Tools needed to swap out pre-2013 Brompton crankset to post 2013 version
Old 12-25-15, 12:12 PM
shinew
Bikes: Current: 2015 Brompton M6L Raw Lacuqer; Past: 2013 Brompton M3L, 2008 Dahon Mu Uno
Tools needed to swap out 2012 Brompton crankset to post 2013 one?
Hi, Merry Christmas everyone!
I'm planning to swap a 2012 Brompton crankset with a 2013 Brompton, I figure I could send the bikes to a bike shop or just use the money to do it myself and learn something at the same time(plus I like tools). So can someone give me a list of minimum tools needed to do the job? I already have some basic tools such as the adjustable wrenches(big & small), those folding bike tools, etc... I figure I'll probably need:
  1. Bracket tool like the Park Tool BBT-4
  2. Crank tool
  3. Ratchet with 14mm Drive bit(for 2012 version)
  4. Allen bit(for 2013 version, what size though?)
  5. Some heavy grease
Anything else? Also is having a torque wrench a big plus? I'm not planning to overhaul by bikes often but if it is useful in the long term, I don't mind getting one. Thank you for your input!
shinew is offline
Old 12-25-15, 12:47 PM
fietsbob
Bikes: 8
Quoted: 7607 Post(s)
you have the Plastic ended Sealed bearing BB? that wrench fits ? you may be able to Just leave it.
I pulled mine because I fitted a Mountain Drive crank which integrates it's own BB.
I have a socket that works in a tool made to remove BB Fixing bolts: Crank Wrench - Park Tool
when you put on the new crank use same bolt or newer shimano style which uses a 8mm hex socket in the bolt head , instead
It 'self Dust caps' the extraction threads.. that is what the other side of that tool is for..
fietsbob is offline
Old 12-27-15, 06:31 AM
jur
Quoted: 321 Post(s)
Liked 7 Times in 6 Posts
It is correct that you also have to swap out the BB. Brompton changed the taper from JIS to ISO.
jur is offline
Old 01-01-16, 02:55 PM
dynaryder
DancesWithSUVs
dynaryder's Avatar
Quoted: 7 Post(s)
I prefer this crank puller to the Park. We only have one at the warehouse,and I save it for problem children. I've trashed a couple of the Park models with the handle,but then I prolly average like 5 sets of cranks a day,so doubt you'll see that kind of use.
C'dale BBU('05 and '09)/Super Six/Hooligan8and 3,Kona Dew Deluxe,Novara Buzz/Safari,Surly Big Dummy,Marin Pt Reyes,Giant Defy 1,Schwinn DBX SuperSport,Dahon Speed Pro TT,Brompton S6L/S2E-X
dynaryder is offline
Old 01-01-16, 05:12 PM
shinew
Thanks, although for now I don't need to swap them anymore. For future reference, would this one also work? https://www.amazon.com/XLC-bike-tools...rds=crank+tool
Also can I upgrade a 2012 6-speed Brompton with all the updated components(crankset, double walled rims & brakes) from an existing 2013 3-speed model? My main concern is the rear wheel because of the different hub, but I think it's doable, or is it?
shinew is offline
Old 02-11-16, 02:25 PM
dynaryder
DancesWithSUVs
dynaryder's Avatar
Quoted: 7 Post(s)
Sorry for the delay,been busy. Yes,that puller will work,but I prefer the ones with handles. If the cranks are really on,I'd rather hammer the puller handle than a wrench.
Yes,the parts will all swap. However,you won't be able to run the two cogs and derailleur with the 3spd hub;the 3spd will only take one cog. If you want a 6spd,you need the BWR hub.
kmcrawford111
Folding Bikes
9
09-17-17 09:50 PM
DoubleDiamonDog
Folding Bikes
3
12-10-13 12:55 PM
kamtsa
Folding Bikes
8
03-16-13 09:26 PM
chagzuki
Folding Bikes
1
05-18-11 10:12 AM
