The darn adjustable bottom bracket cup won't come out.
Quoted: 339 Post(s)
Liked 631 Times
I am working on a Shogun Alpine GT steel frame trying to finish disassembly so I can do an overhaul.
I have removed the drive side bottom bracket cup and the crank spindle but the adjustable cup won't budge.
Using a pin wrench just broke off the pins.
Using a punch in the pin holes just ruined the holes .
A (left hand) pedal spindle inserted through the hole in the cup and tightened as much as we could to a Forged left handed thread crank arm to act as a wrench just turns against the cup no mater how much we tighten it.
Liquid wrench left to soak a couple days didn't do anything.
Any other suggestions? heat? saw through the threads from the inside?
Bikes: 2016 Fuji Tread, 1983 Trek 520
Quoted: 674 Post(s)
Liked 738 Times
I haven't done it on a bike, but in auto and plumbing I've carefully cut the threads in one or more places then taken a cold chisel to it to break it loose. You may then need a shop to chase the threads with the correct die, or use an old freewheel hub (threads are the same on the NDS, I hear).
Or cut a wide slot across the face, and use that for cold chisel purchase at the outside edge of the piece.
Heat (electric heat gun) may help, but you probably just can't get enough torque on the piece.
Quoted: 1438 Post(s)
Liked 1,092 Times
Before resorting to extreme measures, try putting on some Kano Kroil (best) or PB Blaster. Liquid Wrench is weak in comparison. After applying a generous amount give the joint a few whacks to get things started, then wait overnight or better 24 hours and try to remove it. If not try more goop and time.
Bikes: old clunker
Quoted: 684 Post(s)
Liked 105 Times
Here's a tool that might help:
https://www.sheldonbrown.com/tooltips/bbcups.html
Also get as many factors in your favor as possible: soak with Kroil or PB Blaster for at least a week, apply heat, and make absolutely certain* you are turning the correct direction.
*A recent poster here said "pretty sure" about thread direction but this is binary: either 100% right or 100% wrong. You can guess which.
Quoted: 892 Post(s)
Liked 2,050 Times
Use Sheldon's tool (which he describes as being for fixed cups), linked above, following the French or Italian thread variation. I think the washers are key, since it provides more surface area to grip the cup.
Friendship is Magic
Bikes: old ones
Quoted: 26382 Post(s)
Liked 10,359 Times
2. The best penetrating oil (by far) is a 50/50mix of acetone and ATF. since you work in the co-op environment, you need to try this.
Keep it in a plastic bottle that is acetone resistant plastic, or the bottle will melt. An old, small black squeeze bottle from Tri Flow is what I use.
Shake it before each use, and cap it when not in use.
3. In some cases, you can file wrench flats on the portion of the cup that was exposed when you removed the lock ring.
Then use some sort of bolt and fender washers to affix whatever wrench to the cup and hit the handle of it with a hammer.
4. Again, since you have a co-op (where I presume you do much of this work), you really ought to convince them to buy a Hozan fixed cup tool.
It will also work well for this adjustable cup, inserted in the proper direction and used without the flats attachment of the tool.
5. If you have one, a MAPP gas torch will make this and other stuck cups come out easily with heat, but be careful not to get the shell hot enough to blister the paint.
Quoted: 2336 Post(s)
Liked 2,809 Times
also I recommend PBBlaster..... combines freezing with penetrating oil
Quoted: 1062 Post(s)
Liked 665 Times
bike whisperer
Quoted: 1523 Post(s)
Liked 716 Times
You can try cutting a slot all the way through the face with a cut-off wheel on a dremel, and grab it with a thick bit of steel plate in a vise.
As for the direction, isn't every NDS BB thread right hand?
The ATF/Acetone mix is your best bet. Squirt some on a couple times a day and rap it a few times with a ball peen hammer. After a couple of days use an angle grinder to cut some slots on the face and use a hammer and cold chisle to try busting it lose.
Super Moderator
Quoted: 1173 Post(s)
Liked 927 Times
Grind 2 flats on the exposed adj cup, then try a big-ass pipe wrench.
If the pin spanner holes are already gone this won't be helpful, but options/tools exist for that.
I have a bolt on adjustable cup remover. It's a socket tool with 6 pins to engage all the holes, provided the cup has 6 holes. On the outside is a collar that secures it in place using the threads the lockring would have occupied. Royce style bottom bracket socket tools also have 6 pins to keep them from slipping.
Bikes: Too, too many....
Quoted: 125 Post(s)
Liked 130 Times
If the bike is USED it is possible (unlikely, but possible) that the previous owner has had issues with the adjustable cup coming loose and has assembled it with a couple of drops of blue (removable strength) Locktite.
If this is the case, you are going to need some heat to soften it. Not too much heat... In rare instances where hand tools do not work because of excessive engagement length, apply localized heat to approximately 482°F (250°C). Disassemble while hot.
Bikes: 2009 Masi, 2014 Specialized Crossroads 1975 Schwinn Unicycle
Quoted: 12 Post(s)
I'd try getting the lock ring off first. I have a pair of the old,, VAR Lock ring Pliers. I had 2 bikes from the 1980's with frozen adjustable cups. The fixed cups came out rather easy. Both adj. cups had a single "notch" straight across them. I took the fixed cup wrench & placed the edge of it. Straight across the slot & hammered that loose. Good Luck,,
Quoted: 339 Post(s)
Liked 631 Times
Still no luck with the adjustable cup.
I followed Saint Sheldon's instructions and made a remover out of a 5/8" bolt , lock washers, and a nut that clamps the cup , soaked the threads in liquid wrench for a week, heated the bottom bracket with a butane torch , wrenched on the puller with a large wrench. and tried tapping the pin holes with a drift punch , all to no effect except to break the end off the punch . Yesterday I cut a slot in the face of the cup with a diamond blade hack saw then tried to cut through the inside face of the cup with a metal blade and a sawzall. The steel of the cup just dulled the sawzall blade.
I am wondering if the PO used red Loctite on those threads.
I think the only way this sucker is coming out is if I can find a sawzall blade that is diamond coated to finally saw through the cup. If I can make at least 2 cuts in it I can probably tap the threads from the outside to break them loose.
As Bugs Bunny always said:
"Of course you know This means war"
Friendship is Magic
Bikes: old ones
Liked 10,359 Times
...you need quite a bit of heat on a BB shell/cup combination. I use MAPP gas, which is also what I use to solder join copper plumbing. Even red Loctite will give up if you get it hot enough. And Liquid Wrench is not the best penetrating oil, by any stretch of the imagination.
Liked 2,809 Times
You were using 2 wrenches (one a socket for inside the bottom bracket) correct?
For an adjustable cup, you should be tightening the nut on the inside of the bb while holding the head of the bolt on the outside. for a really tough on you might need a helper and a breaker bar
Droid on a mission
Quoted: 317 Post(s)
Liked 280 Times
adjustable cup you missed that data point it's the one on the left side,
all are right hand thread on that side of th BB . non drive side
