Eddy Merckx Corsa ID help needed!
Bikes: Eddy Merckx Professional, Gazelle Champion Mondial, Bianchi XR2 and more.
Hi all!
I recently acquired this Eddy Merckx Corsa:
EDDY MERCKX CORSA by 2beus | PhotobucketI bought it as a complete bike, but has since then taken it apart. I’ve had lots of steel frames over the years but this is my first Merckx and I’m really exited about trying it out. Part of the joy for me when buying a “new” bike is to find out its history, but with this frame I’m having some trouble and that’s why I could really need some help.
I’ve been comparing the serial# (A2-3990-E) on my frame against other serial numbers on cadre.org and it seems like Merckx bikes with an “E” at the end of the serial# are either from 95/96 or from the early 80’s. The fact that my frame has got cable routing over the bottom bracket would rule out the 90’s and confirm that the frame is from the early 80’s. I’m I right to think this, and if so, is there any way to find out a more exact year of manufacture?
Also, I assume that the “original paintwork” decal and the lack of a tubing decal would suggest that the frame has been repainted? The paintjob looks 90’s to me but I haven’t been able to find another bike from the 90’s with this paintjob. I’m hoping someone can tell me more about the paintjob and perhaps provide me with some educated guesses regarding what tubing might have been used.
I’m also a bit confused to why the serial number on this frame starts with an “A” when Corsas generally have a “C” as the first letter (again, according to cadre.org).
Any info would be greatly appreciated!
Kind Regards,
Tobias
Kind Regards,
Tobias
lots of anomalies on that frame. Does the fork have a matching serial number?
All signs point to early 80's, except paint. Factory repaint?
Thanks for the reply! I need to check the fork for serial number, forgot about that today. Do you think the fork might be later than the frame?
The fork *maybe* newer, but that design was available early on. I would also check the ST & HT angles. I wouldn't be surprised if it was a Professional, not a Corsa.
That's interesting! The "A" in the serial would according to cadre suggest that it started its life as a Professional. What would be the difference between a Professional and a Corsa in terms of HT and ST angles?
I believe (not sure) that the Professional has steeper angles than the Corsa, Corsa a bit more laid back on the ST. I have always preferred Professionals.
aka: Dr. Cannondale
Quoted: 2152 Post(s)
Liked 3,401 Times
Definitely early 80's, somewhere between 81 and 84 I would guess. My experience with Merckx serial numbers is that they were not always applied sequentially, so it can be difficult to pin down precise dates.
Pretty sure that over the BB cable routing was prior to the Corsa/Corsa Extra designation, so could well be a Professional. Fork would be period correct, both the sloping and flat crowns were available. Sometimes the steerer has information on it regarding the frame it was paired with, but if it's a respray, that may not be present (on one of my Merckx frames of the same period, there was a piece of paper with this information taped to the steerer).
Definitely a respray, in 'Corsa 01' style, and those decals probably came along as a full sheet. Might be a factory respray, but the infills look pretty amateurish to me. Chrome is in good shape, rare for a Merckx frame of that age.
While it's torn down, check the steer tube and seat tube above the bottom bracket for the helical reinforcements that would indicate Columbus SL tubing.
Nice frame. is it 62cm? The 2 on the DS stamping would indicate either 52 or 62...
Cool, thanks! I will do some more research regarding the angles on the Professionals vs Carsas.
Quoted: 233 Post(s)
Liked 396 Times
Hi! this is Eddy Merckx 1982 (the name "Professional" is not official), Columbus SL, repainted at the Merckx factory in the 90s. A2 E3990 means: A - designation of an employee responsible for preparation of the chroming / painting frame (A is not a model / tube type designation - it appears in the years 1980 - 1989 on every Merckx model), 2 - 52 or 62 cm seat tube, E - the first "letter" EM series of bicycle frames 1981-1984 (in 1980 the series "letterless" was produced, there never was an E series from 94/95), 3990 ~ summer 1982. Corsa appeared at the earliest in 1985 and had the same geometry from Eddy Merckx 1981-1986. The numbering and marking of the EM frames is continuous and logical - in case of any problems, I will help you best regards - Jacek
Quoted: 233 Post(s)
Liked 396 Times
Hi! reason 1: destroyed old paint coat - we renew the frame with currently available paints; reason 2: we think that the original painting is "unfashionable" and we order the latest or the best Corsa was a direct successor (continuator) EM (Professional) - practically changed only minor details - Best Regards - Jacek
stone52076
1
05-03-11 06:28 PM
