Fuso FRX
Fuso FRX
Just picked up this gorgeous 54cm Fuso FRX #550 ... Weirdness on the rear drive train being dumped to replace withe Dura-ace 7700 to match the rest of the bike. But... And it's a big one! The front fork is bent from a collision. Do I just bend it back using my trusty lil' brute or do I shell out $175 for new blades into the old crown. The fork crown is fine.
Sourcing another Fuso anything will be very hard, so you might want to consider repairing or 'correcting'. Repairing might be the better option.
Master Parts Rearranger
Quoted: 1556 Post(s)
Liked 2,024 Times
Another vote for repair. It looks like the bending in the fork is in the upper blades as opposed to at the blade-to-crown intersection, which makes the repair possibility really iffy. You're in a good spot. Other benefits to repair: No repainting necessary / it will still be the original color (love the colors!) regardless of work done to it. Big bonus. And finally: that steel is what Dave Moulton meant for that frame. Re-formed to his specs, it will be and ride like he intended it to, which is a big reason you and anyone else got a Fuso in the first place.
Bianchi Goddess
Quoted: 2938 Post(s)
Liked 2,934 Times
A frame builder might be able to bend them back for you but I'd replace it with this https://www.somafab.com/archives/pro...ade-track-fork
Sugar "Kane" Kowalczyk
Quoted: 1858 Post(s)
Liked 606 Times
Did you check the downtube for any damage? Looks like it took a pretty good hit.
I would opt for repairing it. Harder to sell a bike with non original fork.
ex frame builder
Liked 5 Times
This fork could be safely straightened. I wrote an article here. Dave Moulton's Blog - Dave Moulton's Bike Blog - Straightening steel forksv
Dave M
Dave M
History, photos and tech articles on "Dave's Bike Blog." 'dave moulton' Registry including a Picture Gallery https://www.davemoultonregistry.com/
Thanks Dave! That's very reassuring. I absolutely love the look of this bike. I just need to get on it and ride it. Trying to find someone in Florida who has the experience. I do not want to botch this one. Nice article as well.
Stop reading my posts!
Quoted: 1444 Post(s)
Liked 1,064 Times
I just bought a frame with a (not original) Fuso fork for a 56 cm...except it's RED, but blades are not bent! PM me if interested and I'll snap some pix. I have another fork for this frame so don't need the Fuso (at least not YET!)
And BTW if there are any Fuso owners that need a red fork (same crown as in the pink example) with Campy forkends, drop me a PM. It's marked "56" and has a short section of threading, maybe 25mm or so.
ex frame builder
Liked 5 Times
There is a reason why the threads are short on frames I built, outlined in this article, Dave Moulton's Blog - Dave Moulton's Bike Blog - Why so short?
But because of this your 56 cm. fork would probably not work in a 54 cm, frame. Even though normally you could add a spacer, with a short thread there is not enough thread to screw the top bearing cup down.
Quoted: 51 Post(s)
Liked 35 Times
Was this the bike listed in the Tampa area? Anyhow, if your in the area, call Allen Wanta, a framebuilder in Clearwater. He might be able to fix it, or make you a new one.
Does anyone know "miamijim" ? ... He's in my area. Hoping he can take a look at this fork. Sent him a PM, but no response.
Quoted: 835 Post(s)
Liked 2,156 Times
Way to go! Any comments on the fork repair process?
