Vintage Cannondale A113 Top Tube Cable Guides
I'm sure this has been asked before, but does anyone have any recommendations on replacing damaged cable guides for a vintage "Dale"?
Author Doug Keeler - Author Doug Keeler
Quoted: 85 Post(s)
Liked 74 Times
The guides sold on on vintagecannondale.com are sold out. They are more expensive but easier to install in my opinion. But for now Shapeways may be the only adoption unless you can find some NOS guides at a dusty LBS.
https://shop.vintagecannondale.com/c...ant=3139324227
Sophomore Member
Quoted: 1628 Post(s)
Liked 1,057 Times
I used 34.9 mm clamps off Ebay, I got 4 less than $10, but 2 were the wrong size so I had to send for more, and they take weeks to arrive from China. Not the prettiest solution, but better than the painter's tape I was using before. Had to buy longer screws for the clamps too, the ones they came with were about 1 mm too short.
aka: Dr. Cannondale
Quoted: 2155 Post(s)
Liked 3,404 Times
How many do you need?
aka: Dr. Cannondale
Liked 3,404 Times
I can mail you one of my spares for the cost of postage, figure $2 in a padded bag. Pins are gone but if you clean the top tube and mount with rubbing alcohol and glue it on with ShooGoo (nothing else does the job, I've tried several kinds of similar products), then allow to cure 24 hours, it will work just fine.
If interested, PM me your address and I'll drop it in the mail. My PPID is rccardr@cox.net
If you have access to a 3d printer .. you can make these
https://www.thingiverse.com/thing:811446
https://www.thingiverse.com/thing:3446663
Bikes: '84 Miyata 610 ‘91 Cannondale ST600,'83 Trek 720 ‘84 Trek 520, 620, ‘91 Miyata 1000LT, '79 Trek 514, '78 Trek 706, '73 Raleigh Int. frame.
Quoted: 685 Post(s)
Liked 370 Times
Along these same lines does anyone know of a source for the plastic pump peg that fits in the head tube and the plastic chain holder on the seat stay? Both are missing or broken on my ST1000. Cheers.
I have an OEM chain holder plus pins from a Criterium model. I assume they are the same but I can take a photo if needed. $5 shipped. Can't help on the pump peg.
Quoted: 1627 Post(s)
Liked 630 Times
I bought two sets of Shapeways (just OK) repro cable guides just so I could harvest the very precious, fragile Cannondale original cable guides for my personal "keeper" bikes. The repros do the job, but they're not the same thing.
