Newbie with a Motobecane unknown model questions.
Bikes: '73 falcon sr, '76 grand record, '84 davidson
Quoted: 59 Post(s)
Liked 22 Times
yes, '72/'73 is older than '76.
here's are a few moto threads:
https://www.bikeforums.net/classic-vi...ght=motobecane
Steel is real
Bikes: 1999 Trek 5500 w/ Campagnolo Record 10
Thanks for posting the serial number database link! That will be some useful information.
Looks like it's a 73 model picture shows a stamp below the headset, a step closer to a full I'd
Derrick
The top & bottom head lugs have a emblem stamped BCM on each, has anyone seen this before ? Also the seat lug is stamps 75. There appears to various different theories on the range of numbers stamped on the Motobecane frames, I think it's safe to say it's build is around the mid 70's. I'm going to base the colour I spray on catalog pics of this period the light metallic Blue appeals with the Aluminium components to set it off.
I post more pics along the build.
Cheers guys
Cheers guys
Cheers guys
Cheers guys
curmudgineer
Bikes: 2 many 2 fit here
Quoted: 263 Post(s)
Liked 112 Times
"Bacoma", not to be confused with Tacoma, producer of wood-derived products and accompanying odor, known as the "Tacoma Aroma"...
I heard tell there is also a lug manufacturer with the very similar handle Bocama...
Oh cr*p. I did spell it wrong, didn't I. Yes...Pacific Northwest....Tacoma.....only one cup of coffee and it's very early here.
Got a question on the Huret rear dropouts here are some pics :-
mine has a bodged end stop 1st pic any idea of the correct set up ? Please see other pictures, any Huret supplier that stocks them ?
Cheers derrick
Cheers derrick
Bikes: 1970s Alex Singer, 1960s Peugeot PX 10, 1960s Bertin C37, 1973 Carre Bertin C 37, 1972 Carlton Kermesse, 1981 Peugeot PX 14 Super Competition
Quoted: 346 Post(s)
Liked 266 Times
zola 1-
The 73 30 and the 75 on the lugs is the angle of the tube socket and is not useful for dating production. The centre picture is correct. Huret dropout adjusters use a unique thread at 4 mm for the hole with 0.8 mm threading. Every other adjuster is 5.0 mm x 0.8 mm. However, if you can't find Huret on EBay, then the dropouts can be tapped to 5.0 x 0.8. I've not done it but Sutherlands says it is possible.
zola 1-
Quoted: 59 Post(s)
Liked 22 Times
as far as i know, no one has cracked the code on motobecane serial numbers to indicate year or any other information. that thread i posted was established to begin a database to do so. it is far from complete.
the way we determine moto frame dates is usually relegated to referring to the online catalogs in terms of paint scheme and model options (brazing, bosses, frame material, wheel size, component groups, etc.). when found, component dates can also be helpful.
ok, i 'll try that, there are several original parts on the bike , no more blind alleys with the stamping on the frame, get on with the build..
Quoted: 556 Post(s)
Liked 132 Times
Also, if I may add one caution. It can be very tricky to get an accurate measurement of the inside diameter of the seat tube using the method shown above. The slot cut into the seat lug can introduce innacuracies. Better to measure the seat post if you have it and it was a nice fit. If not, it's best to measure below the seat lug slot, which requires a different tool , or two. FWIW.
Thanks good advice, the seat post was a snug fit and I had to soak it with WD40 to get it out. The Chrome plating has corroded above he pinch point so I'll measure below that line. I have looked for any makers details, no name etc so I assume is not the original (the current seat is a modern plastic one. I'm looking at some options, Brooks look great (price !) eBay France might be worth a bit of searching. Any thoughts on the original seat post e.g was it Chrome or Alu ? Cheers
You think so? This link shows a '72 and '73 that has the exact same head badge as his. I know that's not a true indicator since head badges can be changed, but it was the basis for my guess for his being one of those years. Do you have pictures posted of yours somewhere? I'd love to take a look at them. Motos are some beautiful bikes!
VeloBase.com - Head Badge Gallery
Date of Manufacture of Bicycle Components can be used to date a bike: component dating
6Finger
6
10-11-21 05:49 AM
