[trike] Two wheel-drive = more effort?
Quoted: 573 Post(s)
Liked 118 Times
Hello,
Denmark's BellaBike trikes are unusual with their two front wheel-drive, and the rear wheel that steers.
Empty, the bike weighs about 40 kg/80 lbs. It comes with a Nexus 7 gear hub.
Out of curiosity, do you think it takes more effort to move that bike compared to regular trikes because of the two wheel-drives in the front instead of one in the rear as usual?
Thank you.
Thank you.
Bikes are okay, I guess.
Quoted: 2647 Post(s)
Liked 2,446 Times
Interesting configuration. I suspect turning both those drive wheels isn't significantly more difficult than turning one of them and there might be benefits to the setup.
Quoted: 573 Post(s)
Liked 118 Times
Rather than steering, I'm concerned about the effort required to spin the two front wheels (instead of just one).
Or maybe with "turning", you meant what I just wrote :-p
Bikes: 2016 Fuji Tread, 1983 Trek 520
Quoted: 674 Post(s)
Liked 739 Times
The added weight and extra work on turns is probably negligible. I wonder what the added cost is, how reliable the differential is, and if there are any servicing issues.
Likes For andrewclaus:
Quoted: 1438 Post(s)
Liked 1,092 Times
I would think that the 2 front wheel "tadpole" design would be safer against overturning when braking during turns than the 1 front wheel "delta" design.
Liked 1,092 Times
I do not see a differential in the photo, I wonder if both wheels are driven or just one. That silver cylinder is the multispeed hub.
Quoted: 2026 Post(s)
Liked 1,095 Times
I didn't see one either and, yes, that is the Nexus hub. It does seem to be an awkward and excessively complex design. Front steering, even if it has two front wheels and requires Ackerman linkage, and rear drive makes more sense.
Old fart
Quoted: 3583 Post(s)
Liked 3,395 Times
I don't see one, either. Without a differential, one of the driven wheels must lose traction in corners. A differential will prevent that, but at the cost of additional weight and mechanical friction.
Quoted: 674 Post(s)
Liked 739 Times
Quoted: 1943 Post(s)
Liked 2,164 Times
The steering (turning) aspect aside, the pedaling effort of two wheels vs. one can probably be realized by comparing a bicycle to a rear drive tricycle.
Rear drive tricycles have been around for a long time and the additional dual wheel weight and if any more effort is needed can give that answer.
John
John
Liked 1,095 Times
In this case the differential seems to be small mechanism just above the brake rotor and driven by the short chain.
Likes For HillRider:
Quoted: 573 Post(s)
Liked 118 Times
How does the differential work? Is the magic all into that part?
Is a rear drive trike (delta) harder to move than a front drive (tadpole)?
Likes For Winfried:
Liked 1,095 Times
Why are you so fixated on which is harder to move? Given the weight and extra drag I have to think neither style would make any difference.
A differential allows one driven wheel to rotate at a different speed than the other. When going around a corner, the outside wheel has to travel further than the inside wheel so it has to rotate faster. A differential allows this to happen.
Quoted: 1109 Post(s)
Liked 1,200 Times
Tadpole recumbents are generally (single) rear wheel drive and (dual) front wheel steering and braking. The crank goes through a long chain w/ idler to the rear derailleur and cassette. On my tadpole, the drive train, with the exception of the incredibly long chain run, had a common triple crank with derailleur and 9 speed cassette on the rear hub with long cage derailleur.
Quoted: 254 Post(s)
Liked 182 Times
To answer the original question, the effort required to pedal a bike is almost all due to the total weight and what gear you are in relative to how fast you are trying to go, with a little contribution from wind resistance and rolling resistance. So whether you are driving one or two wheels really doesn’t matter. I presume a cargo trike like that is pretty heavy, though, so it’ll be slow to get moving and tough to go uphill, but that has little to do with driving two wheels vs one.
Old fart
Liked 3,395 Times
Old fart
Liked 3,395 Times
