Cassette change -- 11-30 to 11-32
Bikes: 2019 CAAD12, 2015 Specialized Sirrus Comp
Quoted: 562 Post(s)
Liked 64 Times
Been doing a lot of hill climbing lately and sometimes wish I had one more cog for the steepest hills. Current cassette is 11-30, and chainrings are 52-36. Bike is a CAAD12 with Ultegra mech.
I'm thinking of changing the cassette to 11-32. Going from 30t to 32t is a 7% reduction in effort and costs about $100 in parts (including the chain). Changing chainrings to 50-34 is way too expensive.
New wheels are coming, so there's a bit of a labor savings by not having to remove the 11-30 from the old wheel.
Is going to 11-32 worthwhile, or is it too close to matter?
Thanks,
Robert
Thanks,
Robert
Quoted: 344 Post(s)
Liked 20 Times
Thanks,
Robert
Thanks,
Robert
Cheers
Likes For cycledogg:
Likes For dwing:
Quoted: 562 Post(s)
Liked 64 Times
I already climb 1000-2000 feet every time I ride, which is usually 2-3 times a week, and have climbed 112,000 so far this year.
Quoted: 551 Post(s)
Liked 277 Times
Likes For tagaproject6:
When i shift from my 28 tooth cog to 32, i totally feel it I have never shifter from 30 to 32, so i have no idea. That is too small of a change. I suggest you to go for a 34 instead.
Quoted: 562 Post(s)
Liked 64 Times
On the Ultegra 11-32, the second lowest gear is 29t, so it's not quite the same jump as you describe..
Globo Gym lifetime member
Bikes: Fast ones
Quoted: 410 Post(s)
Liked 614 Times
I moved from a 25 to a 28 due to a change of topography and was amazed at the difference. My times on climbs actually went down a little bit because I was able to stay "on top" of the gear a little better and hold power without draining the tank on steeper sections.
Quoted: 20810 Post(s)
Liked 9,456 Times
If it's not giving you a more problematic gap someplace else, go for it.
Quoted: 562 Post(s)
Liked 64 Times
How can I identify which Shimano R8000 derailleur I have -- short cage and medium cage? Medium cage is required for cassettes larger than 30t.
Are there specific markings to look for?
Sunshine
Quoted: 10963 Post(s)
Liked 7,490 Times
No harm in trying the SS RD with a 32t cassette, if that's what you have. Move the B screw and give it a try.
As for the old cassette removal, it takes 30seconds. The labor is basically non existent. Dont think twice about mounting/removal of a cassette. It's a simple tool and almost no effort.
A 50/34 compact r8000 costs +/-$215. A 34/30 bailout is the same ratio as a 36/32 bailout. Yes it's more $, but it keeps the same jumps in the cassette you have and you will presumably use the 11 and/or 12 tooth cogs more often. I assume you dont spin out on 52/11 right now.
Just something to consider.
Likes For Atlas Shrugged:
Quoted: 8279 Post(s)
Liked 9,033 Times
Ever been on a group ride and watched guys try to change a tube?
Likes For big john:
Sunshine
Liked 7,490 Times
Its 3 things and takes 30 seconds.
Point was- it isnt a difficult component to add/remove.
Likes For mstateglfr:
Liked 9,033 Times
Quoted: 562 Post(s)
Liked 64 Times
Measure from pulley center to pulley center on the arm. If it's about 3.5", then it's a GS RD.
Bikes: 1986 KHS Fiero, 1989 Trek 950, 1990 Trek 7000, 1991 Gary Fisher Hoo Koo E Koo, 1992 Trek 1400, 1997 Cannondale CAD2 R300, 1998 Cannondale CAD2 R200, 2002 Marin San Rafael, 2006 Cannondale CAAD8 R1000, 2010 Performance Access XCL9R
Quoted: 284 Post(s)
Liked 385 Times
This was going to be my question as well. I can fit a 30, but 32 is too big. Really, 30 is too big, but tolerable with the "B" screw in all the way... I have a 11-36 that works if I use a "Road link" with my mid cage SRAM Rival..., Or even my short cage 105 5600... I have not ridden the 36 yet, just on the trainer and work stand...
Quoted: 359 Post(s)
Liked 85 Times
A 34t chainring is about 20$.
if you are mechanically inclined, pulling your crankset and swapping your 36 for a 34t front chainring is pretty easy.
Other than a little chain slap (if riding in a 34x11) This is doable with the FD in a 52/34.
Just another option for you. The only tools you will need are allen wrench set, torque wrench (which you should also use for changing your cogset if you do) and a 5$ Shimano crank tool (TL-FC16)
velo-dilettante
Quoted: 1628 Post(s)
Liked 3,114 Times
if you can reasonably afford to do it and it is mechanically doable on the current bike, then why not?
if you only use the "extra" gears to catch a short breather before shifting back into harder gears-great.
if you use the "extra" gears because there is no way you'd make it up the particular hill otherwise-great.
it's nice to have and you'll need them at some point to save the knees, your pride or the ride. you don't live in florida.
there are plenty of times i've wished i had a 30 or 32. let's just say my 27 gets waay too much work. helps to build strength
but doesn't help to build cardio and is a liability when riding with young punks (you know who you are).
Changing the cassette is easy. You can use the cassette tool with an impact tool and it comes right off, no chain ring tool needed. Just hold it with your hand. Even the small impacts you use around the house for screws and general construction work fine. Just my 0.02...
Quoted: 1743 Post(s)
Liked 1,281 Times
My CAAD 12 came with the same gearing as the OP's. I couldn't spin the 52x11 at comfortable rpms. So, I swapped out the 52/36 for a 50/34. Same cassette. Much better for me.
With the amount of climbing you do, even going from a 30 to 32 chainring will be an improvement IMO. For a more noticeable gain, Check out ratio's with a 34T cog. You might require a longer derailleur cage for either a 32 or 34T large cog, I'm not sure.
The stock approx. 32.5 gear inches on the lowest gear is probably fine for most folks who don't see long steep hills. But for long rides up moderately steep paved grades lows in the 25 - 30 gear inch range might be best. A 32 rear cog is about 30.4 gear inches, And a 34T is 28.6, that would be a big improvement if you can make that work.
For short climbs a 2T difference is barely noticeable. Even on long climbs an A/B comparison will show little difference. But a little difference on a long climb can mean the difference between a pleasant ride, and fighting to get up.
I like bigger gaps (up to 21% we get with 34 - 28 sprockets) in the lowest ratio's. But it is important the midrange be at a max of the 14.3% we get with 14 & 16T cogs, Preferably about 12.5% max (16 & 18T cogs). Ironically my 7 speed Shimano Mega - Range cassette on my budget comfort bike has better ratio's in the midrange then most 9 or 10 speed cassettes, and offers a 34T granny gear.
At first I hated the concept, But in practice, It is one of the best principles when combined with 2 or 3 chainrings. Which might explain why it has been so successful for decades.
