Genesis Folding Bike
Walmart sells folding bikes? I had no clue! Well, it's not the cheapest bike on the market, but it doesn't look too bad. I'd like to know how it performs in the long run, especially against a similar Citizen.
M.
M.
55+ Club,...
Bikes: 9+,...
Quoted: 1112 Post(s)
Liked 848 Times
With the exception of the cheap plastic kickstand mounting hardware the bike, IMO, looks good.
Bikes: homebuilt FWD recumbents, Genesis 20" folding bike, 1986 Schwinn Tempo, Cannondale Beast of the East, 70's Peugeot
Not sure I understand about the kickstand; I'll get a picture tonight an upload. There's not much plastic about it- seems like it's mostly aluminum.
Anyway, I was toying with bullhorn bars and a bottle holder location, what are your thoughts on this arrangement? (the twist grip shifter is temporary, it's the Shimano Revo shifter that came on the bike but will be replaced with some other shifter).
Yes I know that grip shifter looks stupid, and it's also a bit of a pain to shift. So that'll be changed out to something.
One thing I can say the bullhorns do- they stretch the reach a little which makes the bike feel less upright.
I said I would report on how the bike rides, so here goes. The quality of this bike is miles ahead of the previous cheapo folding bike I had, linked here. The extra $50 is well spent on the Genesis. Although the main frame clamp doesn't seem excessively tight when I close the hinge latch, there is zero noise from the main hinge. Pulling on the bars results in a very faint squeak from the handlebar stem hinge. Everything else is quite good, I have no complaints.
EXCEPT....in higher gears there is a rhythmic knocking coming from (I think) the bottom bracket. I haven't torn into it yet, but I *think* the BB is sealed bearing? Everything feels tight. I already swapped out the plastic folding pedals, so they're not the culprit.
So hopefully I can figure out what that issue is. The freewheel (fairly certain this 6 spd is not freehub) makes a lot of clicking noise when coasting but I'm pretty sure that's normal.
The seat is not overly comfortable, but I think most people plan on swapping the seat anyway.
The cable lengths seem a little long, but maybe it's something to do with the fold. It's something I can live with (or shorten the cables...).
Genesis did not include a bottle cage mount anywhere, I used a Bell adjustable handlebar bottle cage mount on the steering stem; I like the placement and unbelievably it doesn't seem to impact the fold (but the bullhorns do to an extent).
There ARE provisions for both a rack and front/rear fenders on the frame.
Finally, the things I would suggest to improve this bike would be 1) quick release axles and 2) freehub instead of freewheel for easier upgrade path.
OK, knocking noise solved. I thought it was the BB, but frankly everything seemed tight and the bottom bracket and cranks seemed to be OK quality. So I turned my attention to the rear wheel. I removed the wheel and the freewheel (which I earlier said made too much noise while freewheeling) seemed loose. I could grab the largest cog and move the entire freewheel about .5 to 1mm. The freewheel brand is "Fleaby", whatever that is.
So, I replaced the cheap freewheel with a Shimano MF-TZ20 and problem solved!
I have $220 invested in this bike and it seems to tick all my boxes. I'm happy, and I urge others looking for a decent quality, low cost folder to consider this bike. The only issue I can see is there's only one color.
Bikes: Fully customized 11-spd MTB built on 2014 Santa Cruz 5010 frame; Brompton S2E-X 2014; Brompton M3E 2014
Quoted: 17 Post(s)
Good to see the naysayers being knocked down a peg.
From day one I've seen some of them proclaim that the only way to get a decent bike is to throw money at the problem. Maybe it's a middle-class, 'people with too much disposable income/savings' kinda mentality.
I use money for many other things in my life with similar or higher priorities - family, friends, my kid - soon to be two hopefully, retirement savings, mortgage, etc.
I do have the disposable income to purchase expensive bikes, but it's never an easy decision to lay it down as some make it out to be.
Bikes: Nishiki Prestige, Reign, IH Warrior, Rockhopper, Brompton, Q-Bike, Forever, Free-Ride, Dahon, Merckx Premium, Litespeed Teramo, Raleigh MTi 1000, Motobecane Fly Ti, OnOne 456, Kona Unit, Transition TransAM
Looks nice. With only 6 gears in the rear, I'd put a friction barcon shifter on that and call it good. It would shift buttery smooth...
This wasn't really my intent, but I do understand and relate to your post. I suppose I make a decent living; and although bicycles are one of my passions, I still can't justify a big cash outlay for one. When it comes to spending money on any of my hobbies, I find I have to strike a balance with other expenditures usually taking a much higher priority.
So when I found what I thought was a good deal, I naturally wanted to share my find with everyone here. I know bikes at this lower price point aren't for everyone; but I know there's a lot of thrifty people out there like me.
tk1971- I used 22.2mm (7/8) bullhorn bars on this from Crow Cycle (leftover from an old build) and the ID of the bars are not large enough for Suntour Barcons (I tried). But you're right, they would be perfect. These bars are sweet because mountain bike components work perfectly due to the 7/8" dia. I'm gonna have to wait for my next flight home to grab another shifter, I think I have a early 90s friction thumbshifter that might mount on the forward part of the bullhorn fairly well. So for now I'm stuck with this shifter. I love the bullhorns on this bike, though.
Bikes: too many
FWIW, I also have disposable income; and bikes are one of the few things I spend it freely on. But not everyone is upper middle class, or if they are, they don't suffer from consumeritis. For that reason, threads like this are valuable.
Atom, I don't think Keyven's comment was directed toward you, rather to posts that were criticizing your choice without any first hand knowledge on their part.
I'll report back later once I learn more or have something new to tell; but as of now, I'm still satisfied with my purchase and think this bike is great buy.
OK, I will
I was going to say a bunch of stuff about how we don't know what company actually makes this bike, etc, but there's no need.
In my earlier posts I forgot to mention- this bike has a lifetime warranty on the frame, backed by the largest retailer in the US.
So I'm thinking that within a year, if anything happens to the bike, I'll just return it for a no-hassle refund of my full purchase price.
Try that with whatever you ride.
Quoted: 17 Post(s)
I apologise for being somewhat critical of the comments here, but I hope people will be a little more accepting of lesser known brands.
There's no need to be snide whenever someone gives a hitherto unknown brand a try. It's nothing more than schoolyard bullying, laughing at some kid's no-name new ride while you flaunt your BMXs. It's one thing to be proud of your own bike, it's another to be an ass about someone else's.
Sheesh, and they say branding isn't everything. No wonder Apple was at one point the most valuable company in the world.
Bikes: to many
Quoted: 213 Post(s)
somebody who enjoys and rides his 200 dlr bike is at least as good as somebody with a 2000 dlr bike who doesn't ride it ...
( except of course if he bought the 2000 dlr bike from me ..lol )
no kidding though
good on ya
no kidding though
good on ya
The Recumbent Quant
The biggest problem with bikes like this are that they are put together very badly. If you don't know anything about bikes, this is a big problem. And once you factor taking a bike to a bikeshop to get it tuned up and parts replaced, what seemed like a good deal no longer is.
This is very different when people are able to work on the bikes themselves (and have a good idea what they are in for).
In this case, the OP has built absolutely beautiful bike frames, so I have NO doubt that as long as the frame and stem are fine, he'll be able to fix anything else.
& [along the same lines...] you wont find a Bicycle Service Section in a Wally*World , it's just another commodity to ring up on the way out of the store.
same as in most big box stores (except, like, REI)
I think you make a valid point here... when I recieved this bike there was a problem. It was minor, but so noticable that within the first several miles I knew I had to fix it (the rythmic noise I reported earlier that turned out to be the junky freewheel). I WAS able to identify the noise and resolve it fairly cheaply; but what about a buyer that's not a "wrench"? I paid for a new freewheel and, although not happy about it, am satisified that my total cash outlay still results in a "good deal", so I was OK with replacing the freewheel rather than returning the bike for a refund.
But many would have to pay to have the problem fixed or just live with the noise until the freewheel failed. Either would probably result in lower buyer satisfaction.
So with the above, I suppose I will revise my recommendation to "this bike is a good value if you have the mechanical aptitude and inclination to deal with unforeseen issues" or something along those lines.
BikingYupik
Quoted: 9 Post(s)
I bought a bike for my wife from Performance Bike.
It was inexpensive, less than $400.
I had to go through it and adjust about everything.
Tighten screws.
Must just be me but I consider it normal.
Doesn't Dahon recommend taking your new purchase to the local bike shop for service prior to riding?
Tighten screws.
Bikes: Norco XFR
Tighten screws.
Tighten screws.
Bikes: Norco XFR
$20 price drop!
The Genesis 20" folder is now $179 at Walmart
20" Genesis, City Cruiser, Folding Bike, Green - Walmart.com
How can you afford to NOT buy one?
I was a little bored this evening so I decided to try to place the bike in this Samsonite 26" suitcase I got off craigslist a couple weeks ago. This suitcase measures 26" x 21" x 10" and has a taper towards the top. It's not the best suitcase to put a folder in, but it was only $20 and I thought it looked big enough to work, but at the same time look small enough to not raise any eyes when checking it at the airport.
I did have to disassemble the bike partially, but I totally expected that. The frame and folding stem were no problem at all, especially since the stem is a telescoping one with a 4 bolt handlebar stem at the top. Made it very easy to get the frame into the case with plenty of room. The biggest issue I had were the wheels and tires; since there is a center latch at the top of the case (as well as two side latches) I had to let the air out of the tires to get them to fit due to the latch.
Before I actually fly with it I will have to devise some sort of padding to protect all the parts.
all in except wheels
