Old 10-03-19, 07:37 PM
  #2251
Mad Honk
Quoted: 1301 Post(s)
Liked 1,903 Times in 1,137 Posts
52 telecaster,
Wasn't that in the Madison bike project not too long ago? Smiles MH BTW whadda ya think about a '57 Gretch f-hole in ebony with white piping? It was stolen from my dad about twenty years ago, wish I had it back.
Mad Honk is offline
Old 10-03-19, 08:08 PM
  #2252
TriBiker19
Just call me Carrie
TriBiker19's Avatar
Quoted: 308 Post(s)
Liked 178 Times in 105 Posts
Originally Posted by GordoTrek
This Holdsworth Professional that I recently acquired. Definitely has been ridden. Years of nicks and scratches, grime, dirt, and 4000 layers of bar tape. https://www.bikeforums.net/classic-v...l#post21139041
Those bars absorb all the shocks. And they kinda look like pretzel dogs.
TriBiker19 is offline
Likes For TriBiker19:
Old 10-03-19, 08:39 PM
  #2253
Kdogbikes
Quoted: 158 Post(s)
Liked 148 Times in 74 Posts
Originally Posted by jdawginsc
Is that a rattle can paint job? If so, I am truly impressed!
Thanks!
5 weeks and 2 cans of paint. Went with the vinyl decals over the water slide.
Kdogbikes is offline
Likes For Kdogbikes:
Old 10-03-19, 11:18 PM
  #2254
52telecaster
ambulatory senior
52telecaster's Avatar
Quoted: 1954 Post(s)
Liked 3,658 Times in 1,677 Posts
Originally Posted by Mad Honk
52 telecaster,
Gretches are nice but i never owned one. Currently have 2 teles and an archtop.
52telecaster is offline
Old 10-05-19, 06:02 PM
  #2255
thinktubes
weapons-grade bolognium
thinktubes's Avatar
Quoted: 985 Post(s)
Liked 2,376 Times in 891 Posts
Velomine wheel after 100 miles....
After 30 minutes of work....
thinktubes is online now
Old 10-05-19, 06:18 PM
  #2256
Senrab62
It's the little things
Bikes: Too many, yet not enough
Quoted: 279 Post(s)
Liked 326 Times in 147 Posts
https://youtu.be/TRc9hIXRlq4
https://youtu.be/dvtlsRI8vU4
Good work 👍 what wheelset is that? I thought general consensus was velomine is solid?
Senrab62 is offline
Old 10-05-19, 06:25 PM
  #2257
thinktubes
thinktubes's Avatar
Quoted: 985 Post(s)
Shimano 6800/Mavic Open Pro. Underwhelmed. If you don't have skills/tools budget for truing costs.
Old 10-05-19, 09:15 PM
  #2258
ryansu
ryansu's Avatar
Quoted: 796 Post(s)
Liked 522 Times in 367 Posts
The Takara got a bit more time in the stand, Stem and seatpost cleaned and given new wax, stem shifters mounted and my spare beater 27" araya rim/Suze hub wheelset mounted with used but decent tires and tubes. If I can make the shifting and braking work it will go back on CL as a beater commuter.
Stem shifters mounted, tapered stem meant I had to site them high up for the clamp.
Cobbled together wheelset
ready for cables and bar tape
ryansu is offline
Old 10-06-19, 06:56 AM
  #2259
thumpism
Bikes are okay, I guess.
thumpism's Avatar
Quoted: 2647 Post(s)
I'd wager there are pristine original Grab On grips under that bar tape.
thumpism is offline
Old 10-06-19, 07:11 AM
  #2260
Narhay
Narhay's Avatar
Quoted: 956 Post(s)
Liked 568 Times in 314 Posts
I used the skills gleaned from wrenching on bikes to replace the pads and squeaky rusty rotors on my 2013 Town & Country last night. I have more respect for how physical working in tight spaces like that can be.
Narhay is offline
Old 10-06-19, 07:15 AM
  #2261
RobbieTunes
Quoted: 378 Post(s)
Liked 1,409 Times in 909 Posts
Decided to pull DA9000 out of a box and put it on a deserving frame. US-made Fiorini. This is my 2nd try at making this frame work, and I think it will be fine. I installed a Roadlink, but I think with the DA9000 RD, I'll be ok with the 11-28 rear without it, and take it off, returning shifting to the snappy flick I expect from DA9000, there's about a half-second delay, I find, on the upper cogs using a Roadlink, as the cassette winds around to the right place. I used DA9000 wheelset (Aerohead rims) as well.
I did find some new Challege skinwalls to put on there, so that gets done in the near future. I still have final cleanup to do.
Interesting treatment at the stay tops. I need to clean out the grease, but may just let it stay to avoid corrosion.
Glad I found those seatpost binder pieces.
Had some more spare time, so I went on with putting DA7700 on the Merckx. 2 hours to get the crankset and BB out (15mm bolt heads, and no thin-walled socket). Since I used my Octalink Italian BB on another bike, had to order one before I can complete this. Hard to tell, but this uses a Roadlink, an 11-34 9sp rear cassette, and a DA7700 GS medium cage RD. It works fine. 7403 wheelset.
RobbieTunes is offline
Old 10-06-19, 07:29 AM
  #2262
thumpism
thumpism's Avatar
Nice crosshatch on the rotor. Talk about bling!
Originally Posted by Narhay
I found this Marin at the curb this week and grabbed it. Since it's my size I thought I might give it a chance, although I'm not riding much these days. It would be nice to have a racy rigid MTB. I'm thinking drop bar conversion. Marin stems of that era were known for low rise--this is at max height--and big reach so I won't keep this setup long. There was a lot of rust but the bike was original except for the seat and bar ends. I binned the seat and got the three stiff links in the chain to move. Everything worked but the rear shifting (rusted cable) and I managed to break the shifter by forcing it, but since I don't care for Rapid Fire that matters not to me. No hurry on this one with all my other projects.
thumpism is offline
Likes For thumpism:
Old 10-06-19, 09:37 AM
  #2263
52telecaster
ambulatory senior
I find servicing my own automotive brakes makes me a more conservative driver.
Old 10-06-19, 09:50 AM
  #2264
Narhay
Narhay's Avatar
Quoted: 956 Post(s)
So far so good. Really just 4 bolts, some wiggling pads and clips in and out, smacking existing frozen rotors with a sledge and some piston pushing.
Narhay is offline
Old 10-06-19, 11:26 AM
  #2265
52telecaster
ambulatory senior
The job isnt that tuff its just looking at what saves your life that makes me a tad more cautious.
Old 10-06-19, 11:45 AM
  #2266
Narhay
Narhay's Avatar
Quoted: 956 Post(s)
For sure and I get that it is hard to get over that fear. I suppose building your own bike wheel with a couple pounds of suspiciously thin spokes and relatively soft alloy rims and then descending at 70kmh has fewer component redundancies and safety features than the brake system in a car.
Narhay is offline
Old 10-06-19, 04:34 PM
  #2267
thumpism
thumpism's Avatar
Went by the co-op for a stem that cost me a whole $7. I don't care for adjustable stems but this will give me the latitude to tweak the setup at my leisure and get a fixed stem later. This is the bar setup I had planned to put on my Cimarron so that will have to wait.
thumpism is offline
Old 10-06-19, 04:44 PM
  #2268
52telecaster
ambulatory senior
I worry about the bike too...
Old 10-06-19, 06:45 PM
  #2269
joluja
_______
Bikes: Merckx Corsa Extra, Ciocc Mockba, Zeus Victoria, Serotta CDA, Willier Cento 1SR, Pinarello FP Quattro, Teledyne Titan, Chesini Arena Precision 83, Denti Master, De Rosa 35th Anniversario, 3Rensho Super Record, Koga Miyata Full Pro, Klein Rascal
Quoted: 21 Post(s)
Liked 127 Times in 31 Posts
Finished today..
Finally finished the Teledyne Titan this morning...
joluja is offline
Old 10-06-19, 09:19 PM
  #2270
Ronsonic
Quoted: 101 Post(s)
Liked 49 Times in 41 Posts
Prebuilt wheels can be a bargain. Usually less than the cost of the parts. But, I've learned to treat them like a wheel that's been assembled but not yet trued and tensioned. It's like having someone else do the lacing and pre-tension steps.
I've had only one pair that didn't need to be re-worked.
Ronsonic is offline
Old 10-07-19, 05:29 AM
  #2271
Johno59
Quoted: 331 Post(s)
Liked 332 Times in 185 Posts
1940s Phillips pedals rebuild
Surprisingly well made. Wire brushed, rust converted and new bearings (inside 1/8 outside 5/32) and greased. The locknut design much easier to correctly adjust than most others I'm familiar with.
Heavy rust 70 years old - no problemlemo!
Johno59 is offline
Old 10-07-19, 11:18 AM
  #2272
noglider
noglider's Avatar
Quoted: 7346 Post(s)
Liked 2,452 Times in 1,430 Posts
Yesterday, I went about replacing the crank with the buggered threads. I tried one last time to thread my extractor in, and I GOT IT! As I threaded it in, it gave no indication that it was cross-threaded except that resistance was high. I took that as a good sign, so I continued pushing through the resistance. As long as it was going in, I was happy because the previous times, the extractor kept popping out. I finally got it in deep enough, and the crank came off. Yay.
I put on the VO triple crankset I bought used, but the small ring rubbed against the frame. Darn. Then I noticed that the crankset came with its own BB. Well waddya know. The new spindle is extremely long. I hope my legs don't mind the bigger Q factor. And I hope the front derailleur can reach out far enough!
I didn't have time to try the new front derailleur I plan to put on.
Here is the crank rubbing the frame, before discovering I have a longer BB.
Here is the entrance to my workshop. In the foreground, you see the little house built around the top of our water well. You also see my wife's cement mixer. She's a power tool maven.
As I was working, I heard all kinds of wild creatures in the upper level above me. I think I heard a rodent walking. I know we've had squirrels. I'm also pretty sure I heard a bird flying inside. What kind of bird would take home in a barn? I also saw a mouse come to my entrance. I shouted at him just for fun. I don't like them in the house, but I don't mind them in the barn.
noglider is offline
Likes For noglider:
Old 10-07-19, 02:53 PM
  #2273
52telecaster
ambulatory senior
Most of ur pics dont show, i will say i really like the vo stuff I've used.
Old 10-07-19, 03:07 PM
  #2274
noglider
noglider's Avatar
Please take another look. I hope I've fixed it. And I did test it in a not-signed-in window, and it worked. Grr.
Does anyone know why the VO cranks have two different-styled dust caps? I don't have pictures but can shoot some next weekend.
noglider is offline
Old 10-07-19, 04:50 PM
  #2275
Mr. 66
Mr. 66's Avatar
Quoted: 1135 Post(s)
Liked 1,727 Times in 951 Posts
Here's the Performance all built. Fast!
Mr. 66 is offline
Likes For Mr. 66:
