Tern CarryOn cover vs Tern Pop cover?
Quoted: 185 Post(s)
Liked 36 Times
We recently purchased a couple of Tern Link C8 (20” tires) bikes to use on vacation commuting. We have an upcoming trip that will entail a long train trip, so will likely want some kind of storage bag. I had initially thought the CarryOn was perhaps the best way to go, the the saw the Pop cover, which would allow us to roll them.
Anyone have any experience using either of these bags, or others that you would recommend? These are both relatively inexpensive, but I’m not opposed to saving money, lol.
Quoted: 573 Post(s)
Liked 118 Times
What's the diff, you ask?
I would get the CarryOn, as I used the same accessory from Dahon. A Tern is light enough that you can carry the bike over your shoulder, and the CarryOn should be a bit more compact and lighter than the PopCover.
Someone should make a CarryOn to fit a Brompton, for when authorities require to fold and bag it before taking the train.
Likes For Winfried:
Quoted: 980 Post(s)
Liked 582 Times
I second the recommendation for the CarryOn. I've been using these (I have two of them) for almost 10 years, since I started using a similar cover on my old Dahon MuXL. I also have a Tern Verge S11i which I've used the CarryOn cover with ever since I got it in 2013. As Winfried points out ^^ the bike is light enough to carry with the very robust strap which attaches securely to the bike. Having said that, I still recommend rolling the unfolded bike as close as possible to the point of boarding (a train in my case) to minimize the distance the bike is carried, and I practice this advice myself.
The CarryOn cover is a snap to fold and stuff into its storage sack, and probably takes 30 seconds or less to install or remove. It has a couple features I have never used: a zippered slot between the strap attachment points, and a drawstring at the outer margin to cinch the cover around the bike; I just ignore these. All in all, a very serviceable and durable product.
Quoted: 185 Post(s)
Liked 36 Times
Tern Carryon
Likes For Craptacular8:
