BB not in fully, crank refuses to come out
*bows*
Bikes: Giant Fastroad Advanced 1
Quoted: 15 Post(s)
Liked 8 Times
Hello everyone,
I have a new bike that is ridden probably less than 50km total. I decided to upgrade my crankset, since it is using an older version (Shimano FC RS-510). I purchased a Shimano FC R7000, but while upgrading, I noticed that the cap on the bottom bracket was broken. I purchased a new press-fit bottom bracket (SM-BB92-41B) and installed it. I installed the new crankset, and everything went smoothly. After I was done, I was taking a look at my work, and noticed that the bottom bracket on the non drive side had a TINY bit of gap between it and the holder (like a fraction of a mm), but I decided since I know how to do it, I might as well put the press back on and press it a bit more. This is where things went wrong. I took off the crank arm normally, but when I tried to take off the crank, it just would not come out. I tried tapping it from the non-drive side, I tried spinning it while pulling, etc. Nothing work. It spins very smoothly, so it's obviously not jammed or anything, but I'm thinking since I added so much grease to it, it formed an air tight bond with the bottom bracket and the suction keeps it from coming out. I eventually gave up and reiinstalled the crank arm, since the space is so miniscule, I figured it's not worth it. However, it keeps bothering me every now and then, and I've removed the crank arm and attempted to take out the crank 4 times since then with the same failure that ends up in me putting everything back together and calling it quits. Keep in mind that the weather here doesn't permit me to ride the bike, so during all of this, the bike is just sitting at home (I keep it in my room, so it's not exposed to the cold). I'm worried that hitting he crank any more forcefully will result in damage to it, the bottom bracket, or the frame. Should I just leave everything as is and see if there are any issues while riding it? (I don't anticipate there would be considering the bottom bracket is like fractions of a mm out; almost imperceptible unless you look really really closely), or do I have to take it apart and press it in more? If so, how?
TL;DR: Press-fit bottom bracket is fractions of a mm away from being fully pressed (almost imperceptible unless you look really closely. a piece of paper would not fit in the space, crank installs normally with no rubbing or anything, and spins freely. There isn't any noise coming from crank or BB). Crank is stuck and refuses to come out, although it spins freely. I'm therefore unable to remove it to press the BB in further. I've tried tapping it with a hammer from the other side, spinning it while pulling, etc. Nothing works. Is it ok to keep things as is or do I absolutely have to take it apart and press the bottom bracket in more?
Solution for anyone else having this problem in the future: Place your old bottom bracket around the exposed part of the spindle and insert it so that it is touching the installed bottom bracket. Hit the old bottom bracket with a rubber mallet a few times, and it'll push in the installed bottom bracket all the way in!
Quoted: 6193 Post(s)
Liked 4,809 Times
New members can put the URL of the location of your photos in the text of your message and then put a space on either side of the . and remove the https://. Then it's not longer a URL, but most of us have at least enough smarts to figure out how to make it work again.
*bows*
Quoted: 15 Post(s)
Liked 8 Times
Thanks. This is what I'm leaning towards currently, but I wanted other people's more experienced input. I appreciate it.
Liked 4,809 Times
But I've been telling other newb's this for years. No administrator or mod has ever said not to. And to my knowledge the SPAM police have never showed up at any newb's door that was so inclined to defeat the spam filters.
Quoted: 836 Post(s)
Liked 1,061 Times
You may need to give the crank spindle a medium whack to get it out. Not uncommon with some setups. Put a wood block over the end of the spindle and give it progressively harder hits until it comes out. Use your common sense of course and don't use gorilla strength with a 20lb sledgehammer.
*bows*
Quoted: 15 Post(s)
Liked 8 Times
Quoted: 254 Post(s)
Liked 182 Times
As long as the bb isn’t binding on the crank, there’s no need to “fix” it. Just keep an eye on it that it doesn’t start to work itself farther out.
If you decide you must get it all the way in, just hit it harder as others advised. It’s rare that “Hit it harder” is the right answer, but this is one of them. Crank spindles are really strong, so you’re not likely to break anything
Likes For AeroGut:
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times
If it ain't broke, fix it til it is.
Quoted: 645 Post(s)
Liked 797 Times
Is the gap consistent all the way around? Maybe the BB shell wasn't properly faced, so it's not perfectly flat and perpendicular to the BB axis (winging it here - not too familiar with press-fit BBs). Could it have always been this way but you never noticed before?
BTW if you installed the crank through the BB, you know there's nothing specific holding it (the "suction" theory is imaginative, but unlikely). Hit it harder, with a dead blow mallet and/or a piece of wood to protect the end
Quoted: 1109 Post(s)
Liked 1,200 Times
Friendship is Magic
Bikes: old ones
Quoted: 26418 Post(s)
Liked 10,380 Times
...in essence, all those press fit cups on either side do is provide a fixed location for the bearings.
So in this particular case, if the BB shell has not been previously faced level on both sides, and the press fit thingies have a lip that is supposed to contact the shell (by which they gain both further support, and alignment), you might get a less perfect alignment of the bearings. If they are roller bearings, an imperfect alignment of them with each other and the shaft running slightly cattywumpus because of it, the bearings might have a slightly shorter lifespan. But I think that now some of them are not roller bearings.
In real world applications, it's usually not a big deal.
It is entirely possible, if you tap that shaft hard enough, and it's really stuck in the interior bearing collar, that you can screw up the clearance in the cartridge bearings. usually, some kind of penetrating oil applied to the shaft where it enters the bearing assembly will solve this problem. i.e. make it easier to tap the shaft through.
I think if the space is as small as you say, I would just leave it alone and not obsess about it. Worst case is you get a slightly shorter bearing life, or a creak. The creak is bad, but you can address it when it arises, if it ever does arise. Which it probably won't, but might. You never know.
Friendship is Magic
Bikes: old ones
Liked 10,380 Times
Likes For 3alarmer:
*bows*
Quoted: 15 Post(s)
Liked 8 Times
Thanks for the comments and wisdom, everyone! I appreciate everyone's feedback. As promised, here is a photo of the bottom bracket with the barely visible gap, full of grease:
i.imgur(DOT)com/0qS4fcM.jpg (replace (DOT) with .)
After reading all the comments, I'm leaning towards leaving it in there and keeping an eye on it (if the gap gets any bigger, any noise, etc.). Is that a logical conclusion? Thanks again.
Liked 4,809 Times
The pic...
Likes For Iride01:
Liked 2,969 Times
send it.
-Oh Hey!
-Oh Hey!
*bows*
Quoted: 15 Post(s)
Liked 8 Times
So, yet again, I tried to remove the crankset and failed just like all the other times. I can take off the non drive side crank arm just fine, but the drive side part of the crank attached to the spindle does not budge. I was hitting the spindle so hard with the rubber mallet, that I was concerned the carbon fiber frame was going to break. I started thinking if there was any way to press the bottom bracket without having access to the other side for bracing, and a thought occurred to me. I still had the old bottom bracket. I placed one side of the old bottom bracket around the protruding part of the spindle, where the non drive side crank arm would attach, which meant that this bottom bracket was now directly touching the installed one that wasnt pressed in all the way. I hit the old bottom bracket with the rubber mallet a few times, and it worked! The bottom bracket was now pressed in completely all the way with no gap! I'm so glad that worked!
TL;DR solution for anyone else having this problem in the future: Place your old bottom bracket around the exposed part of the spindle and insert it so that it is touching the installed bottom bracket. Hit the old bottom bracket with a rubber mallet a few times, and it'll push in the installed bottom bracket all the way in!
Liked 2,969 Times
-Oh Hey!
-Oh Hey!
*bows*
Quoted: 15 Post(s)
Liked 8 Times
I was beating myself up for not taking photos, but was hoping my description was good enough. Unfortunately, did not take any photos, but if I take that non drive side crank arm off and remember to, I will definitely post a photo. The bottom bracket itself is now FULLY pressed in with no gap, so I can finally stop obsessing over it and worrying about the dirt that would’ve gotten in there.
