Bigger cog or smaller chain rings?
I have a 2018 Domane SL5 disc which I like very much. It runs 50x34 chain rings in the from and an 11x32 cog set. I would very much like a a lower gear for getting up the really big hills that I frequently ride. Would it be better to move to an 11x34 cog set, which I know Shimano makes, or would it be better to shop around to find 46x30 chain ring combo, which I hear is available. The bottom bracket is the Trek BB90 and the bike has the 105 group set. Any ideas? Thanks.
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
Mother Nature's Son
Quoted: 853 Post(s)
Liked 1,434 Times
Can't get to 46x30 just by changing the rings on the crank. As noted above by ThermionicScott, gotta change crankset.
bike whisperer
Quoted: 1528 Post(s)
Liked 718 Times
IMO if you need lower than 34/32, you need a triple - there's already a lot of compromise in that gearing, and a triple eliminates it. Pity they're not really a thing anymore, and in this era when everyone wants lower gears, that's just dumb.
If you had Campy levers, you could do it with a crankset and FD, plus chain and long cage RD. Otherwise SOL.
Sheldon Brown's bike info ~~~ Park Tools repair help
Half-step triple, using double gear ~~~ 6400 STI rebuild walkthrough ~~~ Want 8/9/10s @126mm OLD? OCR. ~~~ Shimano cassette body overhaul ~~~ Ergopower Escape wear repair ~~~ PSA: drivetrain wear
List of US/Canada bike co-ops ~~~ Global list
Quoted: 4803 Post(s)
Liked 3,924 Times
Liked 3,924 Times
Ben
https://absoluteblack.cc/oval-road-c...-for-110-4bcd/
but it ain't cheap. I run that on my road/gravel bike and love it. GRX wasn't around when I bought it though and at this point I would probably go for a GRX crank and new FD instead, probably the 48/31. The 46 is fine but the 48/31 would keep more of that top end without really making climbing any different.
if you have 110 bcd crank, 46/34 works well for me, able to stay on the big ring most of the time for increased efficiency. unless you really want to push your luck down hill, 46/11 is plenty
Liked 2,568 Times
Sure you can
I had round rings on a smaller BCD in mind, of course.
Take look at the new GRX components from shimano. There is a 46/30 crank (For this you need the FD as well). Combined with a 11-34 cassette you have good gear reduction.
Bicycle Gear Calculator
motorapido
Singlespeed & Fixed Gear
11
04-17-15 01:26 PM
fork
7
06-06-14 07:04 AM
dolphin62
4
08-24-11 11:53 AM
