Clamp on or undrilled options for brake calipers
It's the little things
Bikes: Too many, yet not enough
Quoted: 279 Post(s)
Liked 326 Times
Hey guys, know this has been discussed before, just wanted to see if there are any other options for alternatively mounted brake calipers before I pull the trigger on the Dia Compe clamp on option?
I have seen some other styles of brake calipers, but typically they are just pictures and not options to purchase. I am looking for a front, preferably as I have had knee surgeries (yes, plural) and have no desire to wreck them by skid stopping and I also like the versatility they provide when riding. Any leads or suggestions are appreciated. Thanks in advance.
Guest
Quoted: 1346 Post(s)
Liked 3,270 Times
Other than swapping the fork for one with a mounting hole, canti bosses, or disc tabs, that Dia Comp clamp-on is probably the simplest and least expensive solution. Do post the results if you try it.
Clark W. Griswold
Quoted: 4335 Post(s)
Liked 3,958 Times
Get a frame that has brake holes is the best solution but if not I think Dia Compe clamp on (clamp off) are a good bet and with good shoes/pads and cables/housing you can get some decent braking. If you are just going front just get a new fork easy peasy lemon squeezy.
I don't know if the clamps for the Dia-Compes could be made to work with a different caliper but that would be pretty neat if you could. Not having touched one or seen one in real life I am unsure and the pictures are fine but I am just not sure and don't want to throw out something so bold and wild without knowing.
Quoted: 399 Post(s)
Liked 274 Times
I used one of those clamp-on dealies for many years - I think mine was a model from EuroAsia but I can't swear to it - it worked fine.
A few years ago I switched to:
https://alexscycle.com/products/801-...for-700c-fd700
and have never looked back.
I'm in the middle of dicking around with my bike so its easier to get a good look at it, I like it a lot...
I still have my old clamp-on assembly sitting around here somewhere sans caliper - just cover shipping and its yours if you want it...
Likes For IAmSam:
Quoted: 279 Post(s)
Liked 326 Times
Thanks for all the replies. I have considered a tange or even generic chrome fork, as this is to go on the track bike I just built. I don't know what's worse, the non matching fork or the mediocre performance of a retro fitted caliper 🤷🏾♂️
That Alex cycles adapter is aces, but $121 is steep just for the contraption, plus expense for the caliper. I'm not keen on taking away tire clearance, which is usually a premium on these frames. Might take you up on that offer though, see if I can make it work.
First world problems, eh? LOL 🤣
Quoted: 279 Post(s)
Liked 326 Times
IAmSam which offered better performance, or are they about the same? Appreciate all feedback.
Likes For Speedway2:
Quoted: 399 Post(s)
Liked 274 Times
If I can find the damn thing I'll post pics of it here. It has a couple different fork mounts to fit on rounder or more oval fork legs but I don't thing it will fit on wide alu or crabon...
Likes For IAmSam:
Bikes: United Motocross BMX, Specialized Langster, Giant OCR, Marin Muirwoods, Globe Roll2, VROD:)
Quoted: 238 Post(s)
Liked 404 Times
Obviously the most important criteria is ensuring the forks are spec'd correctly.....after that aesthetics need to be considered otherwise you're efforts will be diminished IMO
Likes For IAmSam:
Quoted: 279 Post(s)
Liked 326 Times
Appreciate it
IAmSam thank you, you are a gentleman and a scholar.
Regarding replacement fork, as has been mentioned, too many other factors when adding an aftermarket fork. Rake, trail, fork to brown, steerer length, etc. This or the quill adapter are the easiest and beat options for using the stock fork which was designed to work with the frame.
Always amazed at this forum. Thanks everyone who chimed in. I will keep my other thread updated with progress and picks as I continue getting this bike build complete.
