Front Suspension Fork
Old 07-06-20, 11:39 AM
SoldSpartan
Quoted: 41 Post(s)
As of now I been riding my Marin Rock Springs 2 for about 15 miles a day on general trail conditions. I am currently riding on a Rockshox Recon TK 100mm 29 inch fork. I really what to upgrade to something that is at least 120mm but don't know if is worth the money. Any options would be great.
SoldSpartan is offline
Old 07-07-20, 12:23 PM
SoldSpartan
Quoted: 41 Post(s)
Ok, well does it help if I said that my price point is anything under $500?
Old 07-07-20, 03:01 PM
trailangel
trailangel's Avatar
Bikes: Schwinn Varsity
Quoted: 1931 Post(s)
Liked 742 Times in 422 Posts
That's about a $300 fork, and it's not bad....Solo Air right?
Do you have the shock pump, and/or tried adjusting the rebound damper?
100mm travel is typical for a trail or crosscountry bike.
IMO it's not worth spending the extra $ for a new fork, and buyer beware when purchasing used forks.
Keep riding it and save for another bike.
Maybe a slightly larger and cushier front tire would help.
trailangel is offline
Old 07-07-20, 03:32 PM
SoldSpartan
Quoted: 41 Post(s)
I'm having trouble uploading more pictures, but I manage to get this one through.
Old 07-07-20, 03:35 PM
SoldSpartan
Quoted: 41 Post(s)
No it doesn't use a shock pump, and yes I have adjusted the rebound all the way over to the picture of a rabbit. Also what tire should I get for front wheel?
Old 07-07-20, 06:12 PM
SoldSpartan
Quoted: 41 Post(s)
Here are some more pictures; I hope it is helpful.
Likes For SoldSpartan:
Old 07-07-20, 06:29 PM
Darth Lefty
Disco Infiltrator
Darth Lefty's Avatar
Quoted: 3126 Post(s)
Liked 2,105 Times in 1,369 Posts
“Rabbit” is the bounciest setting. Are you sure you’ve got it set up to your best advantage? It’s not a turd, just not fancy.
Darth Lefty is offline
Old 07-07-20, 10:44 PM
70sSanO
70sSanO's Avatar
Quoted: 1944 Post(s)
Liked 2,164 Times in 1,323 Posts
If you are going longer, you have to consider how the change will effect the bike’s handling. It used to be 20mm was the rule of thumb for the max increase in travel. The big question is how does the bike handle with 100mm?
Going to 120mm may have a slight impact, as you go longer the head angle just keeps getting shallower and the steering gets slower.
John
70sSanO is offline
Old 07-07-20, 11:57 PM
Amt0571
Bikes: Canyon Grand Canyon AL SL 8.0, Triban RC520 Gravel Ltd, Btwin Ultra 520 AF GF, Triban Road 7, Benotto 850
Quoted: 402 Post(s)
Liked 215 Times in 137 Posts
I wouldn't upgrade for an extra 20mm of travel. If I upgraded I would do it for a better fork even if it still was 100mm.
Have you measured if you're using all the travel the fork provides? Maybe you need a softer or stronger spring. That's way cheaper than a new fork.
Amt0571 is offline
Old 07-08-20, 07:30 AM
Wooderson
Quoted: 24 Post(s)
Liked 18 Times in 16 Posts
You haven't said what you don't like about the current fork, or what you're trying to achieve with the new fork.
Speeding up the rebound makes shocks bouncy, like a pogo stick. Shocks will feel smoother if you slow down the rebound. You don't want to go so slow that it can't recover between hits.
Like someone else said, you can probably change out the coil, and sometimes you can get spacers to increase stiffness.
It just depends on what you're after.
As for tires, that depends on the terrain type and your riding style, but a fatter tire (if you have space) will improve traction and comfort, which sort of goes hand in hand with the fork. If you're not running tubeless yet, that's a consideration as well (assuming your rims are compatible).
Wooderson is offline
Likes For Wooderson:
Old 07-08-20, 10:42 AM
grubetown
grubetown's Avatar
Quoted: 110 Post(s)
Liked 24 Times in 21 Posts
Great advice!
grubetown is offline
Old 07-08-20, 11:43 AM
Leebo
Bikes: Kona Dawg, Surly 1x1, Karate Monkey, Rockhopper, Crosscheck , Burley Runabout,
Quoted: 854 Post(s)
Liked 111 Times in 66 Posts
What is it about the current setup that's not good?
Leebo is offline
Old 07-08-20, 12:01 PM
SoldSpartan
Quoted: 41 Post(s)
There nothing about it that is bad just want to get more out of what I could get.
Old 07-08-20, 12:04 PM
SoldSpartan
Quoted: 41 Post(s)
Any recommendations for a cushier front tire?
Old 07-08-20, 05:36 PM
Leebo
Quoted: 854 Post(s)
What ever is bigger that fits. Big fan of Maxxis. Running tubeless? Psi used? Fork set up correctly for your weight and riding style?
Leebo is offline
Old 07-08-20, 11:37 PM
cpach
Bikes: Too many. Giant Trance X 29, Surly Midnight Special get the most time.
Quoted: 533 Post(s)
Liked 312 Times in 236 Posts
Take note that the fact that your bike has a straight headtube and your current front wheel has a QR makes your bike not upgradeable to most mid-end current forks. In fact, searching, I only found one 29", straight steerer, air sprung 120mm fork: https://takeahikeshop.com/products/m...gle%20Shopping. You can find a number of decent options in 100mm travel. Radically altering the travel of a bike in most cases is inadvisable.
Really your bike is not a great upgrade platform. Also in general, upgrading right off the bat is inadvisable as bike brands can buy parts much cheaper than you can. You should buy a bike of the general quality level you intend to ride.
cpach is offline
Old 07-08-20, 11:44 PM
base2
I am potato.
base2's Avatar
Quoted: 1789 Post(s)
Liked 1,629 Times in 933 Posts
Since when does a Recon not use a shock pump? Mine is set at 120psi cause I'm a fat clown, and my wife has hers at around 90psi 'cause she is normal person weight.
Having said that: Read the owners manual. When broken down for rebuild (every 50 hours use) you can swap around the internal spacers to select 80, 100, & 120mm of travel.
Good luck.
Car dependency is a tax.
base2 is offline
Old 07-09-20, 10:16 AM
SoldSpartan
Quoted: 41 Post(s)
So basically you guys are saying it's not worth it.
Old 07-09-20, 10:45 AM
Darth Lefty
Disco Infiltrator
Kind of, but that’s not all we’re saying. We want you to get the best out of what you have, too. That’s why we are asking what you think is lacking, and talking about changing springs, adjusting damping, all of the things that you can do within its limits. You can also do a rebuild, and even change the oil weight.
On my bike, which I use for light trail and commuting, I have a soft Nobby Nick in the front and a faster tire in the rear. My original WTB Ranger is wearing out, and it will likely be replaced with a hard Rocket Ron just so that the labels match. But every tire manufacturer has tires that are pretty much equivalent to these.
Old 07-09-20, 11:32 AM
SoldSpartan
Quoted: 41 Post(s)
How do you know all this/ what does QR stand for?
Old 07-09-20, 12:23 PM
cpach
Quoted: 533 Post(s)
I am a professional mechanic and looked at your bike. A qr is a quick release. Front hubs come in both qr and thru axle variants–mid to high end current production forks are nearly all thru axle
cpach is offline
Old 07-10-20, 10:47 AM
grubetown
grubetown's Avatar
Quoted: 110 Post(s)
Good luck.
There is a coil spring Recon.
Old 07-10-20, 11:19 AM
SoldSpartan
Quoted: 41 Post(s)
Yes
Old 07-10-20, 11:34 AM
base2
I am potato.
base2's Avatar
Ok. I learned something new here.
Thanks!
base2 is offline
Likes For base2:
Old 07-10-20, 11:36 AM
grubetown
grubetown's Avatar
Quoted: 110 Post(s)
Thanks!
Thank you for reminder that online forums can be cordial. Have a great weekend!
