3x>1x MTB conversion: Gear ratio quetion
Quoted: 5 Post(s)
Want to convert my 3x MTB to 1x for simplicity and aesthetic reasons.
Some assumption/context first:
> Primarily ride on dry paved trail / gravel / fire roads (mostly flat). No single track or downhill.
> My current 3x set-up provides a sufficient gear range.
> I have a flexible budget.
Using BikeCalc.com - Bicycle Gear Ratio Chart, my current/proposed gear set-up are as follows:
3x (22-32-44T crank | 11/32T cassette) Gear ratio range = 0.70 - 4.00
1x (44T crank with 11/50T cassette) Gear ratio range = 0.90 - 4.00
I would be setting us the 1x using the "shark" by OneUp Components - The mountain bike drivetrain specialists.
Does this set-up and math work out and -- most importantly -- will there really be much of a real-world difference between the .70 and .90 granny gear?
If you never use the 22/32 combination, you can probably live if the loss since you'd really only be living with maybe 1 lost gear. On the other hand, if you use the 22/32 on a somewhat regular basis, you're going to notice a big different going to a 22/25.
Your proposed gearing will be 30% harder to push that your current 22/32. That's a pretty massive difference, unless that's a combination which never gets used.
Have you considered dropping to a 38t or 40t front ring? Your current 44/11 combination is pretty high for a mountain bike. With a 40t ring, your low is 0.8 (high = 3.63), which gives you one gear lower and you only lose your current highest gear (44/11 = 4.0, 44/12 = 3.6). I found that the 44/11 was pretty useless on a mountain bike, there's too much drag to really push hard above 20+ mph, which is where you want that type of gear.
Old Fart In Training
Quoted: 12 Post(s)
Liked 22 Times
Use this calculator, It will show you speeds at a particular cadence, cadence range.
Mike Sherman's Bicycle Gear Calculator
I did the 1x thing to my 3x mtb and loved it, I used a 32T Race Face narrow/wide up front and the Shimano M8000 system out back. 11-42T cassette had plenty of range for me. I can climb pretty much all my local trails.
Some are a challenge and some I cannot do,,,yet.
a 3x9 27 speed only has about 14 gears, NO repeats on a 1x
The M8000 clutch adjustment is external, can be done In the field, I never had to touch it, was perfect at the factory set up.
I use no chain guard/keeper that could jam up as my Narrow wide holds my chain very well. No chain slap on the chain stay, I even took off my Lizard skin,,no longer needed It
I am stronger and faster now, Am considering a 34T up front but so rarely spin out In top gear I may not make the change.
Disco Infiltrator
Quoted: 3126 Post(s)
Liked 2,105 Times
I don't have any new bikes on my horizon right now but if I did they'd all be 1x. I think if I were in your situation I'd use a smaller front, regular rear (11-46 or 10-42), and sacrifice the top gears that I seldom use. It won't achieve the whole range but the shifts will be nicer. If you really need the entire range then a double or triple is still a good plan.
Genesis 49:16-17
Genesis 49:16-17
Bikes: '04 LeMond Buenos Aires, '82 Bianchi Nuova Racing, De Rosa SLX, Bridgestone MB-1, Guerciotti TSX, Torpado Aelle, LeMond Tourmalet 853, Bridgestone Radac
Quoted: 101 Post(s)
Liked 46 Times
I recently built up a Trek 950 as a drop bar commuter. I mostly used stuff I had on hand, and have it set up with a 38T ring up front and a 12-21T 8sp cassette. I have some hills to deal with but it's workable.
Disco Infiltrator
Liked 2,105 Times
Since you'd need to buy the 11-42 system in the first place, you could install it first and give it a chance. If you don't like the result, then you can get the Shark system.
Shimano also now has 11-46 cassettes on offer. So you might not need to go for the Shark anyhow.
FWIW, an 11-42 cassette all by itself offers the same overall range and four more ratios compared to a 3x5 MTB system from the mid 80's!
Genesis 49:16-17
Genesis 49:16-17
Rohloff hubs were also aimed at replacing a MTB drive train with out a derailleur to Muck up or bend in a crash.
3x5 MTB triples from the mid-80s were often something like 46/36/26 with 14-16-20-24-30 freewheels. This is what this looks like in log space (3x5 on the left, 11-42 11-speed cassette on the right):
I can sort of think of a conservative way of reading this chart to see only eight useful ratios, but definitely no fewer. An enthusiastic double-shifter would see at least nine, and possibly up to twelve if they were particularly ambitious.
For a 3x5 triple to offer only seven useful ratios, you'd have to have catastrophic overlap between rings, where the cog-to-cog spacing is the same as the chainring-to-chainring spacing. Something really silly like a 14-17-20-24-28 freewheel with 43/36/30 cranks:
Disco Infiltrator
Liked 2,105 Times
That would imply that the 3x5 system is only getting seven useful ratios.
I can sort of think of a conservative way of reading this chart to see only eight useful ratios, but definitely no fewer. An enthusiastic double-shifter would see at least nine, and possibly up to twelve.
Genesis 49:16-17
Genesis 49:16-17
The shift pattern would kind of suck for some of them, although toward the lower gears a few would be easy to take advantage of.
Yes there are more unique ratios but you wouldn't use them.
Through technical and rough sections it's clumsy to go hunting for precise gear ratios, which is part of the appeal of 1x system. You can't fall into precise cadences anyway so there's no need for the tight spacing of modern 2x and 3x systems; instead, you just want a reliable, simple shift pattern.
When things smooth out, I'd definitely use more ratios. Especially if we delve into road riding.
The big shift to the bottom ring is a bailout granny for when you suddenly run out of torque and want to dump all the gears
and in the upper half it would be cross chained.
Getting a large number of useful gears out of the first 3x5 triple I posted requires no big-big or small-small cross-chaining; those gears are some of the most redundant in the system, especially big-big.
All this is moot, anyhow, these systems are 30 years gone.
1x11 is really, authentically, objectively better.
I'm not really arguing that vintage drivetrains are amazing, though; I just think you're exaggerating their weaknesses. I ride several vintage bikes, and I definitely make use of more ratios than people sometimes say I have.
Disco Infiltrator
Liked 2,105 Times
I love a good gearing thread but this is clutter
Genesis 49:16-17
Genesis 49:16-17
Quoted: 5 Post(s)
Ratios are meaningless.... use gear inches please.
:: Initially, I was using the ratios as a way for me to compare my existing gearing to my proposed. I know how hard it is to pedal with my current hardest gear (4.0) and second hardest gear (3.4). And if I switch to the 36 - 11x50, I will basically lose that 4.0 gear, but keep the rest of the range I have now (especially the .7 granny gear -- I'm an older guy with a bad knee) ::
casette/Inches/Ratio
11 89.9 3.3
13 76.1 2.8
15 66.0 2.4
18 55.0 2.0
21 47.0 1.7
24 41.2 1.5
28 35.5 1.3
32 31.1 1.1
37 26.7 1.0
42 23.6 0.9
50 19.8 0.7
Quoted: 5 Post(s)
OK, so here is the Inches/Ratio for the 36 chainring and the 11x50 cassette. Does this help? And can you explain how it helps? Thanks.
This is the quote/answer that helped me to this end ...
11 89.9 3.3
13 76.1 2.8
15 66.0 2.4
18 55.0 2.0
21 47.0 1.7
24 41.2 1.5
28 35.5 1.3
32 31.1 1.1
37 26.7 1.0
42 23.6 0.9
50 19.8 0.7
You will lose the equivalent of your current two lowest gears.
11 89.9 3.3
13 76.1 2.8
15 66.0 2.4
18 55.0 2.0
21 47.0 1.7
24 41.2 1.5
28 35.5 1.3
32 31.1 1.1
37 26.7 1.0
42 23.6 0.9
50 19.8 0.7
Gear-inches is helpful if you're comparing different wheel sizes. It used to be the standard, so there are some people who think in gear-inches, as in "I need 30 gear-inches to climb an X% grade".
Bikes: Schwinn Varsity
Quoted: 1931 Post(s)
Liked 742 Times
Those look like good gears.
20 inch low gear... that's low. If that doesn't work, walk the bike.
90 inch high I think is good. No higher needed on MTB
Quoted: 686 Post(s)
Liked 5 Times
When I did my swap, I just kept the middle 32t up front and the the 11-36 cassette that came on my bike. Pretty much just bought one of these and called it a day.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
I have to hike a bike on occasion, but those are only on long steep or technical inclines.
Quoted: 5 Post(s)
Quoted: 686 Post(s)
Liked 5 Times
I had actually thought of that but my LBS told me that I couldn't do it and basically should just buy a new 1x bike. Which didn't/doesn't make sense to me when I look at the cranks ... they have the four bolts that look like I could get just what you said ... could I have run into a bad LBS experience?
If the shop is telling you to buy a new bike and that you can't do that, they're smoking crack.
I basically just pulled my crankset, took off the 3x rings, put the single on, pulled the front derailleur and cabling, put the crankset back on, and called it good. Took me about an hour or so.
Nanaterry
Touring
26
02-02-13 10:19 AM
puppypilgrim
Folding Bikes
0
11-15-10 11:50 AM
