you’re after, though.
(I have a 2x11 using a 49d with SunXCD rings in order to get the ramps and pins)
ETA: might as well throw some pics out to approximate aesthetics. Ignore the inner rings...
11sp chain on SunXCD ring:
TA ring (though a 9sp chain, 11 should be fine):
Hopefully that’s of some use...you’d still have the holes in the “outer” ring for the nonexistent inner as a sort of anti-wart. Same with the SunXCD pic above. I know that’d bug me (re form and function). Plus 1x is a pretty odd use case for the 50.4 BCD. So, maybe this is a better example of what not to do...
Maybe a 50.4 to ‘other’ BCD adapter could get around that while avoiding the empty shelf of a double crank arm. Still less than elegant.
Spitballing some more...grind the teeth off a TA outer for a ~bash guard and choose an inner to suit. Maybe acceptable depending on taste and use. That opens the options to double cranksets at this point though, getting away from the original question.
I think I’d pick a chainring based on size and aesthetics, then see where that leads. Not that that answers the question.
Track/SS crankset and 3/16” ring? Okay, that’s full circle.
@pcb probably has some better ideas going by his builds.
What’s the bike??
Sir_Name is offline
Likes For Sir_Name:
Old 09-25-20, 08:18 PM
Roger M
Quoted: 469 Post(s)
Liked 2,443 Times in 646 Posts
White Industries has a square taper silver crank arm set, along with silver chainrings.
I didn't look too hard, but at least one of their models is setup for 1x, and good for 8-12 speed.
Roger M is offline
Likes For Roger M:
Old 09-25-20, 08:30 PM
Sir_Name
Sir_Name's Avatar
Bikes: are fun!
Quoted: 466 Post(s)
^There ya go.
It also looks like Sugino has/had track/SS chainsets with 3/16” rings. RD2 was one option. 130 BCD, so you can find narrow-wide rings but they’ll be relatively tall. Not sure if the Paul Components crank was offered with 3/16” rings.
Sir_Name is offline
Old 09-25-20, 10:29 PM
repechage
Quoted: 3464 Post(s)
Liked 2,829 Times in 1,995 Posts
Spend the big money and get the Chater-Lea cranks and pedals.
maybe even spend the extra for th contrasting hardware
was unclear to me on the pedals if they use a steel bearing cup insert or have ground the bearing cup into the stainless pedal body.
repechage is offline
Old 09-25-20, 10:34 PM
repechage
Phil made cranks for a while- all CNC machined.
Old 09-26-20, 07:10 AM
alexnagui
alexnagui's Avatar
Quoted: 157 Post(s)
Liked 113 Times in 64 Posts
I recently put a SunXCD chaingring on 49D cranks for a 1x5 setup. I like the look of it.
alexnagui is offline
Likes For alexnagui:
Old 09-26-20, 07:19 AM
iab
iab's Avatar
iab is offline
Old 09-26-20, 07:22 AM
iab
iab's Avatar
It is tempting. But so spendy. The single though maxes at 40t. I was hoping for a 44-46t.
iab is offline
Old 09-26-20, 07:36 AM
natterberry
natterberry's Avatar
Bikes: ‘83/‘85 Trek 760, ‘82 Trek 614, ‘77/‘78 Trek 304, ‘74 Raleigh International
Quoted: 285 Post(s)
Liked 220 Times in 138 Posts
Anything in particular that makes a single chainring crank good for a 1x setup?
natterberry is offline
Old 09-26-20, 08:25 AM
iab
iab's Avatar
Nah. Mostly lies on the spindle for chainline and chainring itself. For example, the SunXCD I pictured is drilled if you want a double. The extra holes bother me. Petty yes, but I have nothing better to do.
I also don't want to "search", I want to buy. I just wanted to see what options are available, did I miss something.
iab is offline
Old 09-26-20, 08:42 AM
natterberry
Quoted: 285 Post(s)
Nope! I’m just unfamiliar with 1x setups.
I bought a FSA F Gimondi from Velomine a few years ago for $29 (on sale - they don’t appear the sell them anymore.)
Old 09-26-20, 09:16 AM
obrentharris
obrentharris's Avatar
Bikes: Indeed!
Quoted: 1507 Post(s)
Liked 3,478 Times in 1,132 Posts
The satin finish on those 49D cranks is beautiful. How did you achieve that?
Thanks,
Brent
obrentharris is offline
Old 09-26-20, 01:24 PM
TenGrainBread
TenGrainBread's Avatar
Quoted: 1136 Post(s)
Liked 650 Times in 336 Posts
Thanks,
Brent
I'll let Alex tell his method, but I have achieved a similar finish using red Scotchbrite followed by 600 grit followed by 1000 grit, and then Mother's.
TenGrainBread is offline
Likes For TenGrainBread:
Old 09-26-20, 01:35 PM
TenGrainBread
In my opinion the new Chater-lea cranks are somewhat ugly. Besides the "CL" cutouts in the chainring, they bear no resemblance to the old Chater-lea cranks. The crank arms should be slimmer, and the PVD-coated hardware is gauche. The huge price tag and proprietary chainring/spider just detract more from the appeal. I like that it is manufactured in Britain, but for that money I would expect something more tasteful and in line with the spirit of the old brand. Some skinny brass-welded tubular chromoly cranks would have been much more interesting to me. But obviously in developed Western countries like Britain and the US, CNC milling on aluminum has a much lower barrier to entry than anything involving forging, welding, or fabrication.
Old 09-26-20, 02:33 PM
RiddleOfSteel
Master Parts Rearranger
RiddleOfSteel's Avatar
Quoted: 1556 Post(s)
Liked 2,024 Times in 989 Posts
Pista / track crankset for single flange simplicity. Ofmega Super Competizione, Superbe Pro, etc.
RiddleOfSteel is offline
Old 09-26-20, 03:02 PM
RobbieTunes
Quoted: 378 Post(s)
Liked 1,409 Times in 909 Posts
Narrow-wide teeth.
RobbieTunes is offline
Likes For RobbieTunes:
Old 09-26-20, 03:04 PM
RobbieTunes
Quoted: 378 Post(s)
Velo Orange
Rene Herse
SunXCD
Chater Lea
Campy Centaur silver UT compact.
Old 09-26-20, 03:06 PM
iab
iab's Avatar
Just curious. You could have gone with what your mom taught you, or a simple, I don't like them. So why did you spend the considerable amount of time going on about something you don't like? I may not like Hetchins lugs, but I'm sure as **** not going to write a paragraph about it.
iab is offline
Likes For iab:
Old 09-26-20, 03:08 PM
iab
iab's Avatar
Do I have to do the work to show a picture for you folks?
iab is offline
Likes For iab:
Old 09-26-20, 03:11 PM
Narhay
Narhay's Avatar
Quoted: 956 Post(s)
Liked 568 Times in 314 Posts
Wouldn't this be 10 more speeds than you usual bikes?
Narhay is offline
Old 09-26-20, 03:12 PM
iab
iab's Avatar
I bought them too, same place, same price.
No longer for sale.
iab is offline
Old 09-26-20, 03:13 PM
iab
iab's Avatar
8-10. I have 3-speeds too.
iab is offline
Old 09-26-20, 03:55 PM
TenGrainBread
I thought this is the place where we discuss bicycle stuff? Why wouldn't you write a paragraph about it?
On the topic, I saw Rene Herse is releasing (has released?) a narrow-wide chainring. That would be a temping one.
Grand Bois has just partnered with a French bike shop to commission a narrow-wide chainring for TA cranks, made by TA. Pricey as well.
Old 09-26-20, 04:33 PM
seypat
Quoted: 3241 Post(s)
Liked 2,512 Times in 1,510 Posts
Can you get a 110 11 speed chainring and use a common 110 crankset?
seypat is offline
